Old 03-21-2006, 05:49 PM   #1
dchou
Member#: 39137
2005 PSM STi
Thumbs up Kartboy rear endlinks installed on 05 STi:
Just wanted to review the Kartboy rear endlinks for the 05 sti. I installed these endlinks about 2 weeks ago and they are great. The install is very simple and these endlinks are quality. I got the pair from Turn in Concepts for $100. I also have Whiteline adjustable sways in the rear.
After initially installing them I found that there was a "clunk" that I could feel coming from the left rear side. I re-torqued all the nuts to 36 lbs, but the thump was still there when I came to a stop. I emailed Tom and he said that some of the initial endlinks that were sent out didn't get grease between the rubber bushing and the metal sleeve. So he recommended that I push out the metal sleeve and put some lube on there. I followed his recommendation and now it is quiet and thump free
Install was super easy. I followed the install directions on scoobymods written by peaty. http://www.scoobymods.com/forums/showthread.php?t=6181
I needed a 16mm box wrench for the outside bolt and a 17mm deep socket for the inner nut. Install took me 20 minutes with hand tools. If you have air tools it would take you probably 5 minutes.
These endlinks are great! They are a little longer than the stock endlinks, which will prevent the swaybar from flipping. And I don't have to every worry about a bent/broken endlink.
left side(driver)
right side(passenger)
right side
-Dave
dchou is offline   Reply With Quote
Old 03-21-2006, 10:08 PM   #2
Vikingmoose
Member#: 50319
2006 STI
I can't view the pics you posted, but I assume they are the new pillowball endlinks? If so, what did you use for grease? I might need to grease my endlinks since they are clunking like a mo-fo.
Vikingmoose is offline   Reply With Quote
Old 03-22-2006, 01:45 AM   #3
dchou
Member#: 39137
2005 PSM STi
Fixed the pics.
Old 03-22-2006, 08:50 AM   #4
conker69
Member#: 59692
2005 Impreza WRX STi
WRB-Gold
Nice. I have the same endlinks but with COBB bars. Mine have been awesome so far!!
conker69 is offline   Reply With Quote
Old 03-22-2006, 12:05 PM   #5
STix66
Member#: 104433
2016 Mercedes - GLE
past cars-06 STI /13 WRX
Conker69 do you get clunking with the endlinks and the Cobb rear sway?
Just curious I got the front/rear going on soon and I will be lowered on Prodrives.
Thanks,
STix66
STix66 is offline   Reply With Quote
WTB (NC): WRX Whiteline Adj. Rear Sway bar/Kartboy Rear Endlinks jstalford Private 'Wanted' Classifieds 0 08-26-2009 09:26 PM
Tein Front Camber Plates, Kartboy Rear Endlinks, Perrin 25mm Rear Sway for WRX mrtrex Suspension/Brakes/Handling 35 01-11-2008 10:04 AM
Progress rear sway, kartboy rear endlinks, MRT front sway, noltec front endlinks andrewp724 Suspension/Brakes/Handling 37 01-10-2007 06:04 PM
Kartboy Rear Endlinks + Whiteline Rear Sway Bar Drav Brakes, Steering & Suspension 9 09-27-2005 04:36 PM
Help: Just installed Hydra on 05 STI: throttle feels unnatural syoung0298 Other Engine Management 4 07-14-2005 04:33 PM
