Old 08-07-2006, 12:46 AM   #51
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Driving impression after 5 months of driving on VF34 (only 3000 miles!)
- Protune at XX-tuning resulted: 32whp and 35 wtq over OTS map (Cobb stage 2.5)
- Acceleration is slightly faster than stage 2 until 2nd gear, but car really starts to pull away from stage 2 WRX starting 3rd gear and on.
- spool is roughly 400rpm+ slower than TD04.
- My car gets better mileage since turbo is not used as often (slower to spool).
- My driving style has completely changed to accomodate for additional power (60+ whp). I check for engine oil weekly to watch for potential oil starvation before any spirited drive.
- No aggressive launch ever since turbo upgrade.
- No longer afraid of high trap speed cars like Accord V6, stock SRT4, 350Z, S2000 at the track (1/4 mile).
Old 12-10-2007, 02:12 PM   #52
Fahren
Member#: 105016
2005 FXT
CGM
Originally Posted by txl146 View Post
By gently bending the oil hard line, align it and use 14mm bolt to connect to turbo (circled in RED). Be sure to use a washer while putting it back on.
washers on both sides of the hardline?
Fahren is offline   Reply With Quote
Old 12-10-2007, 03:40 PM   #53
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
IIRC, just on one side....
Old 01-15-2008, 12:18 AM   #54
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Update after 18k miles since the install:
So far everything feels great and car put down similar whp when I went for a retune (same at ~280whp) today.
With german castol oil, car is no longer losing oil, which has been an issue with M1. In my opinion, VF34 is definitely a great turbo for a DD, especially with a custom tune.
Old 04-18-2008, 11:54 PM   #55
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
bump for people looking to step up to stage 4!
Old 04-19-2008, 03:03 PM   #56
speedbuggy67
Member#: 9041
blaze yellow 1-450
lol always was a good post and im always looking to go stg 4 my 39 has sat on my shelf for 2yrs already.... One of these days...
Scott
speedbuggy67 is offline   Reply With Quote
Old 10-30-2008, 03:23 PM   #57
bolderer
Member#: 115633
06 protuned vf-34
wagon
I'll be replacing my blown vf39 with a vf34 this week. I did the last swap by myself as a total noob and had no problems but writeups like this one were the reason it was so simple. This time I'll at least have a buddy there to hand me tools/beer while I work. Thanks a lot for taking the time to make this write-up.
Edit: BTW, Oil inlet banjo bolt has TWO washers. One on the top, one on the bottom.
bolderer is offline   Reply With Quote
Old 10-30-2008, 04:32 PM   #58
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Good luck with the swap. Thanks.
Old 11-12-2008, 05:37 PM   #59
wrxtacular
Member#: 181711
2004 278whpVF34wagon
Jorge Tuned
Just did a VF34/pink injectors swap a few weeks ago (thanks for the write up). I still had a catted uppipe in my stage 2 set up, and I changed that out for an STi uppipe (catless) at the same time as the swap. For me, there wasn't much difference in lag between a stage 2 w/ catted uppipe and VF34 with catless uppipe, but the difference in power is amazing. All did not go well with my swap, so learn from my mistakes:
1) use NEW injector rubber o-rings/gaskets (my pinks were only used for about 1000 miles before I bought them, but I still had problems with a leaky injector)
2) watch out for the TGV sensor! Its a little black sensor that sits between the turbo and the engine, and if you smack it with the turbo or a tool, you will break it (and it is a PITA to replace once you have the turbo back in)
wrxtacular is offline   Reply With Quote
Old 01-05-2009, 04:00 PM   #60
WRXerist
Member#: 20235
2006 FX45
Subscribed
WRXerist is offline   Reply With Quote
Old 01-05-2009, 06:50 PM   #61
felixk
Member#: 188019
2004 Audi S4
awesome write up, got my through my vf39 swap last week. also used his injectors write-up to do those. thanks!
felixk is offline   Reply With Quote
Old 03-25-2009, 12:42 AM   #62
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Photobucket placed a monthly limit on bandwidth... photos will re-appear in April again.
