Old 04-26-2006, 05:35 AM   #26
ASpec818
Member#: 37059
03 WRX
World Rally Blue
does anyone have a diagram of a turbo that describes where is the "oil outlet hard pipe" and the "oil return hard pipe"? I'm kinda confused on what's what in terms of those hard pipes that are sticking out on my vf39 I'm going to install into my 03 wrx.
Also, in what step would the uppipe install come into play? Would it be where you removed the 3 14mm bolts that hold turbo on uppipe flange?
ASpec818 is offline   Reply With Quote
Old 05-08-2006, 07:40 PM   #27
prspect06
Member#: 33223
2003 '03 WRX Vf39
blue pearl
How many gaskets are there for the turbo install? I want to make sure I get all new gaskets. There is one that connects the dp to the turbo and one that connects the uppipe to the turbo.
That's 2 total.
Are there any others I need?
prspect06 is offline   Reply With Quote
Old 05-08-2006, 08:49 PM   #28
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
You probably won't need new gaskets during turbo install. Majority of people reuse stock gaskets without much problem. Mine had over 60k miles and was still in excellent condition.
Old 05-08-2006, 09:57 PM   #29
prspect06
Member#: 33223
2003 '03 WRX Vf39
blue pearl
Thanks for the advice...but I don't mind spending the extra money. So are there a total of 2 gaskets needed?
Old 05-08-2006, 10:12 PM   #30
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Yes, there are two gaskets. Good luck with the install.
Old 05-08-2006, 10:30 PM   #31
quicksilv3r
Member#: 114480
02 wrx
nice write-up thank's for sharing.by the way why didn't you get new gasket?i hope there wont be any leak.
quicksilv3r is offline   Reply With Quote
Old 06-02-2006, 02:42 AM   #32
prspect06
Member#: 33223
2003 '03 WRX Vf39
blue pearl
What's the best way to plug up the coolant lines on the turbo?
Old 06-02-2006, 03:23 AM   #33
thetikler1
Member#: 24096
2011 Outback/WRX
just unplug them and put them vertical as fast as you can to avoid spilling the most coolant. We never figured out a good way to do this as cleanly as possible. at least thats my exp. in 5 turbo installs. just put more coolant back in and burp it via radiator hose (edit: when done installing everything)
^^correct me if i've been doing this wrong the whole time.
thetikler1 is offline   Reply With Quote
Old 06-02-2006, 10:28 AM   #34
prspect06
Member#: 33223
2003 '03 WRX Vf39
blue pearl
Should I disconnect the top coolant line on the turbo first and then the bottom coolant line? Won't there still be coolant inside the turbo that will leak out of the hardlines or do I just worry about the soft hoses?
Old 06-02-2006, 10:35 AM   #35
MF-DIF
Member#: 62197
2002 PSM WRX
LG/Blurple FZ-09
Yes coolant will still leak out of the turbo. You will not be able to do it cleanly. It doesn't really matter though. You just refill as needed.
The oil return line is the one directly on the bottom of the turbo pointing down. If you are replacing this, you will need an additional gasket.
MF-DIF is offline   Reply With Quote
Old 06-02-2006, 10:38 AM   #36
prspect06
Member#: 33223
2003 '03 WRX Vf39
blue pearl
I have the oil return line gasket already. Do I have to worry about losing oil when changing out the turbo?
I want as clean as an install as possible. I was thinking about just shoving a lot of towels towards the base fo the turbo.
Old 06-02-2006, 11:19 AM   #37
MF-DIF
Member#: 62197
2002 PSM WRX
LG/Blurple FZ-09
The turbo will be empty of oil. It drains out when the car is not running.
Old 06-03-2006, 02:58 AM   #38
thetikler1
Member#: 24096
2011 Outback/WRX
just put newspaper and some towels under the general area of the turbo/coolant and it'll catch most of it. it sucks but its messy
i.e. on the floor etc, there is no way to get around it really
Old 06-08-2006, 11:07 PM   #39
prspect06
Member#: 33223
2003 '03 WRX Vf39
blue pearl
I'm planning to do fuel pump, injectors, and turbo all at once with my brother. If I leave the car sitting for a couple of days, will the fuel depressurize enough so that it won't spray all over the place? He's gonna be doing the fuel pump while I work on the turbo and injectors.
Old 06-08-2006, 11:20 PM   #40
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
There is a proper way to depressurize the system by pulling a plug by glove box. However, I never had problem of fuel spraying all over the place...
Old 06-09-2006, 01:34 AM   #41
benw
Member#: 103320
1998 swapped
Forester L
yes. I didnt depressurize. Parked the car, let it cool for about 45 minutes while I set up my work space, and then started with the exhaust, then the turbo. After those were complete I started on the GBODs and finally the injectors. System was out of pressure by then and no spraying fuel.
benw is offline   Reply With Quote
Old 06-09-2006, 03:03 AM   #42
prspect06
Member#: 33223
2003 '03 WRX Vf39
blue pearl
I'm more worried about the fuel pump. Any problems with that?
Old 06-24-2006, 03:55 PM   #43
benw
Member#: 103320
1998 swapped
Forester L
fuel pump is quite easy, you just have to be careful as it is a complicated apparatus and don't want to bend anything. Changing the actual pump in the bracket took about 2 minutes.
To depressurize the system before installing my 255 pump, I unhooked the power from the fuel pump while the car was running via the white harness.
Old 08-05-2006, 12:02 AM   #44
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
in fact, I never had to depressurize the system when I installed fuel pump... never had any problem of fuel spraying all over the place. Maybe tiny 100mL of fuel spilled over...
Old 08-05-2006, 04:27 AM   #45
Highway Drifter
Member#: 81013
very nice write up man
Highway Drifter is offline   Reply With Quote
Old 08-05-2006, 04:47 AM   #46
Hallis
Member#: 94141
Platinum Silver Metallic
+1
this took away much of my fear of doing a swap. The injector swap looks to be more of a pain.
Shane
Hallis is offline   Reply With Quote
Old 08-05-2006, 09:50 PM   #47
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Yeah, it is not as difficult as you might think. All you need is right tools and patience. Just take time and watch out for any leaks post install.
Old 08-05-2006, 11:01 PM   #48
dingobite
Member#: 82391
08 OBP Sti
dom 2.5xt-r 384hp 412tq
Took me a little over 3 hours on the injectors fun stuff just have to remember the car doesnt start next time if theres any lost bolts in the engine bay.
One more thing that makes the turbo super easy to install is replacing the oil line hose clip down below the uppipe. I could never get that thing to stop sliding back down the oil line every time i push the turbo in place. Major PITA
dingobite is offline   Reply With Quote
Old 08-05-2006, 11:05 PM   #49
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
having small hand really helps...
Old 08-06-2006, 03:30 PM   #50
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
Good write up, txl146.
WRXRallyBlue is offline   Reply With Quote
Will a OEM Flywheel for a 2.5L fit on a 2.0L WRX? em199si Transmission (AT/MT) & Driveline 13 11-23-2010 08:23 AM
'05 2.0L WRX VF34 dyno results Acingteam Proven Power Bragging 17 01-07-2009 01:58 PM
Will coilpacks from 2.5L WRX or STI fit on 2.0L WRX? gopsu Service & Maintenance 7 10-08-2008 11:31 AM
2.0l wrx with vf34 kmt Proven Power Bragging 26 06-01-2007 11:36 PM
2.5L Oil Pan on 2.0L WRX theostubbs Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-20-2006 09:02 AM
