Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 01-13-2008, 10:09 AM   #76
WRX4eva
Member#: 103343
2004 2.5 Hybrid 6spd
Rotated Manifold/35R
Originally Posted by scubywagon View Post
I swapped in an sti cluster into my 04 wagon and the only problems that i have is that 1- I don't have the temperature sensor so the temperature always says it's 43 degrees unless it is really cold and it will say 25? not sure why it changes and 2- The rear diff light is always on(no rear diff sensor in my car so it makes sense) and I can't adjust the brightness of the cluster...other than that it was plug and play.
Nice!
However, how did you manage to turn the abs and handbrake lights off?
WRX4eva is offline   Reply With Quote
Old 01-13-2008, 03:06 PM   #77
WRFX
Member#: 149789
WRFX is offline   Reply With Quote
Old 01-13-2008, 09:49 PM   #78
WRFX
Member#: 149789
Finally figured out how to dim the 2007 STi cluster at night....
I connected a potentiometer between pins b20 and b22 on the cluster. The wrx harness does not have any connectors on these pins so all I did was shove the ends of the wires into the empty slots and secured it.
With the headlights turned on you lower the brightness of the cluster until it makes a sudden drop in light (this is the night setting)....when you turn the headlights off the cluster goes back to the brightest setting.
I temporarily put the potentiometer in the little pullout compartment by the fuses, I will find a better location later...Just happy I don't have to blind myself at night anymore.
And here is the vid
Old 01-19-2008, 08:46 PM   #79
PulsedriveRS
Member#: 169441
2007 Impreza WRX STi
Obsidian Black Pearl
Originally Posted by 2.5iSTI View Post
The 04 cluster is the way to go. I just installed one in my 07 2.5i. Pluged in and no problems with a buzzer. Still have the abs light and the diff light, but that will be gone when I do the rest of my STI swap in Feb so for now it works!
Hey 2.5iSTi, I have an 07 RS too. I would like to get the cluster mod done but I would like to know if you encountered any problems like the users posted above. Disconnecting the DCCD light shouldn't be hard to do, but why did the ABS light show up on yours? Anyway, help from anybody would be appreciated.
PulsedriveRS is offline   Reply With Quote
Old 01-20-2008, 01:49 PM   #80
WRFX
Member#: 149789
Clearing things up for a 2007 STi Cluster in a 2007 WRX.
This is exactly what I did and every things works....temp, shift light, etc. Also no extra lights or warnings are on.
  • Trim the 2 green parts on the left (A) plug so it can slide on.
  • Move the B28 wire to B16. (Cruise)
  • Ground B4 pin (Diff light)
  • Cut the C9 wire (buzzer)
  • (Dimmer)-Connect a potentiometer between pins b20 and b22 on the cluster. The wrx harness does not have any connectors on these pins so all I did was shove the ends of the wires into the empty slots and secured it.
    With the headlights turned on you lower the brightness of the cluster until it makes a sudden drop in light (this is the night setting)....when you turn the headlights off the cluster goes back to the brightest setting. This is the potentiometer I used http://www.radioshack.com/product/in...entPage=search
Old 01-20-2008, 03:26 PM   #81
PulsedriveRS
Member#: 169441
Since the Speedometer on my 07 RS 2.5i is in the middle instead of being on the right like the WRX's is, do I have to switch the plugs? Which cluster should I get? 04 or 07? This mod is far too cool and I want to get it done!!!
Old 01-23-2008, 08:41 PM   #82
Z-GhostRex
Member#: 153430
07 WRX
Urban Grey Metallic
Default Thanks!!
Thanks for the info, just swapped mine tonight, I did a 07 STI cluster into a 07 WRX sedan (M/T, Auto Climate) and everything almost went as planned. I broke the pin at B28 (cruise lamp), I don't know why but I am having a hard time getting these out. Yes, the cruise still works and the "set" lamp will come on when it's engaged. Also on mine the DCCD lamp is lit, would anyone know which pin I need to ground or modify? Once again Thanks.
Cheers
Chris Z.
Z-GhostRex is offline   Reply With Quote
Old 01-23-2008, 10:14 PM   #83
WRFX
Member#: 149789
It is somewhat hard to remove the individual wires from the green connector, but it can be done. If you look at the green housing you will see that there is a part on it that can be pried open and closed. Once you pry open the little flap you just pull somewhat hard on the wire and it will pop out.
As for the DCCD light, mine is on all the time... thought it was normal. Here is a pic of my cluster on a fresh start up.
Old 01-23-2008, 10:28 PM   #84
Brody8877
Member#: 92355
2013 Impreza 2.0i
Ice Silver
how about an 06 Sti into an 07 wrx wagon 5spd
Brody8877 is offline   Reply With Quote
Old 01-24-2008, 06:48 AM   #85
Z-GhostRex
Member#: 153430
07 WRX
Urban Grey Metallic
OK, thanks. I might be able to get another pin, we have some here at work that are similar. If not I have a source that may be able to get me a harness repair kit from Subaru.
Old 01-24-2008, 03:23 PM   #86
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
I am in the same boat...tore the wire off yesterday trying to get the damn connector out lol. To fix, I just soldiered around 1/2" of wire, and siliconed it in place.
Harness repair is a great idea, I will have to look into that.
Another thing, I am sitting here digging through the wiring scematics, and I think there may be a way to use the column dimmer switch. The problem is the Body Integrated Module, but I think we can bypass it with no adverse effects. If anyone has experience or knowledge of wiring, send me a PM cause I need the help lol.
