Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 11-29-2005, 05:50 PM   #1
AaronWRX
Member#: 7194
2011 997.2 Turbo
Default Utec for the Nissan 350z....
I appologize in advanced if I missed this but it looks interesting:
http://www.hopupracing.com/tuxsenmasyni.html
Fuel Control- The UTEC takes control of your vehicles fuelling at a define-able TPS point that is programmable. Fuel is tuned by an MAF offset table, a simple but effective technique. The load reference we use is RPM vs. MAF Voltage. The UTEC can also take in our optional MAP sensor to tune RPM vs. MAP or you can just use the MAP reading in your datalogs. This allows the fuel map to be adjusted at each of the 250 rpm resolution with over 10 different load sites from zero to rev limit. Ignition Timing- The UTEC gives you complete control of timing. This is not done on the basis of offsets or altering the crank signal as some engine management systems use. The load reference we use is RPM vs. MAF or MAP which is optional. This allows the fuel map to be adjusted at each of the 250 rpm resolution with over 10 different load sites from zero to rev limit. When you enter a value into the Ignition Map you are actually typing in Degrees Before Top Dead Center. The UTEC fires the coils based on these values. No more wondering if the stock ecu is going to advance or retard timing.
Knock Control- This feature allows you to help keep your motor in one piece. The UTEC contains default knock thresholds but can be adjusted at 1000 rpm increments up to 9000 rpm. It also contains a Knock Count threshold that allows you to define how many counts of knock before the UTEC will respond with a Knock Retard Step. The Knock Retard Step is the amount of ignition timing that will be pulled per knock count to a defined Knock Maximum Retard. Knock Maximum Retard relates to the maximum degrees of timing the UTEC will retard per knock event. When a knock count is registered the UTEC will hold the retard for a set number of crank cycles this is called Knock Retard Duration. The UTEC also has the ability to apply a global Knock Correction to the entire map once a knock event is evident. This will help ensure that you keep your high compression monster together. All of these features are the UTEC’s safety net. They should be used pro-active not as a reactive measure.
Datalogging- The UTEC Datalogging function helps you to keep an eye on your engines vitals. Using the logger gives you all the information you want to know about your vehicle. You can take multiple logs of your vehicle whether it’s simple driveability or all out racing. You can be sure the UTEC is keeping an eye out when you can’t. The main logger (Number1) contains rpm, map, maf voltage, tps, load site, afr, ignition timing, injector duty cycle, modified fuel (fuel control) and more. Logs can be output into text files or csv files for easy comparison. When the UTEC is used with a TXS Tuner model it can also supply you with w/b afr readings in your logs as well. Giving you the ultimate tuning package.
Remote Map Selector- The remote selector gives you the capability to switch between your UTEC maps. It also allows you to revert back to full stock ecu control on map 0 (when stock sized injectors are used). Maps 1 through 5 are your UTEC tunable map locations. Map 7 is your security mode, the car will not start. The car cannot be bump started or jumped when security mode is enabled
Software Upgrade- The UTEC will have periodic software updates to further innovate it’s tunability and flexibility. The most current version of software will be available at www.turboxs.com.
The Z UTEC will be ideal for both Forced Induction and Naturally Aspirated Mods. The UTEC has the ability to control things like Nitrous, Water Injection and More!
AaronWRX is offline   Reply With Quote
Old 11-29-2005, 11:50 PM   #2
nmyeti
Member#: 4980
Not a huge surprise here, but the information in that quote is largely wrong especially in regards to fuel control. The zUTEC has the option of running as a speed density system, a hybrid MAF/SD system, or as a simple offset piggyback for fuel control. The 350z UTEC has just finished up final testing and software work. We have them on the shelf and expect to start shipping them ASAP. It’s likely that we’ll hand deliver the first few units though since the zUTEC is a much different beast then the WRX/STI UTEC. So far we’ve had great success using them on everything from a completely stock G35 to a built motor twin turbo 350z.
