Old 03-20-2006, 10:45 AM   #1
Jpizzzle
Member#: 95492
2003 WRX with STI
goodies >:)
Default ap question
i have stage two right now with exhaust, can i put an intake on or would that throw the computer off? would i have to get a special tune from cobb?
Jpizzzle is offline   Reply With Quote
Old 03-20-2006, 11:01 AM   #2
-Kevlar-
Member#: 82378
hmmmm ok.... did you read about the product and what mods you can do? it says STOCK INTAKE... but ill tell you, you can do it with a protune...
-Kevlar- is offline   Reply With Quote
Old 03-20-2006, 11:04 AM   #3
Jpizzzle
Member#: 95492
2003 WRX with STI
goodies >:)
yea i read it, but i wasnt sure if you added something else if it would throw off the ecu or screw some stuff up...and doesnt cobb do special maps on request?
Old 03-20-2006, 11:17 AM   #4
-Kevlar-
Member#: 82378
no but pdx does. and like i said you can get a protune...
Old 03-20-2006, 02:11 PM   #5
kevin2.5rs
Member#: 67518
2013 Focus ST
TB
Jpizzzlei have stage two right now with exhaust, can i put an intake on or would that throw the computer off? would i have to get a special tune from cobb?
You can use cobb intake (waste of money) & works with AP maps or
Take off the silencer in the fender. You get the pshhhit sound & ITS FREE
DO IT
kevin2.5rs is offline   Reply With Quote
Old 03-22-2006, 01:50 PM   #6
Jpizzzle
Member#: 95492
2003 WRX with STI
goodies >:)
what about a header? if i did something like that which they dont mention on their website what would happen? or is it as long as i have turbo back exhaust and stock intake and injectors i can use ap stg 2 with some headers? because they do not specify about having stock manifold
Old 03-23-2006, 08:29 AM   #7
kevin2.5rs
Member#: 67518
2013 Focus ST
TB
Headers are not mentioned because theses no point with those power levels
Headers would benifit along with a turbo, injectors, pump & a protune
Old 03-23-2006, 09:06 AM   #8
-Kevlar-
Member#: 82378
what they say you can have, you can have. if its not listed then no. very simple. the only things that might not be listed is y pipe and uppipe.
Old 03-23-2006, 05:24 PM   #9
Jasvboost
Member#: 37160
RIP 04 Stg2 JBP WRX
07 SWP WRX 335/350 HTA68!
Default AccessPORT - Frequently Asked Questions (FAQ)
Q. I have XYZ intake, do you have a map for it?
A. We can do mapping for quite a few intakes that are predictable. We have maps for the original(black) APS, Injen, and most of the short ram hot air intakes. The Blitz is about the only short ram that is not predictable. The car may not be as smooth or might miss out on some power since we have to tune even more conservatively with most of the intakes, but it will be safe, and run better than the factory ECU. Also, let us know what specific intake you have. We have had people order the map for the APS intake when in reality they had other intakes. Needless to say the tune was far from optimal. So far the AEM is about the only intake we have seen that is not predictable. We could make a map for it that would make sure that the car runs rich rather than lean, but the benefits would be far less than that if the customer just removed the intake and used the factory unit. We even have to do that on the dyno for the AEM intake. Also, even if the intake is advertised as not needing correction, causing no errors, or factory specifications, let us know. This is not the case on the intakes that we have tuned that make this claim, they do require correction. Just because the piping that the sensor sits in is the exact factory spec does not mean that there is no turbulence to throw the sensor off. In the end if you want the smoothest running car use the factory air box. If you want the noise and slightly better spool-up, remove the silencer in the fenderwell and toss a panel filter in the stock air-box. On the stock turbo you will make the same power as you will with an aftermarket intake. If you have any questions or want to get the best map, your best bet is to give us the most information you can and let us choose the proper map for your combo.
Q. I have an up-pipe, and/or intercooler hoses, and/or a panel filter, and/or a BOV, and/or pulleys, etc. but I donít see a map with those mods. What can I do?
A. Those types of modifications are within the AccessECUís ability to adapt. Most of them (with the exception of the BOV) make a slight improvement in efficiency, but do not change the characteristics of the car enough to require reprogramming to work properly. If you add these types of parts later it might take the car a driving cycle or two to get the boost right on, but it will likely adapt unless the part makes a significant change such as a turbo-back. As stated above, if you have a question about your parts, let us know and we will help you choose the map that is right for you. That is much better than getting a wrong map, or thinking we do not have a map for your combo.
Jasvboost is offline   Reply With Quote
AP- question Need help Married AP!! subadrifta06 AccessPort 13 12-19-2007 03:16 PM
AP Question... F3nom3ni Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 12-08-2004 05:51 PM
STi AP questions -=Fox=- Engine Management & Tuning 0 11-03-2004 01:37 AM
AP question rallyme Engine Management & Tuning 1 10-07-2004 11:31 PM
More AP questions AchmedRodriguez Engine Management & Tuning 9 09-12-2004 09:13 AM
