Old 03-22-2006, 01:18 PM   #1
mranlet
Member#: 66304
98 RWD BG Outback
...with R200 and ITBs ;)
Default Compatible oil cooler/filter relocation
I want to add an oil cooler for my 98 2.5l Legacy now that I have a bumper with a huge center cutout and no intercooler (NA power for the win!). I have a big head exchanger and can get the hoses from Amazon hose across town, but I want to come up with a sandwich plate that will fit the Subaru oil filter (PH3593A). Tooling through JCW, I came across this:
http://www.jcwhitney.com/autoparts/P...Browse/s-10101
That ought to work, but I'd like to find a complete kit that works on a Ford or Chevy truck or something. I remember vaguely that some Dodge oil filters fit on Subaru and that certian Fords up to 95 will also work. Anybody have any info on this?
If I wind up doing it DIY style, I'll post a how-to on scoobymods or SL-i
Thanks!
mranlet is offline   Reply With Quote
Old 03-23-2006, 01:57 AM   #2
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
id like to know about this also. i could use an oil cooler once i start to get crazy with my car.
Old 03-26-2006, 11:57 AM   #3
mranlet
Member#: 66304
98 RWD BG Outback
Here is the type of oil cooler I plan on using (not this exact one, but same style):
It's off a 2nd Generation RX-7 and stands about 18" long, 5" high and 2" thick with both inlet and outlet on the same end.
Judging form the lack of response, I assume that most people use OEM Subaru or FAL oil cooler kits. Looks like I'm going DIY style, but only after I can finish my S14 to J30 VLSD swap and ITBs (both of which are in progress).
Old 03-26-2006, 06:58 PM   #4
tmeh
Member#: 30800
2000 .7 RS
i recently made a decision on cooling the oil on my NA 2.5 and instead of the extra radiator i'm using the oil/water cooler from a WRX and using a WRX water pump as it has the extra coolant output cast into it
the main reason i went this route was that i didn't want to be dealing with draining the cooler everytime i do an oil change
as a bonus, it will fit and look stock, and help bring the oil up to temperature faster.
tmeh is offline   Reply With Quote
oil pressure, oil cooler and relocation filter questions hybrid gti 2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 01-08-2008 01:00 PM
oil cooler + brullen = relocation kit awd4ever Normally Aspirated Powertrain 4 01-08-2005 12:52 AM
Oil cooler & relocation kit 99WRXEJ20 Private 'Wanted' Classifieds 3 09-15-2004 02:09 AM
Leaking Oil from oil filter/oil cooler AustinSTi Normally Aspirated Powertrain 3 01-08-2004 12:42 AM
oil filter relocation and running two filters q tdxflex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 04-18-2003 11:31 AM
