Old 03-24-2006, 04:22 PM   #26
Jon [in CT]
Member#: 2992
02 WRX Sedan
Originally Posted by drees
I wonder what the ECU will think it is after having been flashed by AccessPort, though.
Why not dump its ROM and find out? My guess is a 2002 WRX.
Jon [in CT] is offline   Reply With Quote
Old 03-24-2006, 04:31 PM   #27
turboge
Member#: 35076
2004 507whp Wagon
Once my cable arrives I'm going to dump some roms from an 02-03 AP'd WRX and get someone to help me do some dumping on an AP'd 04-05wrx.
turboge is offline   Reply With Quote
Old 03-25-2006, 10:49 AM   #28
qoncept
Member#: 44762
2013 BRZ
I suspected it might already be possible, I just haven't looked into the software mapping details that far, yet. Good work, I'll try to get some time getting my 03 mapped out. I wonder what the ECU will think it is after having been flashed by AccessPort, though.
It'll be the same revision as every other 02/03 WRX. We've been talking on openecu about what Cobb does when it unmarries -- none of us have an AP to test if it replaces the original image that was on your car, or just whatever revision they happen to already have on the AP.
In any case, if you have an AP or ecutek, make sure you keep a backup of your ROM. That way, if you ever want to use the AP or ecutek again, you can be 100% sure you'll have all the licensing in the ROM.
qoncept is offline   Reply With Quote
Old 03-25-2006, 01:49 PM   #29
turboge
Member#: 35076
2004 507whp Wagon
I'll do some comparisons on that as soon as my cable arrives next week.
Old 03-27-2006, 04:07 AM   #30
qoncept
Member#: 44762
2013 BRZ
I've got a few bug fixes and a ton of ECU revisions to add, hopefully that'll be done some time this week.
Old 03-27-2006, 10:16 AM   #31
Jeramie
Member#: 56995
2016 WRX
WR Blue
Just curious wha bugs you are refering too? Error handeling?
Jeramie is offline   Reply With Quote
Old 03-27-2006, 06:25 PM   #32
qoncept
Member#: 44762
2013 BRZ
Old 03-27-2006, 06:26 PM   #33
qoncept
Member#: 44762
2013 BRZ
..and here's the list of things I'm going to add. I probably won't get to all of them for 0.2.5 but I hope to get most of them knocked out.
http://www.enginuity.org/viewtopic.php?t=48
Old 03-28-2006, 09:48 PM   #34
qoncept
Member#: 44762
2013 BRZ
Version 0.2.5 beta is now available. Must log in to download, yada yada..
http://www.enginuity.org/viewtopic.php?t=137
Old 03-29-2006, 12:35 AM   #35
skiblur
Member#: 48291
02 EJ207RA/JDM6
Still truckin'
great news! Hats off to you for all the hard work.
I understand this has the capability to work on an 02 WRX ecu. What are the chances of it being functional on an v7 STi ecu, using the same plugs, connectors, ect as a wrx ecu, the only real difference being AVCS?
this could make my pump gas tuning much easier
thanks!
Hunter
skiblur is offline   Reply With Quote
Old 03-29-2006, 02:13 AM   #36
qoncept
Member#: 44762
2013 BRZ
Basically, to support an ECU version, all you need is a way to get the image off the ECU and the data locations. You'll need ecuExplorer ( http://www.tari.co.za/cgi-bin/yabb2/...num=1138965460 ) and an openport 1.2 cable ( www.tactrix.com ) to get the image. ecuExplorer supports ROM dumping / flashing from USDM WRX 2002-2005, non-USDM WRX 2001-2005 and non-USDM STi 2001-2005.
If you get an image off your ECU, let me know (on enginuity.org, it's the only place I check frequently anymore) and I can get the ECU definition file set up for you.
Old 03-29-2006, 09:38 AM   #37
JRSCCivic98
Member#: 67080
If the ECU is not DBW (which it shouldn't be for the ver 7) then you should be able to dump it with either ecuFlash or ecuExplorer.
