Old 03-21-2006, 11:01 AM   #1
SiriX
Member#: 70869
2006 Impreza WRX
WR Blue
Default 06 STi Gauges Into 06 WRX?
Hi!
I've got an 06 STi Instrument cluster coming for my MY06 WRX, and i was just wondering before i pull anything apart, is there anything i should know about fitting these? or any tricks?
Hopefully *fingers crossed* it's PnP... place i bought it from said it is... so hopefully they were correct.
Regards,
SiriX
SiriX is offline   Reply With Quote
Old 03-21-2006, 11:13 AM   #2
wrxpunk
Member#: 29194
2006 WRX wagon
(STG II) & '08 Tribeca
i remember reading something about the sti cluster not being plug and play. something about the buzzer or something always going nuts. i think minor modification is needed. i could be wrong tho. (it might just be the 04-05 sti clusters). at any rate, best of luck with the install. please let us know what you find out!
wrxpunk is offline   Reply With Quote
Old 03-21-2006, 11:14 AM   #3
alpinev12
Member#: 90186
2006 Impreza WRX Ltd
2011 Audi S4
yeah definitely keep us posted...i to am interested in this mod
Rick B.
alpinev12 is offline   Reply With Quote
Old 03-21-2006, 11:16 AM   #4
scooby24
Member#: 56414
2004 Forester XT 5MT
subscribed
scooby24 is offline   Reply With Quote
Old 03-21-2006, 11:54 PM   #5
SiriX
Member#: 70869
2006 Impreza WRX
WR Blue
Ok... so initial reports... not looking good...
Here's the issue at-hand...
This photo is the 06 WRX's Left-Hand (if your looking head-on towards the road, an the dash is infront of you as it normaly would be) Connector...
This is the connection on the 06 WRX Dash
And this is where it doesnt connect... here's the STi Dash's connection
So basicly there's a couple of extra pins on the STi dash, and they've changed the connector slightly so you cant just plug in the WRX dash...
Regards,
SiriX
Old 09-12-2006, 11:55 AM   #6
quaam
Member#: 113615
2006 WRX Wagon
BLACK
did you ever get it working?
quaam is offline   Reply With Quote
Old 09-13-2006, 08:53 AM   #7
quaam
Member#: 113615
2006 WRX Wagon
BLACK
bump for an update from anybody
Old 09-15-2006, 05:00 PM   #8
quaam
Member#: 113615
2006 WRX Wagon
BLACK
ok so mine arrived today. I'm going to try and get it working. I'm looking for the 06 wrx and 06 sti cluster wiring diagrams to see if I can figure this out. Another idea would be to get that green connector from an STI and connect the wires where they are supposed to go and try it like that.
Any ideas?
Old 09-15-2006, 05:15 PM   #9
quaam
Member#: 113615
2006 WRX Wagon
BLACK
Also I connected 2 out of 3 plugs and there was a loud buzzer sound. Everything that was connected worked. No ABS light but obviously the Rear diff temp was lighted.
Any idea what the buzzer is?
Old 09-17-2006, 12:19 AM   #10
quaam
Member#: 113615
2006 WRX Wagon
BLACK
Got mine working today ! woot
Old 09-17-2006, 05:10 PM   #11
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
Would a '06 WRX cluster be PnP on a 2.5i? I want that center tach.
Counterfit is offline   Reply With Quote
Old 09-18-2006, 08:29 AM   #12
Bullitt 2496
Member#: 53724
2013 Subaru BRZ LS2
Quaam - did you have to do anything to fix the ABS light?
Bullitt 2496 is offline   Reply With Quote
Old 09-18-2006, 11:44 AM   #13
quaam
Member#: 113615
2006 WRX Wagon
BLACK
06 STI cluster on a 06 WRX didn't have any ABS light come up. Before I bought this one I had an 04 STI cluster and the abs light came up. I sold it to somebody with an 02 WRX and it didn't have the ABS light come up.
I have a friend with an 05 wrx that installed a 06 STI cluster and he went through the same things that I did. Which means that 05 and 06 STI cluster fit the same way on an 05 wrx and a 06 wrx.
04 STI cluster work best on 02-04 wrx although 04 WRX require some additional modification since there are buzzing sounds as well and also something about the ebrake I believe.
Old 09-20-2006, 01:12 AM   #14
KC4725
Member#: 121293
2010 Legacy 2.5i
Satin White Pearl
Any ideas?
hi quaam, I'm thinkin of swapping a 06 STI gauge cluster into my 06 2.5i Impreza.
Did you get that wiring diagram you mentioned?
If so, send it ova plz
So how did the re-wiring go? So you connected 2 outta 3 plugs only?
What wires did you leave out?
