Welcome to the North American Subaru Impreza Owners Club Thursday April 28, 2016
Old 02-20-2015, 11:46 AM   #1
Moejazzur
Member#: 411305
2004 WRX
Java Black Pearl
Default runaway subaru engine
This morning it was -3. When i started my car it did its normal procedures, along with lots of strange sounds just because its so cold. Usually the engine idles at 1800 rpms and drops to 1500 after about 2 minutes. Instead of slowing down after those 2 minutes it slowly started to climb to about 3000 rpms so i shut the car off. After restarting it didnt do it again. Stock 2004 wrx. No i did not have my foot on the gas.
Sometimes when im driving while its warmed up and im at a stop light it will idle at about 1200 rpm. Usually its at 600.
Can anyone shed some light on this? Thanks.
Moejazzur is offline   Reply With Quote
Old 02-20-2015, 12:13 PM   #2
m71owner
Member#: 332321
1998 2.5rs
wrb
Search a little bit this is on here quite a bit. I know that's not the answer you want to hear but that's what I got haha.
m71owner is offline   Reply With Quote
Old 02-20-2015, 12:48 PM   #3
axelthrasher
Member#: 144779
200X ZOMG a car 100%
crabon fibre girlfrendorz
Check your throttle cable, it may be slightly out of adjustment. Make sure there is play in both cables (upper and lower), if you have either one taut, you get some weird partial open TB issues.
axelthrasher is offline   Reply With Quote
Old 02-20-2015, 12:52 PM   #4
DatGriff
Member#: 371326
Try cleaning your IACV on the throttle body. Just be careful with the screws. They're ridiculously soft. I'd recommend getting replacements from the hardware store honestly. There are a couple threads about it with pictures.
DatGriff is offline   Reply With Quote
Old 02-20-2015, 02:24 PM   #5
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Idle air control valve, clean it.
Old 02-20-2015, 04:52 PM   #6
2004wrxy
Member#: 237136
2003 WRX 6MT
JBP
This ^^^
and this...
http://forums.nasioc.com/forums/showthread.php?t=781242
2004wrxy is offline   Reply With Quote
