Old 03-21-2006, 05:45 PM   #1
mpadovano
Member#: 71477
2005 WRX STI
Default What should i be injecting
Hi All,
I am currently planning on getting some sort of injection for my 05 sti. I was curious if i should use water and methanol 50/50 or denatured alcohol and water 50/50 i can get denatured alcohol for about the same price as methanol. Is one better than another?
Please Advise
mpadovano is offline   Reply With Quote
Old 03-21-2006, 06:22 PM   #2
Ultimate Collision Center
Member#: 69072
Best bang for buck is usually water/methanol at about 2 dollars a gallon with great results. It is what I use for daily driving.
Ultimate Collision Center is offline   Reply With Quote
Old 03-21-2006, 09:57 PM   #3
mpadovano
Member#: 71477
2005 WRX STI
Where do you purchase Methanol? I can get denatured alcohol pretty easy but haven't run across Methanol yet.
I am pretty much asking if one is better than the other regarless of price.
Old 03-21-2006, 10:03 PM   #4
Member#: 69072
Methanol is slightly better and you can usually find it for cheap (3 dollars a gallon). Check your local speed shops and/or local farms.
Old 03-21-2006, 10:04 PM   #5
Member#: 69072
I just saw that you are from NJ, is that NNJ, if so I can put you in contact with a guy who sells it.
Old 03-22-2006, 12:32 PM   #6
mpadovano
Member#: 71477
2005 WRX STI
I am from the Edison area...how far north is the guy you know?
Old 03-23-2006, 11:55 AM   #7
wrx904
Member#: 97365
2015 Mustang PP SC
How is it slightly better, doesn't denatured alcohol have a higher octane?
wrx904 is offline   Reply With Quote
Old 03-23-2006, 12:37 PM   #8
Member#: 69072
I believe methanol has an approximate octane rating of 99 while denatured alcohol (ethanol) has a octane rating of 100. I will try to dig up the info on meth vs ethanol when I get a chance. The price alone I would run methanol over denatured alcohol.
Old 03-23-2006, 07:47 PM   #9
wrx904
Member#: 97365
2015 Mustang PP SC
I agree about the price, denatured alcohol is $13 a gallon. I thought that I read on here somewhere that denatured alcohol is around 116oct, I'm not sure.
Old 03-23-2006, 08:58 PM   #10
mpadovano
Member#: 71477
2005 WRX STI
According to this website, Ethanol has an Octane level of 118. (Last Paragraph)
http://www.midatlanticbiofuels.com/ethanol_market.htm
Old 03-23-2006, 09:06 PM   #11
Member#: 69072
Interesting, I too have been doing some more research and have been finding a couple different values for both. Hopefully I can find a definitive answer at some point.
Old 03-23-2006, 09:50 PM   #12
Absubtle
Member#: 85862
From my past experiences, methanol is a corrosive beast. Ethanol is still corrosive, but not nearly as severe. Also, as far as drag racing.. ethanol has a better rating as for as consumption VS menthanol. Menthanol is alittle too light and needs a considerable amount of 'weight' to process the same-amount of 'need' for fuel requirements, as ethanol can produce. Let's just say 116 octane gasoline would use at least a 1/4 LESS fuel to produce the same about of power. 116 is, what, $6.00 a gallon........methanol was $1.20 a gallon.. just takes alittle more to produce the same power for the same amount of time as the 116 or other gasoline fuel. (But you start looking into the cooling effect of using alcohol as a fuel, so your intake air temps go down, your engine temp is lower, your detonation level is a lot lower... that is why it's cool to burn alcohol!). Ethanol is slightly better, in consumption per fuel amount required, but a lot better, in the corrosive aspect.
As far as a 50/50 combo w/ water. I like rubbing alcoho (Iso alky) w/ water. Very hard to find Meth or eth or even Race gasoline.
You can go to Sam's Club and by huge bottles of 70% and 90% of Alcohol... so depending on what you choose.. you may be able to use less water.. since this alcohol has a percentage added-in.
W/ my water injection, I just use 40% water and 60% rubbing alcohol, 70%, (from walwart). If I truely needed required fueling needs, I would switch to ethanol... and do a 50/50.
