Old 04-10-2007, 06:29 PM   #126
benw
Member#: 103320
1998 swapped
Forester L
I tell ya, after you do one set, it's a breeze. We removed/reinstalled a set on a friends car including GBODs and it took an hour.
You can re-use o-rings if they are immaculate. The problem is, they usually aren't, and they are partially torn or marred from the removal process.
The big isolators are always almost fine to re-use. It's just the o-ring that seals in the fuel rail that is the problem.
benw is offline   Reply With Quote
Old 04-10-2007, 06:59 PM   #127
dibblejr
Member#: 94070
05 LGT
^^ I had 100 miles on my wagon and I tried to reuse the o-rings, 3 days later after ordering the o-rings I finally got the car running.
It is never worth the risk to reuse any o-rings or any gaskets in the exhaust sytem pre-turbo. Time is woth more $ then $.05-20.00 in simple parts.
Jay-R
dibblejr is offline   Reply With Quote
Old 04-10-2007, 07:14 PM   #128
sharkmonkey
Member#: 118566
2005 WRX
So if you can use "side feed" injectors in a "top feed" setup, what's the point in even making a distinction if they just pop right in?
sharkmonkey is offline   Reply With Quote
Old 04-10-2007, 07:21 PM   #129
dibblejr
Member#: 94070
05 LGT
You do not want to use side feed injectors in a top feed car they will not seal correctly. Even most AM fuel rails are injector specific.
Jay-R
Old 04-10-2007, 08:38 PM   #130
. M i c h a e l
Member#: 108647
2002 Impreza WRX
Midnight Black Pearl
i'm assuming this write up is the same for an 04 as well?
. M i c h a e l is offline   Reply With Quote
Old 04-10-2007, 08:51 PM   #131
dibblejr
Member#: 94070
05 LGT
Yes you are correct
Old 04-10-2007, 08:54 PM   #132
motoryder
Member#: 111268
.... MLTMFA2
Yes sir.
Last edited by motoryder; 04-10-2007 at 08:55 PM. Reason: haha....dibble beat me to it...damn distractions
motoryder is offline   Reply With Quote
Old 04-10-2007, 10:53 PM   #133
Ottawagon
Member#: 87068
04 WRX Wagon
Jay-R
Noob question here...
Where do you get the o-rings from? Are they a standard size that you can pick up from a hardware store or plumbing dept. or do you get them from either a suby dealer or automotive parts store?
Ottawagon is offline   Reply With Quote
Old 04-11-2007, 11:53 AM   #134
dibblejr
Member#: 94070
05 LGT
Mcmasster carr http://www.mcmaster.com I will post the part # when I find my bag. I paid like $8 for 50 if I recall. I sent a lot of members free o-rings so I dont have any left.
Jay-R
Old 04-11-2007, 12:29 PM   #135
Ottawagon
Member#: 87068
04 WRX Wagon
Jay-R
Cool, thanks! Are they automotive specific (like to handle heat and fuel), or just regular o-rings?
Old 04-11-2007, 12:42 PM   #136
dibblejr
Member#: 94070
05 LGT
mcmaster.com the 8mm ID by 2mm thick o-rings exact match. Part #9263K169. Made out of Viton which are the oil/gas resistant kind.
Jay-R
Old 04-17-2007, 09:59 AM   #137
Ottawagon
Member#: 87068
04 WRX Wagon
Jay-R
Found a local shop who got me a bag of 20 of the viton ones in this size for around 50cents each. Thanks for the info!
Next question: should I order the bigger rubber isolater things too just in case? Anyone have a part number or size for these? And is there a specific type of rubber used that I need to specify when ordering?
Thanks!
Old 04-17-2007, 10:19 AM   #138
dibblejr
Member#: 94070
05 LGT
^^ The isolaters should be fine, probably no need to order. They just slide on and off the incectors.
Old 04-17-2007, 10:48 AM   #139
TheMadScientist
Member#: 23717
2005 Big red
Just flip them over when you install the new injectors.
