Old 03-19-2006, 04:21 PM   #1
skieman
Member#: 38952
2004 STi, TXS RFL Ti
Accessport Stage#2
Post Tried to unmarry the AP..now car not working
I tried to unmarry the AP today and it seemed to work but my car doesn't start now. Any ideas?
Have an 04 Sti. Used to have a TBX TBE so I had the AP set at stage 2 93. Ran great. Put stock exhaust back on and tried to revert AP back to stock.
Initialization worked ok. But car doesnt respond to turn over.
- I disconnected green test wires
- I also tried disconnected battery for an hour... no help.
Tried initializing again and it when thrtough process but timedout before it got to 100%... keep saying it was trying again... I finally got impatient and disconnected all. Then tried to start car but nothing.
_ When I plug the AP back in to try reinitializing again it looks as if my ECU has BEEN reset but when i tried reinitiallizing to stock, or stage 1 93 or even back to stage 2, keeps saying error connecting and doesnt initialize
HeLLPPP!!
skieman is offline   Reply With Quote
Old 03-19-2006, 04:37 PM   #2
-Kevlar-
Member#: 82378
did you disconnect the white plug? dont know if you even use it, or if it would help, but i had too. you ecu may be gone if it got interfered with during the process.....
-Kevlar- is offline   Reply With Quote
Old 03-19-2006, 04:44 PM   #3
skieman
Member#: 38952
Accessport Stage#2
Thanks man but there is no white plug required for the AP for STi. The only pieces required for the reflash are the AP's red connector and making sure the green test connctors are attched to each other.
I am worried about damage to the ECU. But bear in mind, before I tried to reflash it again (this was when I interrupted the initilization process because it was hung up "trying again") it seem to have worked when I initially unmarried the AP. (the only problem was that the car didnt turn over.)
Old 03-19-2006, 04:53 PM   #4
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
07 STI 6-Speed Goodness!
Does it go into the "test mode" with the connectors hooked up and the key turned? A idea that sometimes works is to to attempt reflash/unmarry with another vehicle running and jumper cables connected together.
ScoobyNubieToo! is offline   Reply With Quote
Old 03-19-2006, 04:56 PM   #5
skieman
Member#: 38952
Accessport Stage#2
It does go into test mode although the check engine light doesnt flash (as the manual says it should be doing)
Old 03-19-2006, 05:01 PM   #6
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
Try the technique listed above, I think your ECU can be salvaged.
Old 03-19-2006, 05:22 PM   #7
-Kevlar-
Member#: 82378
is this an attempt to save itself if the battery is weak?
Old 03-19-2006, 08:05 PM   #8
skieman
Member#: 38952
Accessport Stage#2
I appreciate the idea and tried it but it didn't work.
After leaving the battery disconnected for a few hours, I attempted your idea.(co0nnected batery to my running truck)
The AP menu display asked me what map I wanted to choose (as if I was initializing for the first time) . Selected stock map and it started to initialize correctly. Then at about 25% it stopped and displayed the following message, "There was a problem with communication. Trying again..." (its worth noting that when it first started initializing almost all dash lights were on..such as the speedo dial.. the tach etc... Then right before it gave this error message, all lights, except for the "red" oil, brake, airbag & r. diff temp went off. So the ones that were still on were only those red lights). So it then just sits there with this message as if its hung up or in a loop. I gave it at least 10 minutes, than I turned the car into off position and pulled the red AP connector.
car still wont start..
With the other car still running and battery still connected I then tried it again. This time the AP gave me a menu as if the AP map had aleady been initialized. I checked the map and it was still reading Stage 2 93 (the map I was starting with!!) and the same red lights were only on. I tried changing the map to stock and this time it never starts initializing. Just says Error try again.
car still won't start.
This is driving me insane. I'm open to any other suggestions. BTW- Anyone know what a new Sti ECU costs? and if dealers typically have then in stock? and how hard they are to install.
Old 03-19-2006, 08:53 PM   #9
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
Sounds like you may have to send the ECU+AP to Cobb. Give them a call tomorrow, they should be able to help you out.
drees is offline   Reply With Quote
Old 03-19-2006, 09:27 PM   #10
Davenow
Member#: 23676
Wow that AP sure seems like a bargain now doesnt it
Anyway, so The reason I am posting is I wanted to know, is Cobb going to replace the ECU that their product screwed up if you cant get this unmarried?
I have firsthand seen an AP refusing to unmarry, and it took 4-5 phonecalls to Cobb to get it working.
Old 03-19-2006, 09:41 PM   #11
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
Dig around here....maybe ya can find some quick help......
http://www.wrxforum.com/cgi-bin/ultimatebb.cgi
Old 03-19-2006, 10:31 PM   #12
dibblejr
Member#: 94070
05 LGT
As COBB Book says, if there is interference or if you disconnect the AP during initialization you may incur an ECU failure and will have to send them to COBB, and I bet there will be some kind of fee involved.
That's why when I am doing an AP flash I turn off all dome lights, stereo and shut the door when doing the flash.
You said you got frustrated and disconnected it when it was hung at 25%, normally on a reflash it will hang at 25% and again at 80% for some time.