KC4725 is offline   Reply With Quote
Old 09-20-2006, 08:11 AM   #15
quaam
Member#: 113615
2006 WRX Wagon
BLACK
I connected all three plugs. Like Sirix posted above, the leftmost plug (for fuel and temp) is a different size for the wrx and sti. 05 and 06 WRX have the same plug and the wires in the same order. The 05 and 06 STI have the same plug shape and wire order as well. I got a 05 STI green plug from a dismantled 05 STI at a junker. The green plug still had the wires from the harness connected.
I downloaded the wiring diagrams for 05-06 wrx and sti from http://techinfo.subaru.com/html/index.jsp . According to the diagram the manual transmission 05-06 WRX uses 6 wires( AT uses the same wires except that there are additional wires for the P,R,N,etc) , which the 05-06 STI uses along with several more for the DCCD.
This is how I connected it:
1- I identified the colors which I was going to used from the WRX connector plug.
2- Found and identified the matching colors on the STI connector plug (from the junker)
3- Using wire cutters I removed the WRX plug from the harness, leaving enough wires connected to the plug ( just in case I might need these wires in the future) and in the harness.
3- Using the wiring diagram, in order to verify the wire's purpose, I proceeded to connect each wire from the WRX harness with its matching STI plug wire and used electrical tape. You should only have 6 wires connected from the harness into the STI plug. The extra wires on the STI green plug were taped together so that they would be out of the way.
I don't have pics on me but I will try to get some.
As for the buzzing sound, The module controlling this buzzer is on the rightmost plug and the wire that you need to cut on your 06 WRX harness in order to disable it is
c9 which is identified as Body Integraded Module in the wiring diagram.
Let me know if you have any questions.
Old 12-28-2006, 11:34 AM   #16
Chapel
Member#: 3496
1995 Roadmaster
Beige
did you guys have any issues with the radio fuse blowing?
Chapel is offline   Reply With Quote
Old 12-28-2006, 11:57 AM   #17
Chapel
Member#: 3496
1995 Roadmaster
Beige
on the rightmost or the left most?
C9 in my diagram is the left side plug.
Old 12-28-2006, 12:42 PM   #18
Chapel
Member#: 3496
1995 Roadmaster
Beige
here's an 02 gauge.
which one did you remove 9 from? the 14 pin connector (the one on the left) or the 10 pin connector (the one on the right)
Old 02-25-2007, 03:00 PM   #19
Accorn1
Member#: 126428
2007 STi
Bump for more info.
Accorn1 is offline   Reply With Quote
Old 02-25-2007, 06:42 PM   #20
o2sys
Member#: 43842
200? WRX STI
suscribed for later...
o2sys is offline   Reply With Quote
Old 02-26-2007, 01:11 AM   #21
photog72
Member#: 43815
2006 WRX Wgn Limited
2006 Honda S2000
Tips for newbs - see "thread tools" at the top, to subscribe.
photog72 is offline   Reply With Quote
Old 03-04-2007, 10:32 AM   #22
Rexer06
Member#: 125065
2006 WRX
not sure i'm hijacking this thread but thought i started a new one, i might get flamed for not searching... so here goes:
i got myself a 05 JDM STi optitron meter cluster and installed it into my 06 WRX. everthing's fine (outside temp working, no rear diff temp light) except the darn ABS light... can any kind soul provide me with electronics-for-dummies instruction on how to solve this problem?
Rexer06 is offline   Reply With Quote
Old 03-07-2007, 01:18 AM   #23
06STi
Member#: 97561
2006 Widebody
WRB/Carbon/Primer
I've had mine working for about a year now.
I had to move about 25 wires. Everything but dccd, rear diff temp works.
06STi is offline   Reply With Quote
Old 03-09-2007, 11:12 AM   #24
DoDgY
Member#: 142928
Cool
could any of you please tell me where i can get a 06 sti gauge? cuz i just bought this wrx and i dont really like it's greeny color gauge and i have no idea where to get the sti one and how much, please^^
Tao
DoDgY is offline   Reply With Quote
Old 03-22-2007, 12:13 AM   #25
biker921
Member#: 118236
Look through classifieds or go through the cluster color change tutorial. That will let you use your stock gauges, but takes a hell of a lot of work.
Tao
biker921 is offline   Reply With Quote
07 STI Longblock into 06 WRX turbofied Subaru Conversions 5 01-02-2015 01:44 PM
Swap 06 STi HIDs into 06 WRX Snowrider Electrical & Lighting 0 01-09-2008 03:12 PM
06 sti tranny into 02 wrx AWDWRXLOVER Subaru Conversions 5 05-02-2007 05:47 AM
06 Sti wheel into 02 wrx AdsWRX Subaru Conversions 0 02-19-2007 04:02 PM
06 sti tranny into 02 wrx scarsofterror Transmission (AT/MT) & Driveline 26 01-04-2007 09:13 PM
