Old 03-19-2006, 02:05 PM   #1
whiskywizard
Member#: 44482
2004 Impreza 2.5TS
& 2007 Spec.B
Default fast idle problem - need advice please
I'm new to Subarus and would appreciate any help available from those more knowledgable... thanks
2004 Impreza TS2.5 wagon. No mods. 61k km (40k miles)
At cold start, fast idle ranges between 1700 & 2000 RPM. When driving away cold, fast idle increases. With each upshift, idle will remain high, even 2-3k RPM and very slowly drop to about 1800 RPM if the clutch is kept depressed.
After engine warms up to operating temps, idle remains fast for another 20 minutes or so of driving time.
Dealer has been unable to resolve (normally very good dealer service)
whiskywizard is offline   Reply With Quote
Old 03-19-2006, 04:44 PM   #2
DaveFan782
Member#: 90249
2006 WRX Ltd.
SGM
Inherent problem with the throttle on our cars. Subaru NA is working on a fix right now for mine. Take a look at my other threads- hope it helps.
-Dan
DaveFan782 is offline   Reply With Quote
Old 03-20-2006, 01:10 AM   #3
agphotography
Member#: 109729
2007 GTI
Reflex Silver
i have the exact same issue in my '06 wrx wagon.
and i thought i was going crazy
agphotography is offline   Reply With Quote
Old 03-20-2006, 05:26 AM   #4
00Maddog
Member#: 62410
2004 ra'd redrex in
8k w/ STI kit :) DASH
the 04 isn't drive by wire, so in your case check the center wire of the tps sensor and make sure it's .5 volts closed throttle, if it's not adjust it, then reset the ecu. this can cause wierd idle on n/a cars. so can a bad coolant temp sensor, but that usually sets a code.
00Maddog is offline   Reply With Quote
Old 03-20-2006, 09:37 AM   #5
Valhakar
Member#: 39514
2003 WRX 2.5L Hybrid
Mostly Blue
Loosen the cable that routes to the Cruise control box. It is down near the turbo. I loosened mine to have 1/4 inch play in the cable and the issue you described above went away.
Valhakar is offline   Reply With Quote
Hydra Cold fast idle problem Pi7467mp Other Engine Management 18 01-09-2007 11:51 AM
idle problem need help please one wicked wrx Factory 2.0L Turbo Powertrain 2 10-03-2003 04:59 PM
Dealer won't fix my P0304 CEL problem, need advice please! WRXMod Warranty Issues & SOA Problems 5 12-20-2001 06:04 PM
WoW! $1400 bill ... need advice PLease Hitokiri New England Impreza Club Forum -- NESIC 18 05-14-2001 06:10 PM
18" Rim need advice please ChAi Brakes, Steering & Suspension 35 10-25-2000 08:30 PM
Message Board Statistics All times are GMT -4. The time now is 05:34 PM.