TMS
TheMadScientist is offline   Reply With Quote
Old 04-20-2007, 12:13 PM   #140
Ottawagon
Member#: 87068
04 WRX Wagon
Originally Posted by benw View Post
This might make things easier to explain:
not shown: 3 bolts securing fuel rail and hardlines to intake manifold. remove these, and the rail will pull the injectors out of their holes in the manifold.
pop out the injectors from the rail (thin rubber o-rings hold injectors in rails).
the isolators are thick rubber, I used motor oil. new o-rings lubed in gas, pop them into the rail first. second, lower the rail and injectors into the holes in the manifold. secure the lines/rails to the manifold with 3 bolts.
Just to be clear, are there 3 rubber bits on each sti pink injector?
I just looked at the used ones I got, and they each have the small o-ring at the top (the side opposite where the fuel sprays out), and they have the rubber isolater below that. But that is all.
Is there a 3rd o-ring or rubber isolater bit that is supposed to be near the bottom?
I can't take my stockers out for reference just yet - I want to make sure I have any parts I might need on hand before I do the install! Thanks.
Old 04-20-2007, 12:19 PM   #141
slowmike
Member#: 24890
2002 Jackwagon
WRB GG
Great instructions, but i think people make this job sound a lot harder than it actually is.
slowmike is offline   Reply With Quote
Old 04-20-2007, 12:22 PM   #142
subynooby
Member#: 145926
2004 WRX STI
im such a noob at install
subynooby is offline   Reply With Quote
Old 04-20-2007, 04:45 PM   #143
dibblejr
Member#: 94070
05 LGT
Correct, everyone is over thinking this. Just get new o-rings and reuse all the other rubber. Keep it simple.
Jay-R
Old 04-20-2007, 05:31 PM   #144
paintbing
Member#: 59388
2003 WRX - Hybrid
I do my own stunts
Get new o-rings.
I did my install and re-used the orings, and when I started the car, fuel just poured like crazy onto the shop floor. I had to tear the freakin' beast apart again to replace them all. Not fun!
paintbing is offline   Reply With Quote
Old 04-20-2007, 05:38 PM   #145
dibblejr
Member#: 94070
05 LGT
^^ If you do not put the GBOD's back on you can change all injectors in less than 30 minutes.
Jay-R
Old 04-29-2007, 06:57 PM   #146
. M i c h a e l
Member#: 108647
2002 Impreza WRX
anyone have four they want to mail me? i figure i'd ask before i order 25 off of mcmasters
Old 07-14-2007, 07:35 PM   #147
Chizmo
Member#: 135335
2006 impreza 2.5i
Black wagon
Saw that you removed a coolant reservior tank to get to the passenger side. Did you drain your coolant prior to this install??
Chizmo is offline   Reply With Quote
Old 07-14-2007, 08:00 PM   #148
dibblejr
Member#: 94070
05 LGT
^^ You have to remove or just move out of the way the widow wash fluid tank. Not the coolant resevoir.
Jay-R
Old 07-14-2007, 10:15 PM   #149
Chizmo
Member#: 135335
2006 impreza 2.5i
Black wagon
Remove a coolant reservior tank:
Just wasn't sure about this step, from the shot angle it almost looks like the actual tank part of this coolant reservior was removed. But I'm assuming now that it's all still intact???
Old 07-15-2007, 12:43 AM   #150
dibblejr
Member#: 94070
05 LGT
Thats the turbo coolant resevoir and I never remove it to install injectors. If you need to for some reason just swing it out of the way.
Jay-R
JDM v7 STi TMIC Install on 02-03 ThePunisherGT Newbies & FAQs 13 02-09-2016 02:04 PM
how to install oem front lip on 02-03 wrx theo79 Interior & Exterior Modification 2 01-23-2008 01:33 PM
injectors install on a 2005 wrx spyda23 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 05-31-2007 10:47 AM
Pink replica strut bar 02-03 wrx fluxcapacitor Private 'For Sale' Classifieds 8 05-08-2006 02:10 PM
04 wrx springs on 02/03 wrx struts/tophats spdracr00 Brakes, Steering & Suspension 2 03-03-2006 12:53 PM
