Old 07-15-2007, 01:13 AM   #151
TheShad0w
Member#: 91925
2005 CGM WRX
Owner of AWDTuning.com
Originally Posted by dibblejr View Post
^^ If you do not put the GBOD's back on you can change all injectors in less than 30 minutes.
Jay-R
Thats a good point... what purpose do they actually serve?
TheShad0w is offline   Reply With Quote
Old 07-15-2007, 02:30 AM   #152
gopsu
Member#: 96448
02 WRX VF34
maybe protect fuel from leaking during collison? I just put the driver's side GBOD on... it took me 5 min to do it.
gopsu is offline   Reply With Quote
Old 08-01-2007, 09:13 PM   #153
jack klompus
Member#: 152885
05 wagon 16g-xt
E85 6speed 350/330
thanks for the how-to OP. I just did mine. I'm doing a 39 swap in a couple weeks and this will save a few hours for me.
jack klompus is online now   Reply With Quote
Old 08-01-2007, 09:23 PM   #154
scott*impreza
Member#: 155565
2006 WRX STi
Wow, that was a great photo walk through, nice work
scott*impreza is offline   Reply With Quote
Old 08-02-2007, 02:17 AM   #155
gummy
Member#: 99551
2004 WRX
bluey
good thread, i used this and there were no flaws
gummy is offline   Reply With Quote
Old 08-05-2007, 05:05 PM   #156
WeldingHank
Member#: 98645
2002 WRX Wagon
I will add to this. I just finished an install of modded stocker. If your not doing the turbo. you don't need to remove the TMIC. I have a huge EBAY TMIC and it did not get in the way at all.
WeldingHank is offline   Reply With Quote
Old 08-07-2007, 10:33 PM   #157
PhastEddie
Member#: 136545
2006 Evolution IX
I did the GBOD removal along with my injectors last week. An easy way to get that hose off of the bracket is to take a large screwdriver and stick it in between where the hose bracket is welded to the GBOD, and then pound away and eventually you will break the weld cleanly. To you guys that went with pinks, I ordered new insulators from the dealer but it doesnt seem to be the same as the ones that were on there. The originals were tapered where this one just doesnt seem to fit correctly. Anyone notice this?
PhastEddie is offline   Reply With Quote
Old 08-08-2007, 02:06 PM   #158
Paulys05wrx
Member#: 82433
2005 In the works..
Just finished the install... I turned the car on and one injector was leaking. I pulled it out and found that it didnt have the bottom insulator on. I put the stock insulator on this one and bolted the fuel line back. I got them from deatschwerks and all the others didnt leak but i dont think they have the bottom insulator. Will i be fine with the others not having the insulator?? It is not leaking now.
Thanks
Paulys05wrx is offline   Reply With Quote
Old 08-09-2007, 10:41 PM   #159
PhastEddie
Member#: 136545
2006 Evolution IX
Thanks
You definitely need the bottom insulator, otherwise you will leak air under boost. I was just at the tuner twice and was not able to get my car tuned because my insulators were leaking air during the pressure test. Talk about pissed. I even cleaned, lubed, and reused them. They appeared visually fine, but still no dice. A friend had a new set of insulators for an 03wrx which is what I have, but it doesnt seem to taper like the ones that came with my pinks. Does anyone know if these are the right ones? And when installing, do you put the insulators in the slots and then the injectors or do you stick it on the injector before installing them?
Old 04-04-2008, 12:09 AM   #160
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
bump for newbies looking to install injectors...
Old 04-04-2008, 01:49 PM   #161
ogboot
Member#: 170906
psm
Thx for the bump /subscribed
ogboot is offline   Reply With Quote
Old 04-04-2008, 02:25 PM   #162
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
I did mine with a friend not too long ago. I though the most difficult bolt was circled in the pic below. I did not put this one back on and the cover is solid. The reason is that on the 04 WRX wagon, there is a slight bulge on the surrounding material that prohibits a socket from sitting well on there.
tazswing is offline   Reply With Quote
Old 04-18-2008, 11:51 PM   #163
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I did not put passenger side GBOD back on either. Putting driver side GBOD back on was much easier.
Old 04-29-2008, 04:28 PM   #164
DriftinS14
Member#: 52110
02 DB Monster 16G
06 blk on blk Revo'd A3
The GBOD's are to prevent your fuel bits from being smashed from a front end collison and leaking fuel and starting a fire. Its rare for a car to have its injectors 2" away from the main frame rails like ours. I would NEVER drive these cars without these installed. Think about it!