JRSCCivic98 is offline   Reply With Quote
Old 04-03-2006, 05:14 PM   #38
crispyduck
Member#: 98680
Default Using Scoobypedia.co.uk
Jared, All,
I'm more than happy you guys use my Scoobypedia Wiki to either store and/or index all the ECU images by linking back to the relevant Enginuity forum post. Either way, let me know if you want any help doing so. Alternatively Feel free to throw anything my way and I'll publish it for you guys. It's the least I can do to say thanks for your contributions to date.
-Steve.
Originally Posted by qoncept
...What I'd like to do is set up a wiki that has all the latest ECU images for each ECU version ... or maybe Scoobypedia ( www.scoobypedia.co.uk ) would be a better place for it..
crispyduck is offline   Reply With Quote
Old 04-03-2006, 09:17 PM   #39
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
The AP definitely replaces the map with an "Off the shelf stock" map, not the original one from your car.
nhluhr is offline   Reply With Quote
Old 04-04-2006, 02:04 AM   #40
dorrington
Member#: 33289
02 wrx
wrb
hey guys...very intrigued by this, and VERY impressed
do you guys think this is worth ditching my UTEC for? To me, it actually seems like it would be preferable...
dorrington is offline   Reply With Quote
Old 04-04-2006, 02:18 AM   #41
Spec C Wannabe
Member#: 69170
Will Version 0.2.5 support my UKDM 2004 WRX??
How can I verify this??
Spec C Wannabe is offline   Reply With Quote
Old 04-04-2006, 07:37 AM   #42
qoncept
Member#: 44762
2013 BRZ
That's the idea.. There are definately some features of the UTEC that we can't copy yet (like launch control), but not having to use a piggyback makes it worth it in my opinion.
Not at the moment, but it would be easy enough to add support. What you'd need to do is get an openport cable (www.tactrix.com) and ecuExplorer (www.tari.co.za). Get a copy of your ROM uploaded so I'll know what version it is and it'll take me 10 minutes to create a definition for it.
Old 04-05-2006, 09:01 PM   #43
qoncept
Member#: 44762
2013 BRZ
Enginuity 0.2.6 Beta is now available.
http://www.enginuity.org/viewtopic.php?t=163
Old 04-12-2006, 11:27 PM   #44
qoncept
Member#: 44762
2013 BRZ
Enginuity 0.2.7.2 Beta is now available.
http://www.enginuity.org/viewtopic.php?t=200
Old 05-09-2006, 10:42 AM   #45
qoncept
Member#: 44762
2013 BRZ
Enginuity 0.2.7.4b is now available.
http://www.enginuity.org/viewtopic.php?t=287
Old 05-09-2006, 10:45 AM   #46
Jeramie
Member#: 56995
2016 WRX
WR Blue
Yay!!!!
Old 05-09-2006, 11:00 AM   #47
Poweredbysnail
Member#: 74753
2003 Wrx 2.5Lw/gt30r
Team Snail
good stuff
Poweredbysnail is offline   Reply With Quote
Old 05-09-2006, 12:58 PM   #48
teiva-boy
Member#: 22825
What will it take to get FXT support added in? My '04 is needing a new tune.
teiva-boy is offline   Reply With Quote
Old 05-09-2006, 01:01 PM   #49
qoncept
Member#: 44762
2013 BRZ
The architecture of all the DBW ECUs is totally different than non-DBW cars. Just this week someone finally figured it out so it shouldn't be too long now.
Old 05-09-2006, 07:52 PM   #50
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Can I disable TGV CELs/codes? Especially the ones that cause limp mode?
jblaine is offline   Reply With Quote
rallitek enginuity tuning AlpoRS North West Impreza Club Forum -- NWIC 13 03-15-2007 12:06 AM
Enginuity-tuned by me 2006 WRX - stage 1 wall of tvs Proven Power Bragging 18 02-26-2007 09:44 AM
Enginuity tuning project qoncept Engine Management & Tuning 12 01-06-2006 01:48 AM
Unichip tuning software with tuning pots $300. Boost_Junkiee Texas Impreza Club Forum -- TXIC 11 10-29-2003 03:00 PM
FS:best offer takes Unichip with tuning software and tuning pots.. Boost_Junkiee Private 'For Sale' Classifieds 4 08-18-2003 09:21 AM
