Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 03-21-2006, 10:37 AM   #1
r0n
Member#: 91839
Default utec+2.5=?
hey guys, im thinking about upgrading to a 2.5 shortblock in my wrx, I have the wrx utec, would I have to get the sti utec? or what would I have to do, because im sure the wrx utec wouldn't work good with the 2.5 considering it would be measuring 2.0 liters, correct?
ron
r0n is offline   Reply With Quote
Old 03-21-2006, 11:19 AM   #2
TheMadScientist
Member#: 23717
2005 Big red
The Utec you use depends on the ECU you use. It has nothing to do with the mechanicals in the car.
If you are using the 04 WRX ECU you use a 04 WRX Utec.
TMS
TheMadScientist is offline   Reply With Quote
Old 03-21-2006, 11:58 AM   #3
Bundyboyz
Member#: 32764
2003 WRX with 91K
New Motor & Paint WRB
my understanding is you would need a sti utec
Bundyboyz is offline   Reply With Quote
Old 03-21-2006, 12:05 PM   #4
Davenow
Member#: 23676
No, you dont. You use the UTEC that is made for the ECU you are using.
The STI utec wouldnt even plug into the WRX ECU.
<< Had a 2.5 in his WRX, used the same WRX utec he ran on the 2.0. The displacement of the motor has nothing to do with UTEC choice.
Old 03-22-2006, 12:08 PM   #5
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
As Dave said, that is incorrect. What you DO need to use is the STi knock parameters.
TypeC is offline   Reply With Quote
Old 03-22-2006, 01:43 PM   #6
hippy
Member#: 36528
2002 Impreza Wrx
Ya might wanna look into a reflash.
peace
Old 03-22-2006, 01:55 PM   #7
Bundyboyz
Member#: 32764
2003 WRX with 91K
so I have a 2003 2.0L wrx with a UTEC I'm using...
when my engine goes, I can swap in a 2.5 bottom end and be good to go for the most part?
Old 03-22-2006, 02:05 PM   #8
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
For the most part, sure. Why would your engine "go"? Don't run it past its limits...
cdvma is offline   Reply With Quote
Old 03-22-2006, 05:00 PM   #9
Bundyboyz
Member#: 32764
2003 WRX with 91K
After I run it hard I hear some tapping sounds... valve tap, rod knock, piston slap... it's anyone's guess...
I use mobil one every 3,000... prob should get a black labs test... I'm at 70,000 miles and everyday I've taken the car to red line... Been through a few trannies and a few rear diff's figure it's just a matter of time.
Now I'm upping the boost to 16 16.5 pounds with a UTEC that's not gonna make it last longer. Obviously with this power I've been trying not to shift after 6K or 6,500
2.0 utec on a 2.5 swap KillerBumbleBee UTEC 13 01-26-2007 04:02 PM
Utec base map, 2.5, 550s, vf34 kaos200 Engine Management & Tuning 1 07-08-2004 02:41 AM
Utec + STi 2.5 block + 38 counts of knock MAD REX Engine Management & Tuning 11 05-07-2004 12:17 AM
having trouble updating UTEC software from 2.5 to 3.1 annointed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-27-2003 11:36 PM
Utec help again please! How do I reload my 2.5 map into my new 3.1 program?? STR8OUT Engine Management & Tuning 7 07-08-2003 03:31 PM
