Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 03-19-2006, 11:25 AM   #1
Division By Zero
Member#: 7555
Default Timing question!
Okay, looking at this log, you'll see that timing is quite low. This is the effect of the UTEC making a global timing change after it thought it heard knock events I believe. One of the main issues is that I haven't had a really good way of hearing knock yet. The engine is noisey and the UTEC (sensitivity is decreased -5 off the STI default sensitivity settings) and it's picking up knock if you look at it wrong. I found that in the higher rpms just get the AFR beyond 10:1 (leaner) resolved alot of the knock up high. But if you notice the ECU timing seems quite happy!
Recommendations anyone? Seems as if I should be able to push alot more timing as the pistons are 8.4:1 CR.
Todd
PHP Code:
                    Load Knock                     Mod   Mod         Mod
RPM   MAP  MAF TPS Site Count  AFR  Ign
#1  Inj#1  Ign   Fuel Boost  MAF
psig  V   %                    deg   duty   deg    %   (CL)    V
5073
+18.8 5.0 102  80    00   rich +23.7   61.0  +6.0 -19.5 150.00 3.6
5257
+18.8 4.7 102  80    00   rich +25.4   62.2  +5.9 -19.5 150.00 3.5
5402
+19.2 4.9 102  80    00   rich +26.2   62.7  +5.9 -19.5 150.00 3.5
5437
+20.0 5.0 102  90    00   rich +24.7   61.0  +5.5 -20.5 150.00 3.5
5509
+20.4 4.9 102  90    00   rich +25.0   58.6  +5.9 -20.5 150.00 3.4
5574
+20.0 4.8 102  80    00   rich +24.6   63.7  +6.4 -19.5 150.00 3.5
5698
+20.2 5.0 102  80    00   rich +30.7   63.4  +7.1 -19.5 150.00 3.6
5889
+20.2 4.9 102  90    01   rich +29.3   61.7  +7.5 -20.5 150.00 3.6
5889
+19.4 4.8 102  80    00   rich +29.5   64.1  +9.6 -19.5 150.00 3.6
5931
+19.8 4.9 102  80    00   rich +29.3   63.7 +10.9 -19.5 150.00 3.5
6071
+19.2 4.8 102  80    00   rich +28.1   63.7 +11.0 -19.5 150.00 3.4
6138
+18.8 5.0 102  80    00   rich +29.1   65.1 +11.2 -19.5 150.00 3.6
5995
+16.7 4.1   1  60    00   rich +39.5   15.1 ECU.  -13.4 ECU.   2.3
Division By Zero is offline   Reply With Quote
Old 03-19-2006, 04:46 PM   #2
Division By Zero
Member#: 7555
Anybody want to take a chance on a solution Don't be shy!
Old 03-21-2006, 08:32 AM   #3
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
todd, some parts of this log pop out at me:
Code:
5073 +18.8 5.0 102  80    00   rich +23.7   61.0  +6.0 -19.5 150.00 3.6
5257 +18.8 4.7 102  80    00   rich +25.4   62.2  +5.9 -19.5 150.00 3.5
5402 +19.2 4.9 102  80    00   rich +26.2   62.7  +5.9 -19.5 150.00 3.5
5437 +20.0 5.0 102  90    00   rich +24.7   61.0  +5.5 -20.5 150.00 3.5
5509 +20.4 4.9 102  90    00   rich +25.0   58.6  +5.9 -20.5 150.00 3.4
5574 +20.0 4.8 102  80    00   rich +24.6   63.7  +6.4 -19.5 150.00 3.5
5698 +20.2 5.0 102  80    00   rich +30.7   63.4  +7.1 -19.5 150.00 3.6
5889 +20.2 4.9 102  90    01   rich +29.3   61.7  +7.5 -20.5 150.00 3.6
5889 +19.4 4.8 102  80    00   rich +29.5   64.1  +9.6 -19.5 150.00 3.6
5931 +19.8 4.9 102  80    00   rich +29.3   63.7 +10.9 -19.5 150.00 3.5
6071 +19.2 4.8 102  80    00   rich +28.1   63.7 +11.0 -19.5 150.00 3.4
6138 +18.8 5.0 102  80    00   rich +29.1   65.1 +11.2 -19.5 150.00 3.6
look at that raw maf voltage... it's bouncing around all over the place.
a bit of vacillation between two adjacent tenths (ie 4.7 to 4.8) is common/expected, but you've got a swing of THREE tenths going on there. too much. that's not normal. that's turbulence in the maf sensor area.
until you get that worked out it doesn't make much sense to kill yourself on the rest of the mapping... as they say in IT, garbage in garbage out.
as i pointed out in the other thread, you also need to get the raw voltage lower... as a first attempt, perhaps you should try the "screen before maf sensor" trick to laminarize the flow. who knows--it might also reveal that the 5.0mafv were just anamolies due to the turbulence.
ken
ken
Old 03-21-2006, 09:50 AM   #4
Division By Zero
Member#: 7555
So you think it was because of the leaking BOV, which is post MAF but pre TB? The BOV is about 6" before the TB and probably 15" after the MAF (guesstimation).
Long time question, sort of off topic scoob question i-Style Off-Topic 32 08-03-2002 01:25 AM
STI variable valve timing question alfriedesq Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-18-2002 04:22 PM
Tuning wizards: Timing question..... AZScoobie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-09-2001 03:59 PM
Big time question??? Need advice Please! BADWRX Brakes, Steering & Suspension 6 06-26-2001 12:01 AM
Quarter Mile times question?? 98vs99-01 auto/stick? MichiganRS General Forum Archive 0 02-08-2001 05:58 PM
