Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 03-22-2006, 04:13 PM   #1
snarlingbeast
Member#: 100356
Default Any problems w/ STi bottom end on '02 WRX?
Hey guys,
I just developed a rod knock on my '02 WRX. Only 78k on the clock, too. Very sad. Anyway, I'm basically looking at a short block replacement. I called the parts department of the dealership where my car is just to compare the price with an STi short block, and the STi is - get this - $100 cheaper! The labor is the same, so I'd love to do this swap.
The final motor would have the 2.5 STi bottom end, '02 WRX top end, Injen CAI, Borla header, Borla UP, Helix catted DP, and Borla catback exhaust. I would also have it Ecutek custom-tuned when all is said and done.
Have any of you had any problems / issues with such a bottom-end swap (reliability, driveability, etc.)?
And I know about the unstable A/F ratio issues with CAI's. Will it matter if I get the Ecutek tune?
Thanks!
snarlingbeast is offline   Reply With Quote
Old 03-22-2006, 04:25 PM   #2
ejsportcom
Member#: 88905
just use the sti stock head gasket and they will have to tune for a slightly higher compression but it shouldn't make that much of a difference seeing as its mostly stock.....
ejsportcom is offline   Reply With Quote
Old 03-22-2006, 07:20 PM   #3
snarlingbeast
Member#: 100356
bump...
Old 03-23-2006, 12:30 AM   #4
snarlingbeast
Member#: 100356
And... any recommendations on plugs for this config.? Some say one step colder, some say stock.
Old 03-23-2006, 12:40 AM   #5
MrH00nel2
Member#: 80474
2002 Z06
1200whp
just get the stock ngk at the dealership, there just fine
make sure you use the plugs for the wrx because thats the heads you are using
MrH00nel2 is offline   Reply With Quote
Old 03-23-2006, 01:54 AM   #6
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Old 03-24-2006, 02:07 PM   #7
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Normally I would agree and the stock WRX plugs would be fine but since you are bumping compression quite a bit I would recommend a 7 heat range plug instead. This should offer you a little better knock resistance and will be easier to tune for someone who isn't familiar with tuning higher compression.
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Confused: does USDM STi intercooler fit on '02+ WRX? Orson Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 04-08-2005 02:21 AM
'05 STi hood scoop on '02 WRX brandon_bxtr Interior & Exterior Modification 14 03-17-2005 02:33 PM
Has anyone installed an 04 USDM STI rear end on a WRX ElJefe Brakes, Steering & Suspension 2 11-13-2004 05:54 PM
Hooking up JDM STi Instrument Cluster on '02 WRX Hoop-D Electrical & Lighting 8 08-06-2003 01:19 PM
Will STI Brembos fit on '02 WRX Sedan? WRCHAMP STi Forum Archive 6 05-15-2003 01:58 PM
