Old 09-28-2001, 07:25 PM   #1
etam
Member#: 439
www
Default 75w90/75w90ns for 97GT??
Hi all,
I did a searh on trans. and rear diff oil and looks like redline 75w90 (3.7quarts) for rear and 75w90ns (0.7quarts) for front for WRX, can I use the same setup for my 97GT?
thx,
etam
etam is offline   Reply With Quote
Old 09-28-2001, 08:02 PM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
First, I think you have your numbers reversed. The transmission/front diff/center diff holds a helluva lot more fluid than the rear diff does.
Second, as you may have seen in your searching, opinions vary widely on which fluids to use. The rear diff is pretty much a no brainer - 75W90 is good to go. Even if you have a rear LSD, it's sealed, so you don't need special fluid.
The tranny is where it gets confusing. Some people have no problems with 75W90, others say that 75W90NS works better, others have had problems with 75W90 and 75W90NS, etc etc. Some guys swear they've used synthetic ATF with no problems, some say Motul synthetic is the way to go, blah blah blah. I tried a couple different brands (one kinda no-name synthetic that was all I could find, and then Redline 75W90, and then I think Mobil1 75W90 too) in my '99's transmission and my 3rd and 4th gear grinding worsened. So, with the '97 I've just stuck with regular Subaru fluid.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 09-28-2001, 10:54 PM   #3
Jason
Member#: 105
2000 Legacy GT Ltd
WHT
I called redline and asked which oil to use. They recommended 75W-90NS for front and 75W-90 for rear.
I used what was recommended and gears started to grin and I was very unhappy about it. I just never get a chance to see how bad it went before the car was totalled.
Now, I am using Mobil 1 75W-90 and time to time 4th to 5th gear will grin. Usually when rev it above 4K. So, maybe stock Subaru ones actually works the best.
Jason is offline   Reply With Quote
Old 09-29-2001, 12:03 AM   #4
etam
Member#: 439
www
thanks for all the reply!
Pat, thanks for your free tweeter!!
I will probably stay with subaru trans. oil then.
etam
WANTED: passenger foglamp for 97GT Lee MD Private 'Wanted' Classifieds 1 03-11-2009 01:16 PM
FS: Redline 75w90ns 75w90 transmission gear oil + MOTUL 15w50 motor oil bearbearbear VIC Private Classifieds 2 02-17-2007 05:01 PM
Is Redline 75w90NS and regular 75w90 (rear diff) the best gear oil for WRX? scoobbee Transmission (AT/MT) & Driveline 6 04-09-2006 02:21 PM
RS-T: 75W90 or 75W90NS or Shockproof? bensonwrx Normally Aspirated with bolt-on Forced Induction Powertrain 4 04-01-2002 11:24 PM
RL 75w90NS vs 75w90 fatVdub Transmission (AT/MT) & Driveline 2 12-04-2001 11:22 PM