The good news for the WRX crowd is that the software for the WRX/STI/EVO UTECs is going to be brought up to date in the near future.
nmyeti is offline   Reply With Quote
Old 11-30-2005, 12:10 AM   #3
AaronWRX
Member#: 7194
2011 997.2 Turbo
right on. i'm very excited! Do you think you guys might release another base map for the STI? I would love to have something to work off of for my sz55. a 20g/green/superzilla basemap with either perrin or pe injectors would rock.
Old 11-30-2005, 12:13 AM   #4
manimal15611
Member#: 58337
2k2 Impreza WRX
why are we talkin about 350z this is www.nasioc.com right?
manimal15611 is offline   Reply With Quote
Old 11-30-2005, 12:16 AM   #5
cronic
Member#: 9749
What kind of power did you see on a stock g35? I want one for my G..lol
cronic is offline   Reply With Quote
Old 11-30-2005, 12:32 AM   #6
AaronWRX
Member#: 7194
2011 997.2 Turbo
/me takes a deep breath.
We (utec users) care because any cool freature / research that turboxs put's into other utec platforms trickles down to us. But I think YOU should get a Cobb Accessport.!
Old 11-30-2005, 09:03 AM   #7
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
2nded.
Old 11-30-2005, 09:45 AM   #8
TheMadScientist
Member#: 23717
2005 Big red
So does this mean we will finally get the choice to remove the MAF?
TMS
TheMadScientist is offline   Reply With Quote
Old 11-30-2005, 10:12 AM   #9
UKscooby
Member#: 33287
RIP Nik
I will always miss you
Any chance it will work on the Quest minivan? Supposedly the same engine as the NA 350Z.
Yes, yes I said minivan.
UKscooby is offline   Reply With Quote
Old 11-30-2005, 10:18 AM   #10
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
interesting.
i feel myself slowly but surely getting drawn into the utility and ULTIMATE sleeper nature of the minivan.
obviously it has to be highly tunable if i'm ever really going to be satisfied!
Old 11-30-2005, 10:48 AM   #11
2phless
Member#: 69343
1998 TransAm cnvrtbl
You teaze!
2phless is offline   Reply With Quote
Old 11-30-2005, 10:49 AM   #12
UKscooby
Member#: 33287
RIP Nik
I had heard but couldnt find it, that there was a twin turbo Quest running around.
They are actually quite quick. 240hp, 242 ft/lb. It does destroy tires with the traction control off.
Old 11-30-2005, 10:58 AM   #13
nmyeti
Member#: 4980
TMS
Our current plan (which can be revised at any time) is to finally allow this for the WRX/STI/EVO guys. You'll of course need to install an intake air temperature sensor and an appropriate map sensor, but if you've pushed your car to the point where you require a speed density system, you are well beyond "plug and play" and can figure out a little wiring.
Air temperature corrections are easy, so that’s not a big hurdle in tuning a speed density system, but you’ll have a lot of work to do on coolant temperature corrections and cold start should you decide to completely remove your MAF.
In the case of the current release 350z software you do not have the choice of completely removing the MAF just yet because we are not simulating a signal to the stock ECU. We are just completely ignoring the MAF signal and using our own speed-density fuel map where the end user is tuning IPW. This will change in the future, but it is unlikely that it will be until after the WRX/STI/EVO software gets updated.
I am sure that we will be accused of all sorts of evil things here though since every time we release a new software update, a new product, or some upgrade to an existing product these boards fill up with such accusations. I’ll start the first one for you. The SD software is just an evil ploy to get you to purchase TurboXS MAP and IAT sensors. Discuss amongst yourselves…
Old 11-30-2005, 11:03 AM   #14
TheMadScientist
Member#: 23717
2005 Big red
Will this be compatiable with common sensors? ie. GM 3bar MAP and GM IAT
Since the Utec has the ability to change the MAP calibration any MAP should work. What about IAT will the ability to change the cal on that come with the new software?
Thanks for the new features inadvance it is about time, now you won't get the angry "It is on the website as a feature" calls and posts.
TMS
Old 11-30-2005, 11:06 AM   #15
Freon
Member#: 88322
2009 BMW 135i
Bastard!
I just want my 5.0 equivalent STI upgrade (1.2? 2.0?). Where do I send my bribes?