Good luck, COBB folks are very friendly.
dibblejr is offline   Reply With Quote
Old 03-20-2006, 03:40 AM   #13
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
I turn off the stereo, the HVAC blower fan, the dome lights, AND i dim the dash lights
nhluhr is offline   Reply With Quote
Old 03-20-2006, 09:38 AM   #14
skieman
Member#: 38952
Accessport Stage#2
Actually, I didn't disconnect it when the % numbers were still on the AP screen. I disconnected it when it changed to read " There was a problem with communication. Trying again..."
Thanks for veryone's suggestions. I've left a message for COBB this morning. Hopefully they can help sort this out. I suspect, as someone commented earlier, that I'll have to send the AP and ECU to COBB.
Now for the ultimate stupid questions ; 1) Where is the ECU in an 04 STi? 2)How easy is it to take out? (pics please..) 3)Any idea what I might expect repair costs to be? 4) How much is a new ECU?Can this only be ordered by a dealer?
Old 03-20-2006, 04:00 PM   #15
drees
Member#: 25905
2003 Silver Wagon
The ECU is under the carpet under the dash on the passenger side of the car. Undo the retainers for the carpet, pull the carpet and and you'll see a few bolts holding the ECU down. Pretty simple, the trickiest part can sometimes be pulling out the carpet fasteners, sometimes they get stuck! Pull harder.
Old 03-20-2006, 04:46 PM   #16
Davenow
Member#: 23676
The dealership where I worked, if we were flashing an ECU, we didnt even run a lift or use a radio within abotu 30 feet of the car. I actually saw an ECU die because someone ran the lift next to the car being flashed...
Old 03-20-2006, 06:41 PM   #17
Jon [in CT]
Member#: 2992
02 WRX Sedan
Yeah, I don't think the Cobb AccessPort User Manual provides enough warnings. Here are the warnings from p. 89 of the Subaru Select Monitor III manual at http://www.subarujtg.com/doc/SSMIII_Application.pdf;
Notes on doing ECM reprogramming
Before starting
  1. Do reprogramming more than 50 m (164 ft) away from high voltage wires.
  2. Do reprogramming more than 10 m (33 ft) away from equipment that might emit high voltage.
  3. Do reprogramming more than 2 m (7 ft) away from equipment that emits electronic noise (such as a vehicle having its ignition checked).
  4. Do reprogramming more than 2 m (7 ft) away from electronic devices that emit radio waves (such as cellular phones or pagers).
  5. Before starting the reprogramming, turn off all the electric equipment (such as the ignition system, audio system, cigarette lighter, or power seats).
  6. Reprogramming automatically turns off if the ambient temperature falls below 0C (32F).
During reprogramming
  1. Do not touch any switches in the vehicle.
  2. Do not touch the pedals, and do not open or close the doors.
  3. Stay near the car
  4. Do not touch the cables or connectors, and do not move the SDI.
Jon [in CT] is offline   Reply With Quote
Old 03-21-2006, 10:42 PM   #18
GotHP?
Member#: 51138
2015 LE STI
Wow, almost identical problem:
http://www.iwsti.com/forums/showthread.php?t=45959
Only difference is in test mode some solenoid on mine is clicking, no fans running, no fuel pump priming. And I can turn the car over fine, just won't catch (likely due to no fuel). Either way the ECU is confused. Being a daily driver I bought a used ECU. If Cobb can save mine, I can always sell it back.
GotHP? is offline   Reply With Quote
Old 03-21-2006, 11:08 PM   #19
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
Great link! Thanks a lot!
Old 03-22-2006, 10:39 AM   #20
skieman
Member#: 38952
Accessport Stage#2
According to COBB, my ECU was "confused". They said they were able to fix ECU and are sending it back to me (with unmarried AP). I'll let you all know if its back to normal later today.
Thanks for all your suggestions!
PS: COBB was very helpful. Good customer service.
Old 03-22-2006, 01:27 PM   #21
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
did you have to pay them for anything?
Bishop is offline   Reply With Quote
Old 03-22-2006, 02:07 PM   #22
skieman
Member#: 38952
Accessport Stage#2
shipping (both ways) and a pretty nominal service fee
Old 03-22-2006, 04:57 PM   #23
GotHP?
Member#: 51138
2015 LE STI
Good to hear, I hope mine turns out so good. I agree Cobb tech support has been good so far.
Old 03-22-2006, 08:59 PM   #24
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
+1 Very happy with COBB's service.
Old 03-22-2006, 10:39 PM   #25
dibblejr
Member#: 94070
05 LGT
Great for you, let us know how it all works out.
Help with unmarrying the AP V1 or not unmarrying it! DJS_02_WRX Newbies & FAQs 12 10-18-2009 10:53 AM
Do you have to unplug the AP when car is off? STI 08 Bahrain AccessPort 2 10-03-2008 06:38 AM
Car totalled, can't unmarry the AP -- what now? perret318 AccessPort 19 10-30-2006 07:10 PM
tried to fix exhaust leak - now car sounds like a beast! anthonyrb98 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-20-2005 11:56 PM
I tried to order the AP for an STI today imprzya Engine Management & Tuning 7 06-08-2004 11:14 AM
