Old 03-20-2006, 06:41 PM   #1
OvenMitts
Member#: 46278
96 Impreza
"brighton"
Default What steering rack can go where? forester <-> impreza
I haven't been able to find any decisive evidence about steering rack compatibility, so does anybody know which will fit where? I'm trying to find a new steering rack for my 96 with a complete WRX swap (crossmember, hubs, brakes) and I'm wondering if I can get one out of, say, a forester, or even an earlier Impreza.
Thanks for da help
-Matt
OvenMitts is offline   Reply With Quote
Old 03-20-2006, 07:23 PM   #2
mranlet
Member#: 66304
98 RWD BG Outback
...with R200 and ITBs ;)
I'm under the impression that the forester and Impreza shared the same steering equipment and that it was different from the WRX, but I'm no expert.
mranlet is offline   Reply With Quote
Old 03-20-2006, 07:26 PM   #3
mranlet
Member#: 66304
98 RWD BG Outback
Default Steering angle comparison?
OOPS, plz delete
Old 03-22-2006, 11:59 AM   #4
OvenMitts
Member#: 46278
96 Impreza
"brighton"
are there any steering rack gurus out there?
Old 03-22-2006, 12:30 PM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
I just took a look at the part numbers, and it's showing the Forester rack as different. I don't know what the difference is, but it is somehow different.
However, for a '96 Impreza, any 90-94 Legacy, any 93-01 Impreza and any '96-01 OBS steering rack would work for you.
I am still trying to sort out if I can use an '02 WRX steering rack with '00 tie rods on my RS, but don't have an answer yet. I have a feeling the only difference is tie rod length for the wider track, but can't confirm anything yet...
Old 03-22-2006, 01:10 PM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
iirc the input shaft on the wrx steering wheel is differnt size than the older style
Old 03-22-2006, 01:27 PM   #7
OvenMitts
Member#: 46278
96 Impreza
"brighton"
Matt- IIRC, when I did my swap, the WRX rack's tie rods were bent, but the old tie ends off the 96 worked fine. I think there's enough thread on the shafts to make up for any difference anyway.
I forgot to mention that my steering column is out of a WRX too, so I guess I'm looking for anything that is WRX compatible. The crossmember is my biggest concern. Can you switch between GC and GD racks/crossmembers?
Old 03-22-2006, 01:35 PM   #8
Matt Monson
Member#: 832
99 2.5RS, '85 911
What would matter is the splining on the rack itself where it enters the U-joint in the engine bay...
What steering racks fit the 07 STI? silentt Brakes, Steering & Suspension 4 07-18-2008 09:17 PM
Is my steering rack really going bad? (Not leaking) MatchstiK Brakes, Steering & Suspension 2 01-14-2008 10:15 PM
05 sti steering rack can fit 05 wrx? craver Brakes, Steering & Suspension 26 10-16-2007 07:06 PM
02 stock ride height?What is lowest can go without effecting suspension? titanium wrx Brakes, Steering & Suspension 0 03-05-2007 12:27 AM
Do the Whiteline Steering Rack Bushings fit the Forester? King Of Imports Forester Forum 3 10-04-2004 02:09 PM
