Old 03-22-2006, 12:13 AM   #1
machantu
Member#: 82852
2003 Impreza WRX
Rally Blue
Default Engine Hesitation
Hey guys,
I was driving on the freeway recently and I accelerated hard to pass a car in 4th gear at about 75-80mph..
I felt like the engine shut off completely for a second and there was a jerk. But the car went on after that. The CEL came on, but after I restarted the car, the CEL wasn't there anymore... I have been driving the car for about 15000 miles and this is the first time that it has happened... I drove for another 100 miles back home, and the problem did not happen again (even under occasional hard acceleration)
I havent had the chance to go pull the CEL, was wondering if any of you could provide some insight...
I have 40000 miles on the car.
Mods:
SR30 Turbo
Pinks
Perrin fuel rails
I have not made any changes to the config for 15000 miles..
machantu is offline   Reply With Quote
Old 03-22-2006, 12:30 AM   #2
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Could it be that engine hit a fuel cut? It happened to me once when I accidently set boost too high on MBC.
Old 03-22-2006, 01:19 AM   #3
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
What engine management are you using with that turbo and those injectors?
nhluhr is offline   Reply With Quote
Old 03-22-2006, 09:54 PM   #4
ADR 04STi
Member#: 51918
2015 Audi S3
Daytona Gray
Question
Sounds like Trouble Code (P0244)= Turbo Wastegate Selenoid "A" Range/Performance. Were you watching your boost gauge? Were you under WOT when it happened?
ADR 04STi is offline   Reply With Quote
Old 03-24-2006, 07:04 PM   #5
machantu
Member#: 82852
2003 Impreza WRX
Rally Blue
yes it was WOT when it happened - I wasn't watching the Boost gauge.
I have a feeling it might be bad gas - I haven't had the problem since.
I am not too sure what engine management I have - but it allows about 20psi max boost.
I brought it to Autozone but they didnt have the ECU tool. I will try again at another branch and provide an update!
Old 03-25-2006, 01:45 AM   #6
crazymikie
Member#: 56321
2006 Honda El Camino
Green
Solenoid range means that you overboosted and hit fuel cut.
crazymikie is offline   Reply With Quote
Old 03-25-2006, 02:24 AM   #7
Lowball
Member#: 24198
02 WRX Sport Wag
Black to reality.
this happens to me some times under hard Acceleration coming off corners at the track. I always think my fuel it sloshing around and not getting into the line for a min. It only happens for a few seconds and then it's back on. But sometimes I have to lift off the throttle before it starts to accelerate hard again coming on to the straight away.
I also have a CEL but it's always P0171 "left bank to lean". Don't know if it's my settings or what. Tuner said all systems are go. All my temps seem to be in order (EGT, Fuel Pressure, etc.).
FP18G
Perrin Fuel Rails
PE650's
Walbro Pump
ECUTEK
Also it never happens on just freeway pulls in 4th or 5th gear.
Lowball is offline   Reply With Quote
Engine Hesitation and Check Engine Light Bricoleur Outback Forum 2 03-22-2004 08:09 AM
Engine Hesitation mrmcderm Electrical & Lighting 9 01-13-2003 08:28 PM
Engine hesitation at shift? DtownIan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-09-2003 06:01 PM
Stupid Engine Hesitation Rags Normally Aspirated Powertrain 12 02-26-2002 09:19 PM
Weird engine hesitation and CEL Impreza25RS Normally Aspirated Powertrain 1 01-08-2002 03:24 AM
