Old 03-21-2006, 02:35 PM   #1
pilfflip
Member#: 40484
'02 Murdered WRX
'02 Silver Legacy
Default head bolt torque specs
I'm getting ready to disassemble my engine for the head gaskted job.
I need to know where I can find the torque specs for the head bolts and it would be nice if i could get them for other fasteners on the egine as well. Does anyone know where I could get a spec sheet or download one?
...actually, a Chilton or Haynes should have that huh?
~Mike
pilfflip is offline   Reply With Quote
Old 03-21-2006, 04:03 PM   #2
Speedwagon
Member#: 19681
1998 Legacy Wagon GT
Green
Haynes has it. But it's not so much a spec, as a procedure/ritual.
Speedwagon is offline   Reply With Quote
Old 03-21-2006, 04:10 PM   #3
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
I can give you whatever torque specs you want. If you need anymore Just ask
Intake Manifold Bolts: 18 Ft Lbs
Crankshaft Bolt: 101 Ft Lbs
Camshaft Bolts: 61 Ft Lbs
Flywheel Bolts: 55 Ft Lbs
Timing Belt Idler Botls: 30 Ft Lbs
Timing Belt Tensioner (8mm Bolts): 18 ft lbs
Water Pump: 44 in lbs
Oil Pump: 44 in lbs
Cam Support or Rocker Shaft (8mm): 18 Ft Lbs
Loosen Headbolts in this order:
1 5 4
3 6 2
Tighten Headbolts in this order:
3 1 6
5 2 4
Following the tightening order, torque Head Bolts as following:
1. Torque All to 22 Ft Lbs
2. Torque all to 51 Ft Lbs
3. Loosen all 180 degrees
4. Loosen all 180 degrees
5. Torque Center Two bolts to 25 Ft Lbs
6. Torque Outer 4 bolts to 11 Ft Lbs
7. Tighten all bolts 90 degrees
8. Tighten all bolts 90 degrees again
Make sure you tighten all of them down the first 90* and then go back and tighten them another 90*. Also make sure you put some lube between the bolt and the washer, and put some sealant on the bolt threads. We use GM Thread Sealant.
wrx_driver_2002 is offline   Reply With Quote
Old 03-21-2006, 10:55 PM   #4
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
why the difference in torque readings from inner bolts to outer bolts? and why torque them down to 51 ft. lbs. and then back off to only 11 ft. lbs.? seems a little light to me but how the hell should i know. also, i heard that suby head bolts are stretch bolts and should be replaced when doing HG's. but ive also heard that that info is B.S. and some people use head bolts 5 or 6 times and nothing happens. any info is appreciated.
~Josh~
Old 03-22-2006, 12:22 AM   #5
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
~Josh~
I've never questioned Subaru's torque sequence. It does seem a little extensive and odd, but it's what the engineers found out worked best, plus it's always worked perfectly for me, so I've had no reason to deviate. When you torque subaru head bolts to the final torque specs, you're actually using angle torque (That's why you turn them all 90* once, and then 90* again after those low torque numbers) I would assume you are somewhere around 80 ft lbs on the center bolts and 70 ft lbs on the outer bolts by the time you're done with your angle torque steps. It would make sense to me that the angle torque compensates for the stretch of the bolt. I've only had to replace headbolts once, and that was because the person who put the engine together the last time didn't use any sealant on the threads of the bolts, and he didn't torque them down correctly so coolant got down into the threads and rusted the bolts.
Old 03-22-2006, 01:32 AM   #6
ballitch
Member#: 74907
98 cam'd EJ251
good to know, thanx.
~Josh~
Old 12-27-2014, 10:27 AM   #7
2003wrx64
Member#: 171615
2003 WRX
No sealant is needed on the head bolts. The Subaru manual says to use engine oil to lube the bolt. Always lube the whole bolt, including the threads and both sides of the washer. Heavier oil works best. The only way coolant can get to the bolts is if the head gasket is already failing. The initial torquing of the head bolts is to compress the head gasket. This insures that the final torque sequence is accurate and not just compressing the gasket. If the bolts creak and pop while torquing, you need more lube on the bolt. If you are at the beginning of the torque sequence when the bolt creaks, start over from the beginning after relubing the bolt. If the bolt creaks after you have started the final torque procedure (25 lbs-ft on the center bolts, 11 lbs-ft on the outer) restart the procedure at the point where you loosen all bolts 180 degrees and all bolts again 180 degrees. In case of a stubborn creaking bolt, a bit of anti-seize usually does the trick. Also, make sure the bolt holes are super clean before beginning. Brake clean and compressed air work best. If you don't have compressed air, allow plenty of drying time after brake-cleaning the holes.
2003wrx64 is offline   Reply With Quote
Old 12-27-2014, 10:48 AM   #8
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Hopefully the OP hasn't been waiting for almost 8 years until someone provided that information.
Old 12-30-2014, 09:13 AM   #9
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
True statement.......
Do the NA guys still use the FI torque specs for the HG's? It's what I started doing a long time ago once the "new" (back then) HG's came out.
Old 01-26-2016, 09:41 PM   #10
SR 25 RS
Member#: 97983
2008 STi hatch
I learned a valuable lesson about inch pounds
Inch pounds VS foot pounds. Be warned future folk, pay attention to the spec measurment unit lol
SR 25 RS is offline   Reply With Quote
Old 01-27-2016, 08:38 PM   #11
Hardware BoB
Member#: 429778
That sounds like an expensive mistake!
Hardware BoB is offline   Reply With Quote
head bolt torque specs and pattern?? sekretskwirl Built Motor Discussion 8 03-02-2014 11:37 PM
Head Bolts & Cams Bolts Torque Specs Imprezd Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-20-2003 07:30 AM
A/T oil pan bolt torque spec? GPH993 Transmission (AT/MT) & Driveline 1 02-24-2002 05:17 AM
2002 2.5 RS bolt torque specs jdsimpreza Normally Aspirated Powertrain 0 02-12-2002 10:10 PM
Bolt torque spec, coilovers ????? Branwell Brakes, Steering & Suspension 5 10-19-2001 05:53 PM
