Welcome to the North American Subaru Impreza Owners Club Tuesday June 2, 2015
Old 05-12-2007, 04:24 PM   #51
need2boost
Member#: 118163
2006 EWG vf39 WRX
RA TRANNY
Originally Posted by biker921 View Post
nope, my car is manual a/c...boo
I'm thinking this might have something to do with it since all 2006 sti's are auto a/c, my a/c is also a manual a/c. The ambient temp sensor is tied in with the auto a/c according to my wiring diagrams. But I'm still hoping that i just need an sti sensor in the front. it's weird that the temp never changes from 43.
need2boost is offline   Reply With Quote
Old 05-13-2007, 02:01 AM   #52
biker921
Member#: 118236
Let me know if you end up getting it, I'd like to know if it works. Was thinking it was something in the wiring, but didn't' know for sure.
biker921 is offline   Reply With Quote
Old 07-06-2007, 11:21 PM   #53
WRX4eva
Member#: 103343
2004 2.5 Hybrid 6spd
Rotated Manifold/35R
Hey guys,
I got a question. I got the Brake lights and ABS lights on. My car is an 04 wrx w/ 06 sti (cluster). Do you think it's okay to drive the car with it on? I know it sounds dumb but just in case.
Also, has anyone figured how to get the abs lights off? can anyone help?
WRX4eva is offline   Reply With Quote
Old 07-23-2007, 07:08 AM   #54
Kentrik
Member#: 125937
03 WRX I do not
like your tweed, chap.
Has anyone tried to do the manual A/C to Auto A/C swap? I'd like to know what all it entails and roughly how much it would cost time and money wise...I've got the dials and cluster for an 05 STi and I'm trying to get them into an 03 wrx.
Kentrik is offline   Reply With Quote
Old 07-24-2007, 04:13 AM   #55
Kentrik
Member#: 125937
03 WRX I do not
Wrxwhip, do you have any pics of the file job? I've got an 05STi going into an 03wrx that is being a major pita. Any recommendations, anyone?
Old 10-24-2007, 11:57 AM   #56
dorby
Member#: 153695
sweet info
dorby is offline   Reply With Quote
Old 11-18-2007, 11:53 PM   #57
WRFX
Member#: 149789
just did an 07 sti cluster in an 07 wagon..
Really easy:
  • Trim the 2 green parts on the left (A) plug so it can slide on.
  • Move B28 wire to B16. (Cruise)
  • Ground B4 pin (Diff light)
  • Cut C9 wire (buzzer)
WRFX is offline   Reply With Quote
Old 11-25-2007, 08:52 PM   #58
FTL83
Member#: 142267
2006 tacoma
white
I don't know if I'm retarded but the reason I wanted the STi cluster in my MY06 wrx is for the rpm buzzer notification. I don't get on my car that often but when I do I find myself paying too much attention to the rpm's and it's taking away from me paying attention to the driving. I want the buzzer but I notice everyone saying you cut C9. Anyway, to the people who made the swap; why did you swap it? Are their some benefits I'm missing or negatives I'm over looking?
Gabriel-
P.S: is there a way to get the full STi wire harness from cluster back so you don't have to shave anything off?
FTL83 is offline   Reply With Quote
Old 11-26-2007, 03:04 PM   #59
06_Rex
Member#: 130804
2013 STi
Ice Silver
i have a 05 sti cluster and wanting to install it in my 06 wrx...is everything the same vise versa?...
06_Rex is offline   Reply With Quote
Old 11-27-2007, 02:45 PM   #60
swiftwrx06
Member#: 130897
2006 6 speed WRX 18G
330awhp 355ft/lbs
Gabriel-
My shift light an buzzer works fine after cutting c9. Trimming the connector to the cluster is really easier than it sounds, i only trimmed down 1 little tab and it fit fine, took about 30 seconds. It will still plug back into your old cluster if you ever want to switch back.
swiftwrx06 is offline   Reply With Quote
Old 12-07-2007, 08:04 AM   #61
2.5iSTI
Member#: 162585
2007 03 Evo w/2.3
Just curious since most of this information pertains to the 05+ cluster, are the 04 STI clusters easier? I just happen to get on of those with the cluster harness as well
2.5iSTI is offline   Reply With Quote
Old 12-08-2007, 02:46 AM   #62
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
I haven't found a fix yet. A couple of people have told me I need to install a temp wire, but clearly I already have one since my stock cluster had the temp. Does anyone know what every wire in the WRX and STi are for in the harness???
I just made a spreadsheet with the pinouts from the 06 WRX and 06 STI Cluster scematics. What everyone has said so far is accurate. The A plug on the STI seems to have two extra, unused pins lol. If I am correct, that would mean they are there for NO reason. I will try to post the spreadsheet as an image....otherwise, I will just post a link to my storage.
One interesting thing, however, is that I THINK I can get the IC Sprayer Tank level warning light working. I need to look at the B plug in my car tho to see if the Auto Tranny wire is there on the MT model....I suspect it is. Even if it is not, there is a way Worst part would probably be running a wire from the trunk mounted tank to the cluster.
