North West Impreza Club
Go Back   NASIOC > NASIOC Chapters > North West Impreza Club Forum -- NWIC
Old 03-21-2006, 10:05 PM   #1
modaddict
Member#: 95840
sold to a good bud
awaiting next car
Default SMC, Aquamist, Coolingmist users in the N.W: chime in
I would like to know if anyone in the N.W here uses these systems. please let us know what kit you have chosen and who tuned your car.
Im looking at going with the smc kit, then going to pdx
modaddict is offline   Reply With Quote
Old 03-21-2006, 11:11 PM   #2
Ozer
Member#: 88062
I bought the coolingmist. It looks more advanced (you can program the flow at given PSI), and is more affordable. I got it from Mike @ InnovativeTuning. He is a very good guy.
Ozer is offline   Reply With Quote
Old 03-21-2006, 11:13 PM   #3
Ozer
Member#: 88062
I have a question though: where can we buy methanol?
Old 03-21-2006, 11:19 PM   #4
F-H
Member#: 79775
PDXTunig sell Aquamist and can tune on the dyno for it.
F-H is offline   Reply With Quote
Old 03-21-2006, 11:22 PM   #5
modaddict
Member#: 95840
sold to a good bud
awaiting next car
how do you mean more affordable? you mean because you dont have to buy alcohol? or a cheaper price to purchase the kit?
Old 03-22-2006, 02:03 AM   #6
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
I built my kit taking what i thought were the most important aspects from a few kits, before you even buy a kit learn everything u can about what it is doing, what WI does, what is, what it is not. Expectations for the systems need to be set before you go slap on on your car.
Token-Negro is offline   Reply With Quote
Old 03-22-2006, 02:03 AM   #7
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Well my car is setup with an Ecutek reflash so it has no built in ability to activate the WI so I went the route of using the Cooling Mist Boost Pressure switches, I wanted to have dual stage so installed two of these and set the levels on them at 10psi right above the WG only boost, and at 15psi. The car is tuned for 22psi total boost.
This is the pillar setup I installed, from the bottom up we have a gauge I know it says AIR pressure but really this is the water pressure of the system. Its set for a max of 100psi and drops to a low of 75psi before the pump comes back on. The red led is the low water indicator this is from the stock STI intercooler spray tank in the trunk. Next is the boost gauge the bottom light on this tree is when the pump is working and should be green along with the pressure going back up. The 2nd green light is the first stage opening up, the third light is when the second stage starts. These lights are wired into solenoids that are set closed until they get a ground from the Boost pressure switches.
You can see the solenoids in this picture along with the jets used.
The solenoids are also from coolingmist. I used high pressure tube used in air systems for the whole system it is accepted by the Washington State DOT so I figured it would be good enough for this project. Great push on style connectors. The water supply line teeís off to supply both solenoids adequate water. Then they run to the IC piping. Iím using the Auquamist jets as I found they are by far the best out there. The spray pattern is very fine and continuous and with the 25psi variance in pressure I found the spray to not deform greatly before the pressure came back up.
As for the pump im using the Shurflo 100psi 1.8 gpm along with an accumulator also from Shurflo so when the pump does come on the flow dose not spike the water jets. So far the system has worked very well and the car was tuned to 310whp with a FP 18g turbo with supporting mods by PDX tuning. There are many ways to add a safe guard to the system but what I have noticed is that when the light for the stage comes on the pressure needle on the gauge will fluctuate so I know for sure the solenoid opened up. In case of some system failure the D-tec allows me to turn boost to WG pressure witch is lower then when the WI system starts activating.
I just wanted to post up another way of building a system for your car.
Kendrick
Old 03-22-2006, 02:19 AM   #8
modaddict
Member#: 95840
sold to a good bud
awaiting next car
thankyou for your input kendrick....awesome setup!
Old 03-22-2006, 06:05 PM   #9
modaddict
Member#: 95840
sold to a good bud
awaiting next car
anyone else?
Old 03-22-2006, 07:18 PM   #10
entropy138
Member#: 87446
2005 STI
3 second start club
I'm joining the crowd as soon as my kit gets here - should have shipped the first of the week - SMC & Hydra on a green, txs tmic, and 850s...
Probably switching to a fmic soon but going to play w/ that setup for now...
entropy138 is offline   Reply With Quote
Old 03-23-2006, 07:06 AM   #11
Ozer
Member#: 88062
I meant the kit is affordable. Where can we buy methanol? PDX is pretty far away from me : )
Old 03-23-2006, 07:57 AM   #12
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
Is there anyone here using a standard Aquamist 1s?
-paK +2
Pakin is offline   Reply With Quote
Old 03-23-2006, 04:59 PM   #13
modaddict
Member#: 95840
sold to a good bud
awaiting next car
from what ive heard, you can get it at hardware stores. i havent actually gone and tried to buy it but ive done a ton of research about the smc kit and alot of people say they get it at home depot.
