Welcome to the North American Subaru Impreza Owners Club Tuesday December 1, 2015
Old 03-19-2006, 07:39 PM   #1
Member#: 1277
1999 Minnam Stage 2
Cobb Stage3 engine, TEC3
Default The problem with changeing Big Brake Kit in the front and leaving the stock
I'm thinking of installing a Stop tech 355 x 32 mm Big Brake Kit. The problem that concern me is that changeing Big Brake Kit in the front and leaving the stock back is that the brake bias changes too much forward. I'm making a big change in braking force in the front. so that mean front brake force would be a lot grater than the rear? Anyone know how to solve this problem?
ChAi is offline   Reply With Quote
Old 03-19-2006, 07:50 PM   #2
Member#: 1444
Talk to Stoptech. They typically engineer their front BBKs to keep the brake balance the same with stock rear brakes.
ChrisL2 is offline   Reply With Quote
Old 03-19-2006, 07:54 PM   #3
Member#: 17877
Midnight Pearl
Stoptech designs their front BBKs to match the stock rear brakes (they decrease front bias). Give them a call if you're worried.
oldmansan is offline   Reply With Quote
Old 03-19-2006, 10:26 PM   #4
Member#: 25587
2004 Forester XT
In order to match their front stoptech's to the stock rears without changing the brake proportioning system, they would have to ensure that for a given amount of line pressure, the pressure put on the brake pads by the calipers would be similar to the stock brakes...
which means... aside from the improvement over standard sliding calipers, what improvement would this upgrade have over say, the scooby 4 pots ? The only thing I can think of is, fade resistance, but I would think the caliper has less of an impact than say, good brake pads... ?!?!?
twg is offline   Reply With Quote
Old 03-19-2006, 10:31 PM   #5
Member#: 94494
2005 Element 92x
Not necessarily. Stock brakes as well as aftermarket brakes are already front biased. Since so little braking is done in the rears, you can have the brakes in the front much stronger.
I had Stoptech front BBK kit with factory rears, and it felt fine. I've tried 4-pot WRX brakes, and there's no comparison. In fact, I'd say the Stoptech front BBK with factory rears brakes better than STI's with factory Brembo's front and rear. Look at both WRX and STI factory brakes. The front set is always larger than the rear. When Stoptech makes their front kit, sure it makes it more front biased, but research shows the car still stops much better and still has good control.
I did improve my rear, and all it did was make the car not nose dive as much. I added the H6 rotor upgrade, added better pads to the rear, and added SS lines. The car doesn't feel to stop any better, but it stays slightly more balanced. Not enough to be worth it, but I hate looking at the little rear rotors.
keaniegenie is offline   Reply With Quote
Old 03-19-2006, 11:34 PM   #6
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
95 993 C4, 71 911, 04 STI
Quote of the week! And it's only Sunday...
Chai, you're right. As that brake bias chart on Stoptech's site shows, the 355mm fronts are more front biased (same caliper + larger rotor). They don't seem to think it's a problem. In general, ABS on modern cars allows too much front bias will few ill effects. But you should look at rear upgrades to go with the big fronts.
Why the huge kit? The 332x32 wouldn't be adequate? Or do you just want the pie plate look?
Jon Bogert is offline   Reply With Quote
EBC Red Stuff P/N for 03WRX with WILWOOD Big Brake Kit skimobile Brakes, Steering & Suspension 4 05-08-2006 07:13 PM
Rotora Big Brake Kit Front/Rear Combo In Stock and Ready to Ship Spun Autosports Suspension/Brakes/Handling 0 02-02-2006 10:18 AM
Rotora Big brake kits, rotors, Axxis pads and more! autoarttech.com Suspension/Brakes/Handling 13 08-09-2004 03:11 PM
Brembo Big Brake Kits 02+ Wrx Front & Rear vividracing Vendor 'For Sale' Classifieds 16 02-05-2004 08:52 PM
Rotora: Front and rear big brake kit in stock! autoarttech.com Vendor 'For Sale' Classifieds 37 10-17-2003 02:13 PM