DriftinS14 is offline   Reply With Quote
Old 05-04-2008, 01:24 PM   #165
Psipwrd
Member#: 102746
1992 Celica GT-4 CS
I did this yesterday, don't think I could hear or feel the "click" and the two forward injectors leaked. Like someone else said, the stock bottom insulator fit better than the new ones so I reused them. I'm about to go do it all again!
Also someone mentioned the injector should be able to spin once installed. It should not because there's a groove it should fit into, with the forward injector's harness facing forward and the rear/aft harness facing the rear.
Psipwrd is offline   Reply With Quote
Old 05-14-2008, 12:06 AM   #166
cquirki
Member#: 171466
02 WRX
Built 2.5 6speed
just did this with some modded 750s... sucked. so difficult with sti version 8 heads. avcs on BOTH sides blocks so crucial screws completly. i suggest ratcheting WRENCHES and sockets
cquirki is offline   Reply With Quote
Old 05-18-2008, 03:05 AM   #167
AntiZeroTrip
Member#: 152827
2003 WRX
Sonic Yellow
+1.
ones with a swivel head would also be very useful.
my fingers hurt and my hands are covered in grease, but the damn injectors are in and bolted down,... now, to see if they leak.....
*crosses fingers*
AntiZeroTrip is offline   Reply With Quote
Old 05-18-2008, 03:06 AM   #168
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Good luck!
Old 05-18-2008, 03:26 AM   #169
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
here is a great link to finding inexpensive o-rings ($1.50 for 10 viton o-rings):
http://forums.nasioc.com/forums/show...smallparts.com
Thanks Polaris
Old 05-29-2008, 10:26 AM   #170
WRXislander
Member#: 50064
'02 WRX
MBP
Let's BUMP this beast for anyone who wants to put in more advice. I just did my STI TMIC, fuel pump, and turbo inlet. I'm sort of treading water until I have a free day to do the injectors and vf39. The turbo I'm not sweating but staring at these pinks in front of me gives me heartburn.
WRXislander is offline   Reply With Quote
Old 05-29-2008, 12:23 PM   #171
snubie
Member#: 138182
2005 WRX Wagon
psm
I just did this and the GB'sOD were'nt that bad. The driverside was alot easier to put back on after removing the breather cover. I was horrified by the thought of doing this but after I did it it really wasn't that bad. The "tough to reach" bolt on the passenger side bracket was pretty easy with an angled racheting wrench.
To the OP, Good write-up. It helped me out alot to read it before doing mine, thanks.
snubie is offline   Reply With Quote
Old 05-30-2008, 12:23 AM   #172
Swine
Member#: 16197
2005 OBP LGT
99 WR400 SuMo
subscribe.
Swine is offline   Reply With Quote
Old 06-19-2008, 03:03 PM   #173
ptirmal
Member#: 82243
07' Acura TL-S
11' Ducati Monster 796
Just wanted to share what happens if you don't properly lube o-rings/ insulators...
Installed over a year ago I noticed a leak and had to have the car towed a few days ago. The o-rings were lubed in motor oil when installed, same as the top insulators. I'm not using motor oil this time - even though others have had no problems with it, it is not a proper lubricant for them.
The other side was done with petroleum jelly and it's been fine.
ptirmal is offline   Reply With Quote
Old 06-19-2008, 07:08 PM   #174
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
if i were you, i'd replace that side too.
Old 06-19-2008, 07:23 PM   #175
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Thanks for the pictures.
how to install oem front lip on 02-03 wrx theo79 Interior & Exterior Modification 2 01-23-2008 01:33 PM
JDM v7 STi TMIC Install on 02-03 ThePunisherGT Newbies & FAQs 12 12-13-2007 08:07 AM
injectors install on a 2005 wrx spyda23 Factory 2.0L Turbo Powertrain 8 05-31-2007 10:47 AM
Pink replica strut bar 02-03 wrx fluxcapacitor Private 'For Sale' Classifieds 8 05-08-2006 02:10 PM
04 wrx springs on 02/03 wrx struts/tophats spdracr00 Brakes, Steering & Suspension 2 03-03-2006 12:53 PM
Message Board Statistics All times are GMT -4. The time now is 06:27 AM.
