Old 04-16-2006, 11:09 PM   #51
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
What did you do with the pipe on passenger's side GBOD?
Old 04-17-2006, 10:38 AM   #52
gizmodude311
Member#: 71856
2002 psmWRX wagoneer
COBB VF39, v7 STI susp
when we order a set of pinks (new or used), besides the actual injectors, we just need the 8mm or 7mm rings for the install? I just don't want to have my engine apart and missing parts to re-assemble... i've made that mistake before and trying to avoid it...
gizmodude311 is offline   Reply With Quote
Old 04-17-2006, 08:25 PM   #53
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Most of the times, you should be able to reuse existing ones from stock injectors. Best thing is to get new OEM o-rings from either suby dealer or from another member here. PM Benw now
Old 04-17-2006, 08:28 PM   #54
mexicanpizza
Member#: 16779
2008 God's Gift to
Turbo Wagons (MS3)
mexicanpizza is offline   Reply With Quote
Old 04-17-2006, 08:31 PM   #55
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I find it easier to put driver's side GBOD back on than cutting it.
Old 04-17-2006, 08:31 PM   #56
prometheum
Member#: 92003
04 bicycle!
http://www.mcmaster.com/ part number 9263K167 ftw
prometheum is offline   Reply With Quote
Old 04-17-2006, 08:34 PM   #57
mexicanpizza
Member#: 16779
2008 God's Gift to
Turbo Wagons (MS3)
Probably, but I figured I'd maintain symmetry with my lack of GBOD.
Old 04-26-2006, 06:13 AM   #58
ASpec818
Member#: 37059
03 WRX
World Rally Blue
does anyone know if injectors require cleaning? I bought a set of used sti pink injectors and was wondering ifit would be neccesary.
ASpec818 is offline   Reply With Quote
Old 04-26-2006, 06:14 AM   #59
ASpec818
Member#: 37059
03 WRX
World Rally Blue
also what the hell is a GBOD. what does it stand for?
Old 04-26-2006, 06:44 AM   #60
GDR
Member#: 34924
03 WRX Wagon
81 Scirocco S
They have been called the "Green brackets of Death". Don't know if GBOD has a real meaning or not.
GDR is offline   Reply With Quote
Old 04-26-2006, 04:27 PM   #61
gaby
Member#: 94097
2004 WRX Hybrid GT35
[email protected]
NO need to clean them. I just installed mine they work perfect.
gaby is offline   Reply With Quote
Old 04-26-2006, 05:10 PM   #62
benw
Member#: 103320
1998 swapped
Forester L
I still have o-rings, PM me if you need some.
benw is offline   Reply With Quote
Old 04-30-2006, 09:54 AM   #63
prspect06
Member#: 33223
2003 '03 WRX Vf39
blue pearl
Can anyone give a better description of how to lube the o-rings.
Also, can someone give me a better idea of how to remove and re-install the injectors?
Do you just remove bolts for the fuel line, then remove the electrical connectors, and then pull the injectors up? After removing the stockers, do I then just drop the new one in?
Is the injectors only held to the block by the fuel line?
What's up with this injector with the black thingy on the tip that the other injectors don't have on?
prspect06 is offline   Reply With Quote
Old 04-30-2006, 11:44 AM   #64
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Please ignore that pic with black thingy on the tip. I bought them as is. As for reinstalling injectors, steps you described are correct. Simply pull up the fuel rail and create enough space to remove and install injectors. It's pretty simple.
I just used my finger to transfer regular 93 octane gasoline onto the o-ring.
Old 04-30-2006, 08:33 PM   #65
prometheum
Member#: 92003
04 bicycle!
injectors are held on by the fuel rail, just unbolt them and pull up on the fuel rail injectors will probably come up with the fuel rail.
installing them, just do the same in reverse. put some vaseline on the o-rings and push them up into the fuel rail then move the fuel rail into position
Old 05-01-2006, 03:14 AM   #66
benw
Member#: 103320
1998 swapped
Forester L
This might make things easier to explain:
not shown: 3 bolts securing fuel rail and hardlines to intake manifold. remove these, and the rail will pull the injectors out of their holes in the manifold.
pop out the injectors from the rail (thin rubber o-rings hold injectors in rails).
the isolators are thick rubber, I used motor oil. new o-rings lubed in gas, pop them into the rail first. second, lower the rail and injectors into the holes in the manifold. secure the lines/rails to the manifold with 3 bolts.
Old 05-01-2006, 12:49 PM   #67
prspect06
Member#: 33223
2003 '03 WRX Vf39
blue pearl
Great diagram. So the injectors are attached to the fuel line. That's why we need to pull on the fuel line that removes the injectors with it.
Do I then just yank the injectors out of the fuel line?
And when using gas to lubricate the o-ring, do I put gas on the o-ring by itself or with it on the injector? How much gas do I use?
Thanks
Old 05-01-2006, 02:13 PM   #68
kunfuzion
Member#: 1094
'85 Levin Hatch
color of rust
great write up.
kunfuzion is offline   Reply With Quote
Old 05-01-2006, 02:16 PM   #69
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Thanks
Yes, just yank the injectors out of the fuel line (GENTLY). Make sure not to damage injector head (spray side) when pulling it out as they can easily be damaged.
I just used a very small amount, barely enough to lubricate o-rings.
Old 05-01-2006, 03:22 PM   #70
prspect06
Member#: 33223
2003 '03 WRX Vf39
blue pearl
I know that gas evaporates quickly...so I should lubricate them right before reinserting them into the fuel lines?
Old 05-01-2006, 03:47 PM   #71
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
It doesn't evaporate that quickly, so you should be ok if you apply o-rings before reinserting them into the fuel rail.
Old 05-01-2006, 04:13 PM   #72
MF-DIF
Member#: 62197
2002 PSM WRX
LG/Blurple FZ-09
DO NOT put the GBOD back in!
I went back to stock inj over the weekend, and it only took about 30 mins to swap them out with the GBOD missing.
MF-DIF is offline   Reply With Quote
Old 05-01-2006, 04:27 PM   #73
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
agreed, throw those things FAR away..
djerickd is offline   Reply With Quote
Old 05-01-2006, 04:40 PM   #74
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Throw them away and you will be searching for them next year when you are upgrading to STi
They may provide some protection in case of an accident too.
Old 05-01-2006, 05:26 PM   #75
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
huh? they should have never come on the car...
JDM v7 STi TMIC Install on 02-03 ThePunisherGT Newbies & FAQs 13 02-09-2016 02:04 PM
how to install oem front lip on 02-03 wrx theo79 Interior & Exterior Modification 2 01-23-2008 01:33 PM
injectors install on a 2005 wrx spyda23 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 05-31-2007 10:47 AM
Pink replica strut bar 02-03 wrx fluxcapacitor Private 'For Sale' Classifieds 8 05-08-2006 02:10 PM
04 wrx springs on 02/03 wrx struts/tophats spdracr00 Brakes, Steering & Suspension 2 03-03-2006 12:53 PM