Old 03-25-2009, 02:13 AM   #63
snowlovinrex
Member#: 192406
02' bugeye wagon
mbp
You mean April?
snowlovinrex is offline   Reply With Quote
Old 04-02-2009, 01:26 AM   #64
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
pictures are finally working!
Old 04-02-2009, 03:22 PM   #65
AlucardR
Member#: 54213
Thanks for your contribution
AlucardR is offline   Reply With Quote
Old 07-23-2009, 12:54 AM   #66
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
One thing I should mention is to use new gaskets when replacing turbo. I think one of my gasket maybe shot after 90k miles (could be any of pre-turbo gaskets).
Will find out soon as I plan to install Grimm speed crossover pipe shortly.
Will do write up on Xover pipe.
Old 03-03-2010, 01:00 AM   #67
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Update after 25k miles since the install of VF34:
Since the install of VF34, I have upgraded STI TMIC to TXS TMIC. Car was retuned after installing TXS TMIC.
Car put down 301whp with VF34 at 16psi. Could have made >20 more hp, but we decided to leave it at moderate 16psi. I think VF34 is a great little turbo for 2.0L WRX.
Old 03-03-2010, 01:47 PM   #68
PCrowlz
Member#: 215260
12 WRX STi
PBP
Really nice writeup. This will come in good use for me someday.
PCrowlz is offline   Reply With Quote
Old 03-03-2010, 03:19 PM   #69
jstalford
Member#: 175819
2006 Rav4
how many total miles are on your car now?
jstalford is offline   Reply With Quote
Old 03-03-2010, 05:15 PM   #70
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Around 95k miles - 25k miles @ >280whp power level with original glass transmission.
Old 03-03-2010, 05:29 PM   #71
jstalford
Member#: 175819
2006 Rav4
Sweet. I went stage 2 at ~75k and then Added a Grimmspeed 3 port and TurboXS TMIC and protune at ~90k. Doing an inlet/after MAF tube and ported heads/crosspipe soon. This makes me feel better about doing a turbo upgrade soon, with higher miles. I'm at 107k now.
Old 03-13-2010, 09:44 AM   #72
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
jstalford, I also had exhaust manifold ported by GS right before Justin started his business.
Old 06-14-2011, 02:55 PM   #73
Adamthomas625
Member#: 264401
I think I need to get an upgraded turbo inlet hose. When I drove around I could hear this air sucking noise (barely noticeable), which appears to be coming from turbo - turbo inlet hose. When I put in the VF34, I noticed that turbo inlet hose where clamp sits was worn out.
I think stock hose may be worn out or maybe I am mistaken for a noise coming from resonator removal mod since VF34 turbo is sucking more air in. I was planning on getting a turbo inlet hose anyway. It gives me another reason to write up a procedure for turbo inlet hose.
Nice write up. I also found that my inlet hose was very worn out. I have a new one on the way. When it gets here and I put it all back together I will let you know if it starts haha I used your writeup on injector and turbo install. I just hope my injectors don't leak. If they do it will be a Pain to take them out and solve the problem
Adamthomas625 is offline   Reply With Quote
Old 08-12-2011, 12:48 AM   #74
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Adamthomas625, how did your install go? I installed Perrin v2 turbo inlet hose and it fit like OEM hose.
Old 08-12-2011, 08:52 AM   #75
SubieLuvin
Member#: 248202
2013 WRX Sedan
Subscribed. Rocking a pnp vf34 and pinks myself. Love it! Getting money together for grimmspeed exhaust manifold crossover pipe and ewg setup!
SubieLuvin is offline   Reply With Quote
Will a OEM Flywheel for a 2.5L fit on a 2.0L WRX? em199si Transmission (AT/MT) & Driveline 13 11-23-2010 08:23 AM
'05 2.0L WRX VF34 dyno results Acingteam Proven Power Bragging 17 01-07-2009 01:58 PM
Will coilpacks from 2.5L WRX or STI fit on 2.0L WRX? gopsu Service & Maintenance 7 10-08-2008 11:31 AM
2.0l wrx with vf34 kmt Proven Power Bragging 26 06-01-2007 11:36 PM
2.5L Oil Pan on 2.0L WRX theostubbs Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-20-2006 09:02 AM
