Old 03-20-2006, 07:27 PM   #1
mranlet
Member#: 66304
98 RWD BG Outback
...with R200 and ITBs ;)
Default Steering Angle Comparison/Maximization?
I'm trying to increase the steering angle of my 98 Outback. Is there a certian model that would be compatible with most or even some of my existing equipment that would help me increase steering angle? I'm willing to swap hubs, racks and toe rods if necessary - I'd like to cover all the bases for OEM to OEM swapping before cutting and welding on my uprights.
NOTE: CV joint operation is not an issue since I've converted to RWD.
Thanks for any help or guidance!
mranlet is offline   Reply With Quote
Old 03-22-2006, 10:20 AM   #2
mranlet
Member#: 66304
98 RWD BG Outback
Could someone measure their steering angle from a FWD or GD Impreza for me?
Old 03-22-2006, 01:29 PM   #3
OvenMitts
Member#: 46278
96 Impreza
"brighton"
Why do you need to increase your steering angle?
OvenMitts is offline   Reply With Quote
Old 03-22-2006, 01:50 PM   #4
mranlet
Member#: 66304
98 RWD BG Outback
I want a tighter turning radius and to be able to hold more angle while drifting. A quicker steering ratio would also be nice since the oem outback/levacy ratio feels like you're driving a semi cab.
Old 03-23-2006, 01:29 AM   #5
Storm
Member#: 5218
96L Most Over-
Developed Beater
You should be able to relocate the hole for the steering rod ends inward to get more angle and ratio.
Old 03-23-2006, 01:50 AM   #6
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
wont a wrx rack fit a legacy? the wrx has like a 13:1 ratio while the legacy has a 15:1 or something like that. thats about i the info i have for ya, kind of a he said she said thing.
~Josh~
Old 03-23-2006, 02:12 AM   #7
GFimpreza
Member#: 40674
94 Impreza wagon
1.8L + 657cc's
We could only wish that the wrx had a 13:1 steering ratio.
GFimpreza is offline   Reply With Quote
Old 03-23-2006, 06:08 AM   #8
Kotir
Member#: 17300
1993 Widebody Wagon
748whp e98
Someone else I was talking to who was a drift fan said that the FWD steering racks have more steering angle than the AWD ones. He said he read that it was one of the modifications done to the Orange drift STi.
Not sure if that's true or not.
Kotir is offline   Reply With Quote
Old 03-23-2006, 08:28 AM   #9
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
humm well my car was orginally FWD and I'm still using the FWD rack and I personally think it feels like poop...I guess I really haven't compared it to any other subie sooo...
scobaru is offline   Reply With Quote
Old 03-23-2006, 01:16 PM   #10
mranlet
Member#: 66304
98 RWD BG Outback
Could you take a pic of your maximum steering angle for me? I'd like to try a comparison between Outback/Legacy AWD rack and FWD rack.
Old 03-23-2006, 03:28 PM   #11
970subaru
Member#: 45703
to make quicker steering, look into getting one of these:
http://www.stockcarproducts.com/steer4.htm
970subaru is offline   Reply With Quote
Old 03-23-2006, 04:23 PM   #12
mranlet
Member#: 66304
98 RWD BG Outback
Good link. I'm not only interested in quickening the ratio, but also increasing the maximum steering angle for the sake of turning radius and drift angle. The steering quiekcner would solve half of that problem, but I'd still be limited to the crappy stock steering angle.
Old 03-23-2006, 06:39 PM   #13
THAWA
Member#: 44581
3 Boxers 2 AWD
3 turbo 1 6cyl & a 13BT
Look into USDM/v8+ STi control arms. It should increase your SAI by around 15'. Not to mention the other benefits you'll recieve with the arms. Lighter, stronger, more positive caster, wider front track, longer wheelbase. Although the last one might not actually be that much better for you.
THAWA is offline   Reply With Quote
Old 03-23-2006, 06:59 PM   #14
970subaru
Member#: 45703
Old 03-23-2006, 10:55 PM   #15
mranlet
Member#: 66304
98 RWD BG Outback
I see what you're saying, but I think my best bets would either be to find uprights that have the tierod hole closer to the pivot point or a rack that has a longer throw. I'm thinking about cutting and welding on some junkyard uprights, but I'd rather install something from the factory than something that I've put together (I have enough of that in my car already).
Old 03-23-2006, 11:46 PM   #16
THAWA
Member#: 44581
3 Boxers 2 AWD
I don't think you're going to find that. From what I've looked into, FWD/AWD cars of the same generation have the same part number for the knuckles meaning the same measurements.
You can find the STi control arms for 150-300 depending on where you look. Hell I got my set for like 250 with whitline ALK's installed. Plus they're a hell of a lot better than stock. Honestly going to STi stuff is probably the best bang for buck suspension upgrades you can do, and since you have a BG you don't have any real modification to do to install these. Just make sure you get the swaybar endlinks and the balljoint boss, and it's as easy and just replacing a control arm.
If you're going to custom make some knuckles, why don't try to improve the design? Maybe revamp the whole suspension setup?
Replacing the Steering Angle Sensor/ Clock Spring nvrenufsti Brakes, Steering & Suspension 0 12-11-2008 06:38 PM
I need more steering angle racer555 Brakes, Steering & Suspension 3 05-28-2008 09:14 PM
WTB Steering angle sensor Blue beard Private 'Wanted' Classifieds 0 05-08-2008 03:43 AM
DCCD not working after quick rack install,steering angle sensor? Supraru gt Transmission (AT/MT) & Driveline 0 07-18-2007 05:00 PM
Steering angle comparison? mranlet Brakes, Steering & Suspension 2 02-20-2006 03:09 PM