I'm not really interested in running SD.
Freon is offline   Reply With Quote
Old 11-30-2005, 11:12 AM   #16
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
I can’t wait for your management/monitoring interface overhaul. What’s on the road-map and when do you guys expect this enhanced component to be available, for all UTEC’s that is? I’m tired of relying on independent third-party apps to monitor and manage the status of my EM.
xcntrk75 is offline   Reply With Quote
Old 11-30-2005, 11:51 PM   #17
TexRex2002
Member#: 36303
06 Evo IX
whom will the SD system benefit?
the pump gas sti guys with FP greens, or just the big boys with rotated mount turbos, C16 fiends, etc?
I'm still barely touching 4.9 V MAF. Will the SD system benefit me?
TexRex2002 is offline   Reply With Quote
Old 12-01-2005, 09:11 AM   #18
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
if you're getting 4.9mafv you're well out of the range of its accuracy. i'd be thinking of a bigmaf if you don't switch to SD.
as far as who it would benefit, i'd like to fool around with it so i can just try out a filtered velocity stack right into the compressor inlet.
oh yeah, and run a VTA BOV to rice it up!
Old 12-01-2005, 02:33 PM   #19
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
hmm intersting
there are alot of cars using the same motor /frontier/xterra/
cool
Old 12-01-2005, 03:00 PM   #20
AaronWRX
Member#: 7194
2011 997.2 Turbo
hmm I might be a good candidate for beta testing this.
I'm in NoVa, im running a sz55, perrin injectors, and a typhoon intake (so no bigMAF)
Old 12-01-2005, 04:11 PM   #21
Wombat North
Member#: 21267
STI, EWG 8cm Green
UTEC/ECUtek/WI & SD tune
I know what power they got on the built 350z
Wombat North is offline   Reply With Quote
Old 12-13-2005, 05:55 PM   #22
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
13.4 @ 103, '09 spec.B
I am sure that we will be accused of all sorts of evil things... ...every time we release a new software update, a new product, or some upgrade to an existing product these boards fill up with such accusations. I’ll start the first one for you. The SD software is just an evil ploy to get you to purchase TurboXS MAP and IAT sensors. Discuss amongst yourselves…
Damn Nathan... you're starting to sound really jaded... ignore the haters! Don't let'em bring you down!
def
dug-e-fresh is offline   Reply With Quote
Old 12-18-2005, 12:16 PM   #23
AaronWRX
Member#: 7194
2011 997.2 Turbo
I did some trolling of 350z boards this morning and found this link:
http://turboxs.com/utec350zupdate.htm
I grabbed this zip and read the manual:
http://turboxs.com/downloads/350zutec/350Zutec_v2_3.zip
The zutec has a serial port and a USB port. (cool)
I also noticed it has a MAP sensor input.
p.s. Nice job on the manual.
Old 12-18-2005, 01:30 PM   #24
ShaggyGT
Member#: 19221
2005 Legacy GT (STi)
UR35R/Rotated Intake Mani
Can you give us any idea of when we might see this update??? I think most of us have been waiting 2 years for this. How about atleast a software update for the STi????
-Matt
ShaggyGT is offline   Reply With Quote
Old 03-29-2006, 03:27 PM   #25
AaronWRX
Member#: 7194
2011 997.2 Turbo
bump... it would be cool at least to have the same features the WRX has. I could really use the WI map.
Is the any common problems with the Nissan 350z? mrtrex Off-Topic 42 11-19-2011 11:06 AM
Central 20 presents hi-flow sports catalyzers for the Nissan 370Z AVANTI R5 Non-Subaru News & Rumors 11 02-27-2009 03:11 PM
HKS GT Supercharger released for the Nissan 350Z, Infiniti G35 Coupe and Infiniti FX3 AVANTI R5 Non-Subaru News & Rumors 0 02-25-2009 08:25 AM
For the Nissan lover in you... Paulie Member's Car Gallery 76 12-09-2007 10:38 PM
the first concept of the Nissan 350Z LinuxGuy New England Impreza Club Forum -- NESIC 5 11-22-2002 02:54 PM
