Old 05-20-2006, 06:05 AM   #101
prspect06
Member#: 33223
2003 '03 WRX Vf39
blue pearl
Originally Posted by benw
mine werent "dangling" so much as just not attached super firm, I omitted the circular bracket hold-down and it's been fine.
ok, not so much dangling, but the GBOD gave it a great deal of support. I'm sure while driving they are vibrating quite a bit.
prspect06 is offline   Reply With Quote
Old 06-11-2006, 04:40 AM   #102
prspect06
Member#: 33223
2003 '03 WRX Vf39
blue pearl
I'm having a hard time making the injectors click when inserting it into the fuel rail. Do the injectors only go on one way?
i'm pulling for the life of me and still no click. Should it be really audible and noticeable?
Old 06-11-2006, 05:18 AM   #103
prspect06
Member#: 33223
2003 '03 WRX Vf39
blue pearl
I just put them in with no click. I hope all turns out well. Are they supposed to be able to spin while secure attached to fuel line and engine block?
Old 06-11-2006, 08:10 AM   #104
dibblejr
Member#: 94070
05 LGT
When I installed mine only heard 1 sort of click. As long as you pull up as hard as you can and you use new orings you will be ok.
Yes they will turn.
dibblejr is offline   Reply With Quote
Old 06-11-2006, 11:37 AM   #105
prspect06
Member#: 33223
2003 '03 WRX Vf39
blue pearl
thanks!
Should I just prime the fuel pump after I'm done without starting it up? Do I just get a flash light and look at the injectors for leaks?
Old 06-11-2006, 03:37 PM   #106
dibblejr
Member#: 94070
05 LGT
as soon as you start it you will know if it leaks. Usually it will spray if they leak. Flashlight is safer than a drop light for this. If you discover leak turn off engine, wont take long to start a fire.
Old 06-22-2006, 10:46 PM   #107
kcook
Member#: 78074
2005 STi
i have to install injectors in about 2 weeks when i put my new setup in... im scared to do this lol
kcook is offline   Reply With Quote
Old 06-22-2006, 11:26 PM   #108
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
don't worry... you can do it in 2 hours.
Old 06-23-2006, 09:19 AM   #109
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
Originally Posted by txl146
I am glad to see more WRXs are turning into stage 4.
... i've been stage 4 for over a year, and never swapped injectors.
Old 10-01-2006, 08:36 PM   #110
Matth3w
Member#: 94597
2003 Corvette Z06
Black/Black
can you explain the clicking and pulling in a little more detail for me?
Matth3w is offline   Reply With Quote
Old 10-01-2006, 08:59 PM   #111
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Basically, you align injectors carefully into fuel rails and pull it UP gently until you feel a "click". It is indicative of good seal. Before putting brackets back on, turn on the engine and visually check for fuel leak.
Old 10-01-2006, 09:12 PM   #112
Matth3w
Member#: 94597
2003 Corvette Z06
Black/Black
okey thanks...wondering if i should prepurchase some orings...i have about 10k miles on my car...
Old 10-01-2006, 09:32 PM   #113
dibblejr
Member#: 94070
05 LGT
Anytime you pull the injectors off it is best to replace the o-rings. If you did that you would not be mad about your fuel leak.
Jay-R
Old 10-01-2006, 09:33 PM   #114
Matth3w
Member#: 94597
2003 Corvette Z06
Black/Black
right on then
Old 10-02-2006, 11:40 AM   #115
sube-trex
Member#: 97577
2001 IS 300
umm. ill pay someone for that
sube-trex is offline   Reply With Quote
Old 10-02-2006, 11:56 AM   #116
TheMadScientist
Member#: 23717
2005 Big red
Jay-R
It is a good idea, but not needed as long as the O-rings are in good shape. The biggest mistake I see when people install the injector is not using lube. When you try to insert the injector dry most of the time you end up folding the o-ring over and causing a leak. FUEL IS NOT A LUBE. Use a small amount of WD40, ZEP45, motor oil, anything as long as it won't eat the o-ring. IMO stay away from PB blaster as it is not a lube but a penetrating oil and is very hard on plastic and rubber.
TMS
TheMadScientist is offline   Reply With Quote
Old 10-06-2006, 07:46 PM   #117
Vince126
Member#: 91712
2006 Evolution IX
Wicked White
errgh i just spent 3 hours trying to install pinks, and i only manage to get the driver side done. the passenger side is giving me a lot of headache. i managed to removed all of the 12mm bolts on the GBOD except the one behind the breather box thing. i cant get my ratchet's socket on it enough to be able to turn it, and my wrenches are a little too short...any ideas?
Vince126 is offline   Reply With Quote
Old 10-06-2006, 08:00 PM   #118
dibblejr
Member#: 94070
05 LGT
It is a very tight squeeze. I used a very old japanese Nissan tool kit that was in my skyline gtr, it helped to cuss and talk to it.
You could use a dremel and cut it off. I left both of the GBOD's off.
Good luck
Jay-R
Old 10-06-2006, 08:04 PM   #119
Vince126
Member#: 91712
2006 Evolution IX
Wicked White
thanks for the quick response i guess im in luck my gf just bought my a dremel yesterday!
Old 10-06-2006, 08:15 PM   #120
dibblejr
Member#: 94070
05 LGT
Your welcome, once you cut it off you will have room to get the extra piece off.
Hopefully you did your homework before the install and got new o-rings, do not reuse the old ones. Not worth the time it takes to change them out in case of a leak.
They cost pennies, soak them in gas before install.
Once you get past the GBOD you are home free.
Jay-R
Old 01-03-2007, 01:13 AM   #121
daveyboy
Member#: 35419
I just installed brand new pinks so I thought I would chime in. The larger o-rings that seals against the fuel rail leaked on both of my driver side injectors. I don't know if the o-rings were bad. It could have been that I pulled up on the injectors too forcifully (they didn't "snap" in like the passenger side) and I deformed them. I resused the old o-rings and just turned the key to "on" to kick on the fuel pump--they didn't leak yet.
daveyboy is offline   Reply With Quote
Old 04-09-2007, 02:29 PM   #122
Mooneyes13
Member#: 113666
60' all over you
in for this info
Mooneyes13 is offline   Reply With Quote
Old 04-09-2007, 05:40 PM   #123
dibblejr
Member#: 94070
05 LGT
The entire install is very simple, the thing that shoots you in the foot is trying to reuse the o-rings. Never attempt to do the injetor install without a set of new o-rings. They cost pennies and if you have a problem and your old ones leak your car will be down for at least a few days when you order them.
Jay-R
Old 04-09-2007, 08:54 PM   #124
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
dibblejr, good point.
Old 04-10-2007, 06:30 PM   #125
sonic03rex
Member#: 40534
2016 WRX
wow, would have been nice to have a writeup like this when I installed the pinks in my old 03. Started the instiall at 6pm, with some breaks in between, I didn't finish untill almost 2am thanks to no light and the GBOD!
Good work on the pics/instructions!
sonic03rex is offline   Reply With Quote
JDM v7 STi TMIC Install on 02-03 ThePunisherGT Newbies & FAQs 13 02-09-2016 03:04 PM
how to install oem front lip on 02-03 wrx theo79 Interior & Exterior Modification 2 01-23-2008 02:33 PM
injectors install on a 2005 wrx spyda23 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 05-31-2007 11:47 AM
Pink replica strut bar 02-03 wrx fluxcapacitor Private 'For Sale' Classifieds 8 05-08-2006 03:10 PM
04 wrx springs on 02/03 wrx struts/tophats spdracr00 Brakes, Steering & Suspension 2 03-03-2006 01:53 PM
