Old 03-22-2006, 10:45 AM   #1
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp [email protected]
Default Difference between C16 and Cam2 112
I am getting tuned by PDX this weekend. I am going to have a daily driver pump gas map (via ECUTek) and a race gas map (via UTEC). I was curious if anyone knew the difference between C16 and Cam2 112 leaded. Is C16 going to make 30+whp over the Cam2 or is it going to only be a few horsepower? Has anyone out there played with both fuels?
Main reason I'm asking is because, Cam2 is ~$20 for 5 gallons and C16 is ~$60 for 5 gallons and I'm going to be using the stuff quite frequently during the summer for auto-x. So if there isn't much of a difference in whp, I'll just save my money and use the Cam2.
SloRice is offline   Reply With Quote
Old 03-22-2006, 10:55 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....depends on your hardware....but tuning for the Cam2 isn't gonna cost ya 30hp unless ya getting the ragged edge kind of tune, anyway
Old 03-22-2006, 10:56 AM   #3
SloRice
Member#: 44351
2004 Mitsubishi Evo
Sorry, should have listed the mods
Built Block
Perrin GT30R .63ar Kit
TurboXS FMIC
modded injectors/walbro
all other supporting mods
Old 03-22-2006, 12:42 PM   #4
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
With that turbocharger it probably will amount to around 25 whp less. You are really limited on ignition timing with that fuel comparerd to C16. I've had good luck with Sunoco Optimal 116 (I believe) when C16 is not available.
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 03-22-2006, 03:32 PM   #5
hotrod
Member#: 14141
2002 Impreza WRX
CAM2 = Generic name for Sunoco products where Sunoco brand name cannot be used.
Code:
VP C-16                      MON = 117
Sunoco Maximal               MON = 114   ( High rpm, sunoco's fastest burn rate)
Sunoco Maximal #5            MON = 113   Oxygenated
Sunoco Supreme N.O.S.        MON = 113  ( high lead blend)
Sunoco  MX-114               MON = 110
Sunoco Supreme               MON = 110
Sunoco Stealth               MON = 110
I'm guessing its one of the last 3 given as how folks like to brag about the RON octane even though MON is more useful for performance engines.
If you can get any literature on the fuel such as its color, oxygen content and specific gravity you could probably pin down what blend it is.
Larry
hotrod is offline   Reply With Quote
Old 03-22-2006, 04:56 PM   #6
SloRice
Member#: 44351
2004 Mitsubishi Evo
It's a light blue color.
Old 03-22-2006, 05:21 PM   #7
Element Tuning
Member#: 54918
673 WHP Element
Maximal 118 that's it
Run whatever you have available and whatever you consider affordable. Just don't expect to break any dyno records with it.
I can run my C16 map on 110 with water/alcohol injection and itís more than Ĺ as expensive as C16. When doing track days I can burn through 20 gallons of race gas.
Phil
Old 03-22-2006, 06:40 PM   #8
hotrod
Member#: 14141
2002 Impreza WRX
Sunoco supreme is blue and has an R+M/2 octane of 112, MON of 109 and Ron of 115.
I would guess that is what it is.
Sunoco's GT + unleaded is also light blue, but has an R+M/2 octane of 104
Larry
Technical difference between "Bar and Plate", "Fin and Tube"? FromageTheDog General Community 14 11-10-2005 09:52 PM
Difference between c16 and high octane race gas? shemoves Off-Topic 5 08-16-2005 03:34 AM
Suspension differences between wagons and sedans and my03, and my04. jawbrkr Brakes, Steering & Suspension 16 08-03-2005 07:41 PM
Difference between AWD and 4WD? And other questions... AWD987 Newbies & FAQs 7 01-15-2003 11:00 PM
Difference between 91 and 92 Turbo Legacys?? nd4spd Legacy Forum 3 09-15-2000 02:28 PM
