Old 05-09-2006, 08:27 PM   #51
Jeramie
Member#: 56995
2004 WRX
Originally Posted by jblaine
Can I disable TGV CELs/codes? Especially the ones that cause limp mode?
Thats a good question. That one has crossed my mind before.
Jeramie is offline   Reply With Quote
Old 05-09-2006, 09:37 PM   #52
qoncept
Member#: 44762
2013 BRZ
All CELs can be disabled by modifying the ROM.
qoncept is offline   Reply With Quote
Old 05-10-2006, 01:57 AM   #53
ejsportcom
Member#: 88905
my consern is when they hook it up to the odbII scanner at state inspection in nj if it will show that something isn't right or if it will just pass?
ejsportcom is offline   Reply With Quote
Old 05-10-2006, 07:56 AM   #54
qoncept
Member#: 44762
2013 BRZ
It will be completely transparent to OBD-II sniffers. They'll have no idea.
Old 05-10-2006, 11:13 AM   #55
ejsportcom
Member#: 88905
Talking
thats what i like to hear
Old 05-10-2006, 11:55 AM   #56
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
I believe you, but I would like to get more clarification.
It has taken EcuTek and others quite some time to defeat the TGVs.
I don't mean "intercept the problem and just don't light up the CEL on the dash". That's relatively easy as I understand it.
I mean "fully subvert" TGV logic so that a car with no TGVs and no TGV sensors plugged in has zero problems.
jblaine is offline   Reply With Quote
Old 05-10-2006, 12:01 PM   #57
Jeramie
Member#: 56995
2004 WRX
Defating the CELS is generally not that hard. Most of the locations are known. Most CELS are deleted (well not actaully deleted) but the values that trigger them are moved to a point where they no longer trigger the cel hence "deleting" the cel. I hope that made sense?
Old 05-10-2006, 12:09 PM   #58
TheMadScientist
Member#: 23717
2005 Big red
PM crazymike.
He has been comparing the USDM and JDM ECUs. I think he said that the memory space used for the TGV code in the US ECU is used for the AVCS in the JDM ECU. You might be able to flash the JDM ROM into the US ECU. That way the US ECU won't even check for the TGVs.
I am not sure so you would need to talk to him.
TMS
TheMadScientist is offline   Reply With Quote
Old 06-03-2006, 12:43 AM   #59
MRF582
Member#: 48219
. Always drive
the race line .
Jeff, you can disable all CEL codes. My car has a stock ECU right now tuned via Colby's ECUflash, Calvin's ECUexplorer, and qoncept's Enginuity.
Originally Posted by cboles from www.openecu.org
Say your DTC is P0420.
Load the ROM A4SGD10C in a hex editor. Search for either the hex sequence
03 04 20
or
04 04 20
The 03/04 depends on whether the DTC is an OBD or OEM specific code, I think. You can see that the DTC part of the bytes is just encoded as BCD, and looks like decimal. In this case, I find 03 04 20 in one place in the file, at address 0x2DB0D. To eliminate this DTC mapping, replace the 03 04 20 value with 05 00 00, which appears to be Subaru's way of mapping this event to a non-existent DTC, which produces no CEL.
That's it! Just be sure you don't accidentally edit some other part of the ROM that just happens to have a byte sequence that matches the DTC you are looking for!
Colby
MRF582 is offline   Reply With Quote
Old 07-05-2006, 08:45 AM   #60
qoncept
Member#: 44762
2013 BRZ
Version 0.3.0 is now available for download. This version adds 32-bit ECU support (STi, Legacy, Forrester etc) (!), new checkboxes for disabling CELs, and some other minor changes. Now get it and tune your STi!
http://www.enginuity.org/viewtopic.php?t=397
Old 07-05-2006, 03:23 PM   #61
teiva-boy
Member#: 22825
w00t!
Gotta get my cable now
teiva-boy is offline   Reply With Quote
Old 07-05-2006, 03:29 PM   #62
GotWRX03
Member#: 35705
should'a done that three months ago
Originally Posted by teiva-boy
w00t!
GotWRX03 is offline   Reply With Quote
Old 07-05-2006, 04:37 PM   #63
teiva-boy
Member#: 22825
I only got my FXT 3 months ago
Until as of last week it's been relatively stock.
rallitek enginuity tuning AlpoRS North West Impreza Club Forum -- NWIC 13 03-15-2007 12:06 AM
Enginuity-tuned by me 2006 WRX - stage 1 wall of tvs Proven Power Bragging 18 02-26-2007 09:44 AM
Enginuity tuning project qoncept Engine Management & Tuning 12 01-06-2006 01:48 AM
Unichip tuning software with tuning pots $300. Boost_Junkiee Texas Impreza Club Forum -- TXIC 11 10-29-2003 03:00 PM
FS:best offer takes Unichip with tuning software and tuning pots.. Boost_Junkiee Private 'For Sale' Classifieds 4 08-18-2003 09:21 AM
Message Board Statistics All times are GMT -4. The time now is 08:33 AM.
