Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 03-20-2006, 10:15 PM   #1
thegreg
Member#: 105429
2004 WRX STi
Default 2.0 swap obd??
I am trying to decide on what i should do about a swap. i had originally planned on swapping US WRX in to my 93 L wagon, but have the opportunity to pick upa clean 97 sedan. My concern is the OBD difference. I am worried about emissions with the OBD2 car. I would be saving money with the 97 cause i would pull the motor and the trans.
what should I do?!?!?
thegreg is offline   Reply With Quote
Old 03-20-2006, 10:46 PM   #2
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
a US WRX is OBD2 anyways.
is a 97 even obd2?
Hurley 2.5 WRS is offline   Reply With Quote
Old 03-20-2006, 11:17 PM   #3
suberdave
Member#: 101865
88 GL-10 STi
most all cars had OBDII starting in in 8 of 96 but subaru was an excption, they started in 97.
suberdave is offline   Reply With Quote
Old 03-20-2006, 11:30 PM   #4
thegreg
Member#: 105429
2004 WRX STi
okay...maybe i should clarify...i know that the wrx is obd2 and that obd2 started in 97..i am only concerned about the tuning and the emissions side of it
i have the idea in my mind that if i use the 97 obd2 car and the obvious obd2 engine
Old 03-21-2006, 12:04 AM   #5
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
Obviously there is a little more crap to work with on an OBDII car. But it should be doable.
I personally would go with an OBDI car and go JDM.
If you like the USDM engines because of parts abundance and EM solutions, go for it.
-paK +12
Pakin is offline   Reply With Quote
Old 03-21-2006, 12:36 PM   #6
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
I wouldn't worry about using the '97 engine at all. Just use your '93 intake manifold harness, throttle body, coil pack, and ECU and the car will run just like it did with the original engine...
Old 03-21-2006, 01:35 PM   #7
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
remember that the OBD-1 L's are quite a bit lighter, the Impreza gained some weight in 96.
Old 03-31-2006, 09:18 AM   #8
myver8
Member#: 100817
2004 subaru
i know a 95 legacy has obd 2
myver8 is offline   Reply With Quote
Old 03-31-2006, 10:54 AM   #9
kheff46
Member#: 66739
2002 WRX wagon
96 is obd2.
kheff46 is offline   Reply With Quote
Old 03-31-2006, 12:18 PM   #10
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
yeah but the legacy is funny that way it went befor the deadline 95 legacys are obd2 where 95 imp are obd-1 .. thus the elusive 95 obd-1 coupe
Non-STI 2.5 swap vs. 2.0 swap? anon_az Subaru Conversions 6 03-20-2010 01:33 PM
what is needed for a 6mt swap in my 2.0 swap irishhockeypimp Subaru Conversions 14 10-09-2007 10:24 PM
2.0 swap to 2.5 Assami Built Motor Discussion 1 01-05-2007 11:08 AM
?'s about best 2.0 swap to 2.5 slida Subaru Conversions 4 01-12-2005 04:01 AM
Legacy 2.5 to WRX 2.0 Swap jacksonww Legacy Forum 7 09-08-2003 04:20 PM
