Welcome to the North American Subaru Impreza Owners Club Wednesday July 29, 2015
Old 03-21-2006, 08:46 PM   #1
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
What's A Head Gasket?
Default Engine Management for a JDM swap
What kind of engine management is possible with a Ver7 swap into a 2000 2.5rs?
What would everyone recommend.
Just for the record, it's staying with the stock vf30, stock everything else except for DP and Catback.
subydude is offline   Reply With Quote
Old 03-21-2006, 09:07 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
easiest is a ver 7 ecu
Old 03-21-2006, 09:21 PM   #3
subydude
Member#: 80649
I have the ECU, but what can I use for the reflash/tuning of the Ver7 Ecu?
Old 03-21-2006, 10:28 PM   #4
comradeboris
Member#: 33280
2005 STi
kingpin and others will do reflashes so that you can run on 93 octane so i dont see why they wouldnt be able to do an ecuTek tune to them...
comradeboris is offline   Reply With Quote
Old 03-22-2006, 01:36 AM   #5
Kotir
Member#: 17300
1993 Widebody Wagon
625whp e85
Kingpin and PDXTuning both have the Ecutek reflash licenses for the JDM STi ECUs (I'm sure others do but those are the ones I know off the top of my head) I'd imagine either one of em would have off the shelf maps for your setup but I could be wrong.
Newer revisions of the USDM WRX UTEC (5b and newer iirc) will work aswell but I believe the AUS WRX UTEC is the most "proper" (doesn't throw some codes? But that might just be the TGV stuff idk)
I have a PDXTuning Ecutek flash with my Ver8 ECU
Kotir is offline   Reply With Quote
Old 03-22-2006, 04:36 PM   #6
subydude
Member#: 80649
Did you send your ECU to them to get an OTS map, or did you drive there for the tune?
Old 03-23-2006, 11:53 AM   #7
tweakling
Member#: 33072
'95 EJ20g v1 STI RA
BRP, 2001 GC8 chassis
A place like Rally Performance would probably send you an identical ECU that's already been reflashed so that you can simply swap it and send yours back.
http://www.rallyperformance.com/EcuTek1.htm
tweakling is offline   Reply With Quote
Management for a strange swap - stand alone or carbs? mranlet Engine Management & Tuning 7 10-08-2004 10:58 AM
Engine management with an STi swap 17cTSi Engine Management & Tuning 13 07-12-2004 11:02 PM
engine management for EJ25 swap? RaceCarRiot Normally Aspirated Powertrain 8 03-24-2002 11:22 AM
AEM Engine Management for WRX!!!! mcu81 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 11-14-2001 02:50 AM
Engine managment for PE 1818 / 1820 Branwell Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 07-04-2001 11:09 AM
