Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 03-22-2006, 11:34 PM   #1
xbcaraudio
Member#: 76912
2002 WRX MT
WRX RALLY BLUE
Question Blitz DSBC EBC + UTEC Setup ??? Help
I'm running Utec with Blitz DSBC EBC to control my boost, My question is, if I'm running UTEC just to control timing & fuel, what about the boost map???, or does it matter, I really don't know if I should play with the boost map on the utec. I have no issues so I just leave that alone. How it should look like or set to open with 100's everywhere...
Thanks in advance...
xbcaraudio is offline   Reply With Quote
Old 03-23-2006, 09:36 AM   #2
AaronWRX
Member#: 7194
2011 997.2 Turbo
Dont worry about the boost map. The utec will be sending signals to the factory boost solenoid lines but since you clipped them to install an EBC controlled by the blitz then youre fine.
AaronWRX is offline   Reply With Quote
Old 03-23-2006, 10:00 AM   #3
xbcaraudio
Member#: 76912
2002 WRX MT
WRX RALLY BLUE
Here is my Stage 4 setup:
Greddy T518Z
Perrin Turbo Inlet
TXS FMIC
565 Pinks
Invidia Turbo back, Helix Up- Pipe
Perrin Fuel Rails
Aeromotive AFPR
Big Denso Pump
Snow performance Stage 2 WI
Ported TB and exhaust manifold
TXS bosch Tuner
Biltz DSBC
Right now im using the TXS stage 4 basemap to start the tuning process...
Old 03-23-2006, 10:07 AM   #4
AaronWRX
Member#: 7194
2011 997.2 Turbo
Nice! You will have a lot of work ahead of you molding the Stage 4 map into something that takes full advandate of your mods. The stage 4 map is a good place to start though. It looks like you have all the tools to do a good job.
I enjoy threads where people update their latest utec logs as time goes on. I like to see people making progress. Good luck.
FS (PA) Blitz DSBC Spec-R EBC $150.00 Shipped Techie Engine/Power/Exhaust 2 05-06-2010 10:02 PM
Blitz DSBC setup questions Simon C Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-14-2009 04:04 PM
Blitz DSBC Help? hrb93 Engine Management & Tuning 3 04-17-2005 11:35 AM
Blitz DSBC Setting? JohnWad Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-21-2001 05:48 PM
Blitz DSBC settings MJSpiers Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 05-19-2001 12:08 AM