Absubtle
PA
Absubtle is offline   Reply With Quote
Old 03-24-2006, 08:44 AM   #13
Rexfan
Member#: 50993
02 WRX Wagon
2.5/Blouch Dom 3/Meth/6sp
Is it true some people run window washer fluid?
Rexfan is offline   Reply With Quote
Old 03-24-2006, 11:03 AM   #14
Member#: 69072
yea but its more like running water injection since the water content is so high in most cases
Old 03-24-2006, 01:07 PM   #15
Rexfan
Member#: 50993
02 WRX Wagon
ok, I understand, thanks for that.
Old 03-24-2006, 01:42 PM   #16
WRX-ERROR
Member#: 83211
2002 WRX - stg4
Absubtle I didn't know anyone from WB was running injection.. I would love to see your setup as I am planning to runn injection this summer.
WRX-ERROR is offline   Reply With Quote
Old 03-24-2006, 01:45 PM   #17
natoli4
Member#: 66668
2002 wrx wagon
blk
Meth/water is what I'm running. from what I understand from Harman Motive you can tune more agressively with alcohol...more HP's. I've only seen a 25hp increase with meth/water and I understand that you can get around 35-40hp's with a alcohol map. I think...
natoli4 is offline   Reply With Quote
Old 03-24-2006, 02:11 PM   #18
Member#: 69072
I will be getting tuned by TurboXS as soon as they release their new map software. Two pump gas maps, two 50/50 methanol/distilled water mix and a 100 methanol map. I will post results when I get them.
Old 03-28-2006, 12:53 PM   #19
testes1010
Member#: 47145
2012 Gas Saver
you can also source methanol at WALMART, HEET in the yellow bottle is 99% methanol...I've been running a 50/50 mix since November...
testes1010 is offline   Reply With Quote
Old 03-28-2006, 04:16 PM   #20
edmundu
Member#: 54672
A1 Racing in Paterson, NJ carries/sells Sunoco Methanol, as well as their race fuels. Good prices too!
edmundu is offline   Reply With Quote
Old 11-16-2006, 11:27 AM   #21
awdrocks
Member#: 114961
2002 Blown Explorer
awdrocks is offline   Reply With Quote
Old 11-16-2006, 02:21 PM   #22
oldhat
Member#: 113036
Just out of curiosity, when people say they're injection "alcohol" instead of methanol do they mean they're injecting pure ethanol? Isopropyl alcohol? Denatured alcohol (which is usually cut with methanol)?
oldhat is offline   Reply With Quote
Old 11-16-2006, 02:43 PM   #23
snwman
Member#: 72680
2013 Subaru STi
Satin White Pearl
ohhh, does age affect this stuff, there is like 20+ bottles in my parents garage.
snwman is offline   Reply With Quote
Old 11-16-2006, 04:54 PM   #24
oldhat
Member#: 113036
Methanol is uber-stable and won't degrade, so long as the bottles are still sealed.
Old 11-16-2006, 05:04 PM   #25
PolarisSnT
Member#: 85905
2004 WRX
I run 100% denatured alcohol in my setup. I went from 300whp to 340 whp with adding the alcohol. I like using denatured because its easy to find. Its alittle expensive at Home Depot but its convenient and thats all that matters. I only use a gallon every 2-3months so $13 isnt that bad to me and its not like I baby the car. Its been 2 months and Ive been to the track and a dyno session and havnt used an entire gallon yet.
PolarisSnT is offline   Reply With Quote
ALK is installed now what should I be testing? Heather Brakes, Steering & Suspension 8 06-24-2003 09:27 PM
what should i be running? ellinopedo182 Proven Power Bragging 7 05-27-2003 01:07 PM
Installed A/F Meter...what should it be doing? 2000vfr800 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 08-08-2002 09:50 AM
Next Meet/Event - what should it be? Subie Gal North West Impreza Club Forum -- NWIC 42 05-02-2002 08:27 PM
Next SCIC Meet: What Should it be? You Take the Poll karazyman Southern California Impreza Club Forum -- SCIC 0 04-30-2002 10:43 PM
