Old 03-21-2006, 08:21 PM   #1
WRXDriftR
Member#: 65065
04 WRX/ STi Hybrid
6MT, VF43
Default EGT Sensor (uppipe) with AP Stage2??
Hey,
Im currently running AP stage2 on a 2004 wrx. I have an STi catless uppipe with no EGT sensor plugged in. There is the resistor in the harness to keep the ecu happy (even if its not needed).
Im about to purchase the Scanmaster3 from Full Throttle and it would allow me to read Exhaust Gas Temps...if i had the sensor still in the uppipe.
Heres my question: does the AP stage2 programming cancel out all signals from this sensor or does it just ignore the CEL that the EGT sensor throws?
If i took my stock EGT sensor and had a hole tapped in my exhaust header, could I hook it back up so the ECU gets signals from it again? Will the Scanmaster then be able to read the realtime EGT readings??
I hope my theory is correct that it will work.
Any help is appreciated!
Thanks,
~Chris
EDIT:
P0545 - Exhaust Gas Temperature Sensor Circuit Low
P0546 - Exhaust Gas Temperature Sensor Circuit High
P1301 - Misfire Detected (High Temperature Exhaust Gas) **
P1312 - Exhaust Gas Temperature Sensor Malfunction **
P1544 - Exhaust Gas Temperature Too High **
These are the codes defeated under Stage2 mapping. It says nothing about removing normal functioning signals from the EGT sensor, so i assume it will work to re-install it in the exhaust header.
WRXDriftR is offline   Reply With Quote
Old 03-21-2006, 08:28 PM   #2
Call_me_Tom
Member#: 60972
It turns off the CEL warning.
The ECU wouldn't read it properly as it is assuming the signal is coming from your UP and not your header. Get a aftermarket sensor and use that with a gauge or something simular but not with the ECU.
Don't know that one.
Call_me_Tom is offline   Reply With Quote
Old 03-21-2006, 08:29 PM   #3
Quack
Member#: 57264
2004 18g Wagon - WRB
PDX Tuned - 329whp/315wtq
teh AP sets the EGT value to an appropriate level. i don't know if you can work around the AP's "fix"
Quack is offline   Reply With Quote
Old 03-21-2006, 11:58 PM   #4
WRXDriftR
Member#: 65065
04 WRX/ STi Hybrid
6MT, VF43
ok, ill probably get a standalone EGT sensor and gauge then. hmmm....
Old 03-22-2006, 09:15 AM   #5
Hawke
Member#: 25777
Wrong, the AP only prevents the CEL from comming on. The AP does not mess with the readings. If the scanner can read the EGT values on a stock car it will one with the AP installed.
Hawke is offline   Reply With Quote
Old 03-24-2006, 12:58 AM   #6
distorto
Top Scoob 024
Member#: 56364
RIP stompr :(
bagged vulvva
if you can find a egt sensor without a gauge, you can plug it into the scanmaster...
distorto is offline   Reply With Quote
So I raced a stage2 06 WRX with AP kirkeemonster UTEC 16 11-25-2006 12:15 AM
EGT sensor out with perrin uppipe, egt simulator??? XWRATED Factory 2.0L Turbo Powertrain 10 09-04-2006 02:28 PM
Help again! flashing cel now with cobb dp and ap stage2 base map Chigliakus Factory 2.0L Turbo Powertrain 0 12-18-2004 10:33 PM
Blitz intake with AP stage2 kefiristan Engine Management & Tuning 6 05-28-2004 06:34 PM
Trouble with DEFI EGT sensor assembly. tuca33 Factory 2.0L Turbo Powertrain 14 02-28-2003 11:42 AM
Message Board Statistics All times are GMT -4. The time now is 04:36 PM.