Old 03-27-2006, 03:34 PM   #14
Ultimate Collision Center
Member#: 69072
Farms and local speed shops are your best bet for alky. As a side note I suggest the Snow Performance kit as I am slightly biased . I don't want to make this sound like a sale so I will reframe my self as much as possible. There are several great kits out there (Snow, SMC, Aquamist, Coolingmist) you just have to looks at all the features and see what is best for you. I like the Snow Performance kit for its clean install, easy use and setup, great customer service, abiltity to run straight methanol, price comparably and ONE of few kits to have an actual failsafe (will have video shortly). I owned SMC before on my car but switched for reasons to Snow Performance. PM me for pricing if interested. Our kits have more features for the price.
Ultimate Collision Center is offline   Reply With Quote
Old 03-27-2006, 03:46 PM   #15
BREWPUBEAVER
Member#: 84547
06, Lafawnduh
Fender rolling king
Aquamist WI 2d complete kit, with the race pump and high-speed valve
Aquamist DDS3 blue bar water injection monitoring system.
i have yet to have my car tuned for the water/meth set up. there is a newer software release coming from UTEK that i am waiting for.
here is what i put down withOUT the water/meth, on 92*
so when i do get it all working *soon* i should have a few more ponies to the wheel`s
PdXTuning did all of the install.
BREWPUBEAVER is offline   Reply With Quote
Old 04-04-2006, 04:51 AM   #16
Ozer
Member#: 88062
What do you think about PDX? Are they good at tuning cars this modified?
Originally Posted by BREWPUBEAVER
[img]
Old 04-04-2006, 10:31 AM   #17
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
PDX tuned the car above and pretty much built the motor, turbo setup. The can tune any level subaru you bring them. They have tuned my car twice with my WI system
Old 04-04-2006, 12:00 PM   #18
Keshav
Member#: 1654
1998 GC8 Unicorn
MV Agusta Brutale S
Sweet! This is the route I'm planning for in the future. (year or two)
note that Rallispec sells the 12 liter trunk-mounted intercooler sprayer ... what a great place for your water/alky
Keshav is offline   Reply With Quote
Old 04-04-2006, 12:07 PM   #19
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
only if u dont have subs that fit in that spot. Most people including myself are using the sti ic spray tank. it fits in an area not used at all, and if u buy the trunk liner it looks all stock.
Old 04-04-2006, 01:00 PM   #20
BREWPUBEAVER
Member#: 84547
06, Lafawnduh
Fender rolling king
Subaru Stars
i am going back on friday to have them do some retuning. they are going to tune me for my Meth injection on 92* and C16*
really cant wait.
*IMO*
PDXTuning is the best in the buss. No where else can or will you get more information, quality customer service, and a great performing tune/install.
Old 05-05-2006, 08:56 PM   #21
modaddict
Member#: 95840
sold to a good bud
awaiting next car
Bump.
Where do you source METHANOL here in the N.W?
ive tried VP racing fuels here in Pasco. they want 35 dollars for 5 gallons. i 'thought' methanol went for 2-3 dollars a gallon. Am i mistaken? there is a 76 station that sells higher octane fuel...but i havent been able to get into communication w/ them.
Does PDX sell it?
I was hoping to get some METHANOL here on the east side of WA state.
thanks
Ryan
Old 05-05-2006, 10:38 PM   #22
pdxsilverwrx
Member#: 54935
Sherwin Williams, the paint store.
pdxsilverwrx is offline   Reply With Quote
Old 05-05-2006, 10:49 PM   #23
BREWPUBEAVER
Member#: 84547
06, Lafawnduh
Fender rolling king
but it will be 20 dollars a gallon.... it is pure meth though...
Old 05-06-2006, 12:56 AM   #24
POPOFF
Member#: 107266
2006 20g-366/401
Whitey/Blackie
That's where PDX got mine. I still have half a gallon left after four fillups.
<<Running Aquamist 2D making okay power with it.
POPOFF is offline   Reply With Quote
Old 05-06-2006, 01:16 PM   #25
modaddict
Member#: 95840
sold to a good bud
awaiting next car
BREW:
you been gettin' it from PDX?
check this out: http://www.vpracingfuels.com/vp_01_fuels.html#specialty
scroll to the bottom and see the meth section. 99.5% minimum purity. i guess if the paint store is 20 a gallon, and VP is 35 for 5 gallons, its a no brainer. Somehow i had it in my head that meth was 2 or 3 bucks a gallon . oh well. even if i fill up my meth-h2o mix everytime i get gas. it'll probly only go through 2-3 gallons a month. not bad.
restrictor pill, people who have modded the pill please chime in 06hwrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 06-17-2006 12:04 AM
fun in the fog, and fun in the sun dorifto88 Member's Car Gallery 22 12-20-2003 12:56 AM
Who is the other silver WRX in the Timberland Parking lot in Troy? Damian Mid West Subaru Owners Club Forum -- MWSOC 1 01-30-2002 10:06 AM
Events in the next 3 months in the area tsfxRS New England Impreza Club Forum -- NESIC 3 10-10-2001 08:19 PM
