Old 03-22-2007, 12:15 AM   #26
biker921
Member#: 118236
2004 Audi S4
Hey quaam, did you get any photos of your wiring? Am about to do it this tomorrow.
Originally Posted by quaam View Post
I connected all three plugs. Like Sirix posted above, the leftmost plug (for fuel and temp) is a different size for the wrx and sti. 05 and 06 WRX have the same plug and the wires in the same order. The 05 and 06 STI have the same plug shape and wire order as well. I got a 05 STI green plug from a dismantled 05 STI at a junker. The green plug still had the wires from the harness connected.
I downloaded the wiring diagrams for 05-06 wrx and sti from http://techinfo.subaru.com/html/index.jsp . According to the diagram the manual transmission 05-06 WRX uses 6 wires( AT uses the same wires except that there are additional wires for the P,R,N,etc) , which the 05-06 STI uses along with several more for the DCCD.
This is how I connected it:
1- I identified the colors which I was going to used from the WRX connector plug.
2- Found and identified the matching colors on the STI connector plug (from the junker)
3- Using wire cutters I removed the WRX plug from the harness, leaving enough wires connected to the plug ( just in case I might need these wires in the future) and in the harness.
3- Using the wiring diagram, in order to verify the wire's purpose, I proceeded to connect each wire from the WRX harness with its matching STI plug wire and used electrical tape. You should only have 6 wires connected from the harness into the STI plug. The extra wires on the STI green plug were taped together so that they would be out of the way.
I don't have pics on me but I will try to get some.
As for the buzzing sound, The module controlling this buzzer is on the rightmost plug and the wire that you need to cut on your 06 WRX harness in order to disable it is
c9 which is identified as Body Integraded Module in the wiring diagram.
Let me know if you have any questions.
biker921 is offline   Reply With Quote
Old 03-29-2007, 01:42 PM   #27
acetey
Member#: 144695
2003 Wrx
Hi Rexter, able to share where to purchase the 05 JDM STi optitron meter? Thought of getting one myself too.
Originally Posted by Rexer06 View Post
not sure i'm hijacking this thread but thought i started a new one, i might get flamed for not searching... so here goes:
i got myself a 05 JDM STi optitron meter cluster and installed it into my 06 WRX. everthing's fine (outside temp working, no rear diff temp light) except the darn ABS light... can any kind soul provide me with electronics-for-dummies instruction on how to solve this problem?
acetey is offline   Reply With Quote
Old 04-04-2007, 10:04 PM   #28
biker921
Member#: 118236
2004 Audi S4
Am looking at these 05 STi gauges for cheap...almost too cheap. Is there any ways to get the STi gauges repaired possibly. Am worried that Fuel or some other guage is messed up and doesn't word right.
Old 04-06-2007, 05:06 PM   #29
wrxwhip
Member#: 80343
1993 T67 Supra
Graphite
quuam, i need the wiring diagrams as well if you could post them
i am trying to swap an 06 sti cluster into my 05 wrx.
wrxwhip is offline   Reply With Quote
Old 04-09-2007, 07:25 PM   #30
wrxwhip
Member#: 80343
1993 T67 Supra
Graphite
Hey quuam,
I was just wondering if you still have those wiring diagrams, I have an 06 Sti cluster im trying to swap into my 05 WRX. I was thinking about just filing down the fuel/temp connector and plugging it into the 06 sti cluster and just leaving the two excess pins on the right side of the female connecter alone. Let me know if this will work, or if I have to get the wiring from an 06 sti junker. Thanks.
Cliff
Old 04-10-2007, 11:27 AM   #31
ZackyFarms
Member#: 9274
07 WRX Sedan
Satin White Pearl
subscribed...
ZackyFarms is offline   Reply With Quote
Old 04-10-2007, 11:41 AM   #32
photog72
Member#: 43815
2006 WRX Wgn Limited
2006 Honda S2000
Originally Posted by ZackyFarms View Post
subscribed...
Tips for Long Time Newbs
Go to top of thread, click on Thread Tools. Then click on Subscribe to this Thread. "That was easy."
photog72 is offline   Reply With Quote
Old 04-12-2007, 03:31 AM   #33
cppchrisdh
Member#: 118994
2006 Imreza WRX
WR Blue
subscibed
cppchrisdh is offline   Reply With Quote
Old 04-12-2007, 06:33 PM   #34
photog72
Member#: 43815
2006 Honda S2000
Originally Posted by cppchrisdh View Post
subscibed
Tips for Short Time Newbs Who Can't Follow Directions
Use a spell checker. What is "subscibed?"
Old 04-12-2007, 06:49 PM   #35
biker921
Member#: 118236
2004 Audi S4
holy crap, relax...he can't spell let it go.
Old 04-13-2007, 01:20 PM   #36
need2boost
Member#: 118163
2006 EWG vf39 WRX
RA TRANNY
has anyone else been successful with this?
need2boost is offline   Reply With Quote
Old 04-16-2007, 02:37 PM   #37
ZackyFarms
Member#: 9274
07 WRX Sedan
Satin White Pearl
anyone have updates? quuam could u perhaps give a little more info. i read the post but still a little fuzzy. how difficult was this to do?