As for temp, I have no idea yet...but then, I still need to get the mileage adjusted on my STI cluster.
Originally Posted by WRX4eva View Post
Hey guys,
I dont have an answer, althought I THINK I have seen it on here somewhere. I DO know that with the airbag system, if ANY part of the system is not detected, the entire system is disabled to prevent accidental discharge of the airbags. This is why I cannot remove the clock entirely for my gauges, but have to stuff it in the dash. The stupid airbag light comes on because the clock has the passenger airbag light
Really easy:
Thanks for the clear, specific, and very helpful directions.
Gabriel-
The only realistic way is to get the car side of the plug out of a wrecked STI....unfortunately, most of this stuff gets sold as a complete harness.
aboothman is offline   Reply With Quote
Old 12-10-2007, 11:09 AM   #63
2.5iSTI
Member#: 162585
2007 03 Evo w/2.3
The 04 cluster is the way to go. I just installed one in my 07 2.5i. Pluged in and no problems with a buzzer. Still have the abs light and the diff light, but that will be gone when I do the rest of my STI swap in Feb so for now it works!
Old 12-25-2007, 07:03 AM   #64
darkantz
Member#: 151426
08 STi,TRIBECA,BRZ
DGM SWP
Really easy:
Can you show me which the 2 green parts are you talking about? I'm confused.
A
B
darkantz is offline   Reply With Quote
Old 12-26-2007, 05:22 AM   #65
darkantz
Member#: 151426
08 STi,TRIBECA,BRZ
DGM SWP
Anyone has step by step install pics for 06STi cluster into 06WRX?
Old 12-27-2007, 10:32 PM   #66
KevinG
Member#: 146091
14 Mazda 3
Red
bump...
KevinG is offline   Reply With Quote
Old 12-28-2007, 09:41 AM   #67
jay25RS
Member#: 4273
2011 GR-STI
& 2015 Legacy Ltd.
subscribe
jay25RS is offline   Reply With Quote
Old 12-28-2007, 02:59 PM   #68
KevinG
Member#: 146091
14 Mazda 3
Red
any one have some pics with the sti cluster along next to the rest of the wrx's green controls...
are there any fixes for the rest of the green stuff?
Old 12-28-2007, 09:31 PM   #69
darkantz
Member#: 151426
08 STi,TRIBECA,BRZ
DGM SWP
Originally Posted by KevinG View Post
aby obe have some pics with the sti cluster along next to the rest of the wrx's green controls...
Do you have link for aby obe pics?
Btw, my 07wrx is EDM and there's no cruise control. Do i need to move move B28 wire to B16?
Old 12-30-2007, 10:54 AM   #70
KevinG
Member#: 146091
14 Mazda 3
Red
bump for my question:
Old 01-10-2008, 01:56 PM   #71
subaru_west
Member#: 151373
Chapter/Region: PRSIC
2006 wrx wagon
red
i need help to installs the 2007 sti cluster to my wrx 2006
subaru_west is offline   Reply With Quote
Old 01-10-2008, 03:52 PM   #72
06STi
Member#: 97561
2006 Widebody
WRB/Carbon/Primer
How many of you have checked to see if your gauges are working correctly after doing the swap?
I had to move alot of wires to get mine to work. Trimming and moving one wire was not a option. Everything but rear diff works on mine.
06STi is offline   Reply With Quote
Old 01-12-2008, 01:29 PM   #73
WRFX
Member#: 149789
mine works great, except I can't adjust the brightness???
Old 01-13-2008, 02:40 AM   #74
WRFX
Member#: 149789
Does anybody know how to dim the 06-07 STi cluster? Mine doesn't work with the dimmer switch and it doesn't have an "ILL" adjustment by pressing the odometer.. Any help appreciated.
Old 01-13-2008, 09:40 AM   #75
scubywagon
Member#: 65967
2004 WRX WGN 2.5
Java Black Pearl
I swapped in an sti cluster into my 04 wagon and the only problems that i have is that 1- I don't have the temperature sensor so the temperature always says it's 43 degrees unless it is really cold and it will say 25? not sure why it changes and 2- The rear diff light is always on(no rear diff sensor in my car so it makes sense) and I can't adjust the brightness of the cluster...other than that it was plug and play.
scubywagon is offline   Reply With Quote
07 STI Longblock into 06 WRX turbofied Subaru Conversions 5 01-02-2015 01:44 PM
Swap 06 STi HIDs into 06 WRX Snowrider Electrical & Lighting 0 01-09-2008 03:12 PM
06 sti tranny into 02 wrx AWDWRXLOVER Subaru Conversions 5 05-02-2007 05:47 AM
06 Sti wheel into 02 wrx AdsWRX Subaru Conversions 0 02-19-2007 04:02 PM
06 sti tranny into 02 wrx scarsofterror Transmission (AT/MT) & Driveline 26 01-04-2007 09:13 PM
