Welcome to the North American Subaru Impreza Owners Club Wednesday January 28, 2015
Old 03-19-2006, 04:21 PM   #1
hail2theTheif
Member#: 42548
2015 Base STi
Black (CBS)
Default not getting any help in the drivetrain forum.....soo
posted this up a couple days ago in the tech forum for transmissions and such but has yielded hardly any help. hopefully someone in here will have an idea.
So the other day my car started making a super weird rattle/grinding/groaning noise from the back driver side wheel(or at least i think thats where it's coming from). The sound is simlar to what a heatshield rattle sounds like but way louder and occasionally you can hear what sounds like metal rattling against the frame of the car.
Noise happens any time when decelling in any gear. Happens accelerating to but can only hear the rattle when switching shifts. Checked the wheel for play in regards to maybe a wheel bearing going out but the wheel had none at all.
sorry for the long post
any help/ideas would be great! thanks!
tyler
hail2theTheif is offline   Reply With Quote
Old 03-19-2006, 05:02 PM   #2
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
you might have a bad axle. look under the car and see if the boots are torn.
another thing you can do is drain you rear diff. fluid into a clean container and see if there are any metal shavings, if there is, it means your rear diff is taking a crap, if not fill the fluid back in.
snowman4us is offline   Reply With Quote
Old 03-20-2006, 09:57 AM   #3
kheff46
Member#: 66739
2002 WRX wagon
if its a light rattle, i think its your heat shield or muffler joint is loose. mine did exactly this to a T! upon decel, between shifts, anytime resonant frequency is achieved basically. otherwise, ive seen a carrier bearing/rubber driveshaft bushing wobble enough to give a similar impression. hope this helps!
kheff46 is offline   Reply With Quote
Old 03-21-2006, 07:25 PM   #4
hail2theTheif
Member#: 42548
2015 Base STi
Black (CBS)
it's def not a light rattle. it pretty much over powers any sound in the car even the stereo a bit. it's more of a vibration. if you are in the back seat you can feel vibrations under your feet.
drained fluid today and no metal shavings so thats nice. could the crappy condition of my brake rotors/pads maybe do this? they are really bad.
Old 03-21-2006, 08:19 PM   #5
kheff46
Member#: 66739
2002 WRX wagon
directly under "their" feet in the back seat. sounds like the rubber stabilizer bushing is beat out and your driveshaft is wobbling while rotating. -keith
What a <<gosh darn bad>> night and not getting any, due to the follwoing. racer98 Off-Topic 7 08-16-2006 02:08 AM
I posted this in the audio forum but did not get much help?? waitandbleed92 Off-Topic 11 06-08-2004 08:48 AM
A technical question that didn't get much feedback in the tech forum... RATyson Off-Topic 15 03-23-2004 12:53 PM