1 other thing. It seems the speedometer and Tach are off a little bit. According to my accessport (which uses ECU info) I am consistantly off by 2-3 MPH and 50-100 RPMs. Best part is my MPH is probably more accurate now, as I am using 225 tires as opposed to 215s.
aboothman is offline   Reply With Quote
Old 01-24-2008, 04:28 PM   #87
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
It looks like running pins B20 and B22 to the lighting switch/dimmer knob will work. Aside from bypassing the Body Integrated Module (BIM), the only difference is the third wire. On the WRX it is a ground (Black Wire), running from Cluster pin C6, through the heater, and on to the BIM and Lighting Switch/Dimmer Knob, and finally terminating at ground. On the STI, it is Green/Yellow and I believe it is for power. Assuming the WRX dimmer knob gets it's power from the BIM, it would explain why the STI gets power from the cluster....since the STI does not pass the dimming circuit through a BIM (as far as I can tell).
The real trick, is to tap the dimmer knob wires before the BIM, as I believe cutting them would keep other dimming functions from working. Without rewiring all the car's dimming components, tapping the wires would be the best solution. Since the BIM is providing power for the circuit, we should be able to leave the third dimmer know wire as a ground to complete the circuit.
Tracing the wires from the dimmer knob would be best. Just find a location close to the cluster.
This is difficult because you kinda have to combine schematics, as they do not always include everything that is present in the actual car. It is also necessary to find out whether there is an open pin or not.
Old 01-24-2008, 10:14 PM   #88
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
well, scratch the above. It did and did not work. I had it working in a weird way, but then the other accessories would not dim correctly. As you turn the dimmer down it would do nothing, then as you turn it back up it would start dimming, until the full bright setting lol. I was going to use it that way, but the AC/Heater controls would not dim correctly. It still might be worth it...
I think the BIM unit is screwing up everything. I am so close to taking it out and throwing it away, and just wiring everything the way the STI is. Almost everything on the STI is directly wired, with no ridiculous modules to get in the way.
I will give it another try in a few days. For now, it is wired with a 50k pot...although I think a lesser ohm pot would work.
Old 01-25-2008, 05:29 PM   #89
subaru_west
Member#: 151373
Chapter/Region: PRSIC
2006 wrx wagon
red
I put the sti cluster 07 in my wrx 06 . but the water temp watch not working.. whyy ?
subaru_west is offline   Reply With Quote
Old 01-26-2008, 12:59 AM   #90
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
edited for late night stupidity lol
Old 01-26-2008, 03:46 AM   #91
PulsedriveRS
Member#: 169441
Default water temp
Check the temp gauge when engine is warming up. It takes a while usually to warm up the car (especially at these temperatures). When the car is warmed up and the needle is still at C then the gauge is not connected right.
Old 01-26-2008, 11:54 AM   #92
RallyIt07
Member#: 158498
07 WRX w/ JDM 6spd
I have a question, how do we get the buzzer to work without clipping C9?
RallyIt07 is offline   Reply With Quote
Old 01-26-2008, 12:21 PM   #93
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
the rev buzzer works without C9 connected. I think C9 is a power source/return power source on the WRX, but on the STI it serves another purpose, which explains why the cluster buzzes when you plug it in. The tone of the buzz changes based on what features you are using at the time.
Old 01-26-2008, 03:07 PM   #94
PulsedriveRS
Member#: 169441
Default Buzzer
Why cut C9 ??
Old 01-26-2008, 03:10 PM   #95
PulsedriveRS
Member#: 169441
When B28 wire is moved to B16, what do you do to B16 wire then ???
Old 01-26-2008, 03:39 PM   #96
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
there is no B16 wire...
and you cut C9 because the cluster buzzes non-stop otherwise...probably because thw wire is adding unneeded power to the wrong place.
Old 01-29-2008, 09:37 PM   #97
RallyIt07
Member#: 158498
07 WRX w/ JDM 6spd
just did an 07 sti cluster in an 07 wagon..
Really easy:
  • Move B28 wire to B16. (Cruise)
  • Cut C9 wire (buzzer)
where did you get your cluster? I am having a lot of trouble tracking one down thats a 2007 for a 2007 wrx.
Old 01-29-2008, 09:41 PM   #98
RallyIt07
Member#: 158498
07 WRX w/ JDM 6spd
k I found a 2006 cluster would that work on an 07 wrx? (I would think it would just don't wanna rush before I spend that much and get no refunds)
https://www.subarugenuineparts.com/p...oducts_id=1129
also anywhere else that is less expensive than $550
thanks guys
Old 01-29-2008, 10:51 PM   #99
WRFX
Member#: 149789
I purchased mine on ebay with 3262 miles on it.
Old 01-29-2008, 10:52 PM   #100
WRFX
Member#: 149789
There are a few Clusters on ebay right now... http://search.ebay.com/search/search...ster&category0=
07 STI Longblock into 06 WRX turbofied Subaru Conversions 5 01-02-2015 01:44 PM
Swap 06 STi HIDs into 06 WRX Snowrider Electrical & Lighting 0 01-09-2008 03:12 PM
06 sti tranny into 02 wrx AWDWRXLOVER Subaru Conversions 5 05-02-2007 05:47 AM
06 Sti wheel into 02 wrx AdsWRX Subaru Conversions 0 02-19-2007 04:02 PM
06 sti tranny into 02 wrx scarsofterror Transmission (AT/MT) & Driveline 26 01-04-2007 09:13 PM