Old 04-22-2007, 11:49 PM   #38
biker921
Member#: 118236
2004 Audi S4
What's the difference if any between the 05 and 06 STi clusters?
Old 04-25-2007, 12:08 AM   #39
need2boost
Member#: 118163
2006 EWG vf39 WRX
RA TRANNY
update please...
Old 04-25-2007, 08:44 AM   #40
wrxwhip
Member#: 80343
1993 T67 Supra
Graphite
i installed an 06 WRX Sti cluster into my 05 WRX. All you need to do is file down the one peg on the 05 WRX wiring harness so it can be slid in on for the fuel/temp connection on the 06 Sti cluster. Also, they Sti cluster has 2 extra pins which cause a problem, but all you need to do is file down the one peg so the Male connecter from the 06 Sti cluster can fit into the Female connector of the 05 WRX wiring harness. You just plug it in and leave the two extra pins unconnected. Hope this helps...
Old 04-25-2007, 03:31 PM   #41
alpopcc
Member#: 140691
2007 Impreza WRX
BL=lack
Which wire do you cut on the right plug to disable that annoying buzz? In that diagram the "c" wire's were on the left plug, I filed down two tabs on the left plug to get it to fit, the middle and right plugs fit fine but the odometer went to zero, the r. diff temp light came on, and it's buzzing, I don't care about the zero miles cause I remember how many miles I had on the other odometer, I'm sure I can ignore the r. diff temp light, that buzzing will drive me nuts, how do I turn that off?
alpopcc is offline   Reply With Quote
Old 04-26-2007, 08:41 AM   #42
biker921
Member#: 118236
2004 Audi S4
Scooby Mods will have the info for wire cutting. As for the temp light, I am having the same problems. I was told that unless you have the temp sensor like the STi's have, it will stay on. I KNOW there's a way to turn it off. That link tells of a way with electrical tape and grounding. I didn't understand exactly how to ground it, but electrical tape did NOT work for me. As for the rest of your issues...no clue, sorry.
Old 04-26-2007, 08:43 AM   #43
biker921
Member#: 118236
2004 Audi S4
Does anyone...quaam, know hos exactly to ground that R. diff temp light? Or at least get it to turn off? I'm also having issues with a correct outside thermometer reading. I live in Texas and it's telling me its 45 outside right now.
Old 04-29-2007, 08:05 PM   #44
biker921
Member#: 118236
2004 Audi S4
Bump it
Old 05-08-2007, 01:40 PM   #45
need2boost
Member#: 118163
2006 EWG vf39 WRX
RA TRANNY
ground pin b4 to a ground source, to turn off rear diff light. light will still come on at start up for system check, but will go off
Old 05-12-2007, 02:51 AM   #46
need2boost
Member#: 118163
2006 EWG vf39 WRX
RA TRANNY
alright i got my 2006 sti cluster and wires in the mail today and went ahead and installed it. pretty easy to do. by matching colors on the far right clip and making a ground for terminal B4 for the rear diff. and cutting c9 to get rid of the buzzer. oh and the last thing is swap terminal b28 to b16 for the cruise light. everything works great except my outside temp says its 43 no matter what the temp is. gonna have to look into this one.
Old 05-12-2007, 03:23 AM   #47
need2boost
Member#: 118163
2006 EWG vf39 WRX
RA TRANNY
did you ever find a fix for this, i installed my gauges tonight and my outside temp says 43 outside, its more like 83.
Old 05-12-2007, 10:54 AM   #48
biker921
Member#: 118236
2004 Audi S4
I haven't found a fix yet. A couple of people have told me I need to install a temp wire, but clearly I already have one since my stock cluster had the temp. Does anyone know what every wire in the WRX and STi are for in the harness???
Old 05-12-2007, 11:55 AM   #49
need2boost
Member#: 118163
2006 EWG vf39 WRX
RA TRANNY
i thought about buying a new sensor from an sti to try that, its clearly getting a signal or it would be(--F) instead its giving me a temp thats about 40F off from the real temp, Biker921 does your car have auto a/c?
Old 05-12-2007, 12:08 PM   #50
biker921
Member#: 118236
2004 Audi S4
nope, my car is manual a/c...boo
07 STI Longblock into 06 WRX turbofied Subaru Conversions 3 08-06-2010 10:46 AM
Swap 06 STi HIDs into 06 WRX Snowrider Electrical & Lighting 0 01-09-2008 03:12 PM
06 sti tranny into 02 wrx AWDWRXLOVER Subaru Conversions 5 05-02-2007 05:47 AM
06 Sti wheel into 02 wrx AdsWRX Subaru Conversions 0 02-19-2007 04:02 PM
06 sti tranny into 02 wrx scarsofterror Transmission (AT/MT) & Driveline 26 01-04-2007 09:13 PM
Message Board Statistics All times are GMT -4. The time now is 12:57 AM.
