Old 04-29-2012, 03:33 PM   #326
Notorious J
Member#: 248590
02 bugeyewrbwrx
Junior Tuned
just did this entire job on my 02 bugeye friday.
the GBOD's do suck arse and the passenger side is the harder one to remove (counted 9 bolts all facing different directions!). i used a dremel to remove the hose from the drivers side and i will not be putting them back on.
we must have removed and set the injectors 15 times and every time we primed the injectors they leaked. after wanting to push my car off a cliff, we decided to get into another car (thank god there was one) and drive to the nearest auto parts store to find new o-rings (the first store was out so we had to drive another 45 minutes to another one to get them. thank god we were able to find them).
lifted the injectors again, placed the new o rings on and first turn of the key there were ZERO leaks!
we could have avoided 4 hours of unnecessary wrenching if we did not try to re use the old o rings (also the o rings that came on the pinks from the guy i bought them from).
even though you MAY be able to re use the o rings, if i can stress any advise enough here, do yourselves all the favor and learn from my mistakes and get NEW o rings no matter what before you do the injectors!
-jay
Notorious J is offline   Reply With Quote
Old 05-16-2012, 09:39 PM   #327
VERSION7
Member#: 306038
Well duh lol jk im puttin my pinks in this weekend...along with turbo, fuel pump, and turbo inlet. O and replacing the valve covers. Cant wait uggggggg! it wil be well worth it tho
VERSION7 is offline   Reply With Quote
Old 05-17-2012, 12:05 AM   #328
mpen747
Member#: 292343
i didn't put my GBOD back on. i gave up lol
mpen747 is offline   Reply With Quote
Old 05-28-2012, 12:24 AM   #329
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I put GBOD back on driver side - took me 5 min. I didn't bother installing it on passenger side.
Old 06-02-2012, 12:11 PM   #330
BoboTheMonkey
Member#: 224615
2004 WRX
San Remo Red
Did this last week and everything went in pretty easy. The GBOD's are not as hard as I was led to believe. Got them out and Was going to leave some bolts out of the passenger side, but my friend helping me was intent on getting it all together. Had Deatschwerks injectors, so they had all new rings and everything. Forgot about the lube and had just used gas. Everything has been running great and no leaks so far. Basically, have new O-rings and another set available if you need them is what I've gotten out of the issues people have had.
BoboTheMonkey is offline   Reply With Quote
Old 11-25-2012, 02:10 PM   #331
. o 69 o .
Member#: 124938
going to do this right now.. needed to sticky this as im going be running in and out of the house...lol
update. I found I didnt have to remove the tmic. I was only doing the driver side as I had a bad injector. I found if I removed the oil fill tube it gave me access to the front breather bolt and the other 2 I just removed with a 10mm wrench, pretty straight forward, great write up to work from.
Is there any real reason to put that big heavy metal bracket back on?? it only really covers up the fuel rail and holds the wiring harness.
. o 69 o . is offline   Reply With Quote
Old 11-26-2012, 02:10 PM   #332
ogboot
Member#: 170906
psm
That would be the GBOD. Green Bracket of Death. Yes they are a huge pain, most people remove them, I certainly did. Some people state that they would help reduce chances of fire in a collision, but the overwhelming majority of people apparently remove them rather than deal with reinstalling.
ogboot is online now   Reply With Quote
Old 01-11-2013, 09:13 PM   #333
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
For the reason above, I put the GBOD back only on driver side.
Old 01-11-2013, 09:35 PM   #334
jack klompus
Member#: 152885
2014 Malibu LTZ
Never had a problem with the GBOD. Dot see what the big deal is.
(but I still left them off)
jack klompus is offline   Reply With Quote
Old 02-27-2013, 11:59 PM   #335
SubyLarry
Member#: 289426
2002 Impreza WRX
MBP
What does GBOD stand for?
SubyLarry is offline   Reply With Quote
Old 02-28-2013, 12:02 AM   #336
tribalwrx
Member#: 32993
vf39 Best trap 110
Best ET 12.51 Dale tuned
Green Brackets Of Death
tribalwrx is offline   Reply With Quote
Old 02-28-2013, 12:33 AM   #337
jhanso22
Member#: 344582
2003 WRX
Nice write up!
jhanso22 is offline   Reply With Quote
Old 03-16-2013, 07:28 PM   #338
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Thanks - GBOD and U-subframe are parts I have removed for weight savings.
Old 04-10-2013, 02:37 AM   #339
animalcrackers
Member#: 271364
2002 and 2006 WRX
AW - OPB
omg thank you for this
animalcrackers is offline   Reply With Quote
Old 04-10-2013, 09:19 PM   #340
wrx1392
Member#: 342331
2003 wrx
blue
what the heck are these ....i just pulled my motor and did a rebuild ....i dont remember any GBOD i need to do injectors...so i went to the dealer to get the o-rings and grommets.....i lerned my lesson on o-rings when i bought some for the block that was a $1,500.00 mistake...and a LONG STORY.so i bought the o-rings from the dealer .....cost over $100.00 for 8 orings and 4 grommets..some of the o-rings were $13.95 each.dang but dont want more proplems using non oem seals.
wrx1392 is offline   Reply With Quote
Old 06-05-2013, 07:32 PM   #341
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
Good 02-03 WRX injector install post! Thanks
wgr73 is offline   Reply With Quote
Old 06-05-2013, 07:50 PM   #342
jack klompus
Member#: 152885
2014 Malibu LTZ
You can get a big bag of those for $15 from McMaster or Grainger.
Old 06-25-2014, 07:36 PM   #343
massacremasses
Member#: 380004
2005 V7 EJ207 WRX
I wish the pictures still showed up...
massacremasses is offline   Reply With Quote
Old 06-25-2014, 11:16 PM   #344
IheartAWD
Member#: 329962
Could you fix the picture problem =)?
IheartAWD is offline   Reply With Quote
Old 07-08-2014, 02:06 PM   #345
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Let me know if you are still unable to see the pics...
Old 03-06-2015, 11:05 PM   #346
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Picture problem has been fixed.
Old 01-04-2016, 11:19 PM   #347
e85wrxwagon
Member#: 437421
Default fuel leak after blue sti injector install
first post but i might have missed someone talking about this in all of the pages for this. Just did the install on 02 wrx for blue 2015 560cc injectors and there is a fuel leak after the install now that i cannot seem to find. It took 5 ish times to get the injectors not to leak. It seems to not be coming from the injectors and after i start the car, smoke begins to come out of the up pipe area and the car runs a bit weird but from what i remember close to normal. I do have a base tune from a tuner already loaded on. The passenger side fuel rail does make a weird sound when i prime the fuel pump. I have a feeling the problem is some hose or connection to the fuel rail since i was moving around the fuel rail to replace the injectors. If anyone has had a problem similar to this or knows anything about this any help would be appreciated.
thanks
update: Problem is fixed
e85wrxwagon is offline   Reply With Quote
JDM v7 STi TMIC Install on 02-03 ThePunisherGT Newbies & FAQs 13 02-09-2016 02:04 PM
how to install oem front lip on 02-03 wrx theo79 Interior & Exterior Modification 2 01-23-2008 01:33 PM
injectors install on a 2005 wrx spyda23 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 05-31-2007 10:47 AM
Pink replica strut bar 02-03 wrx fluxcapacitor Private 'For Sale' Classifieds 8 05-08-2006 02:10 PM
04 wrx springs on 02/03 wrx struts/tophats spdracr00 Brakes, Steering & Suspension 2 03-03-2006 12:53 PM
