Welcome to the North American Subaru Impreza Owners Club Monday October 24, 2016
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 03-23-2006, 01:21 PM   #1
Member#: 73755
05 STI
Question Idle AFR's with JECS Injectors?
I recently installed JECS 720cc injectors on my 05 STI. My UTEC is set to 740 (stock 550) injector scaling. I've logged ST and LT trims over a 150 mile drive. Things are looking good with LT around -3.5 and ST between -5 and +5 depending on RPM and load. At idle (~700 rpm) however, my wideband shows AFR's at 11.5-12.1 and I can't seem to get it any closer to 14.7. My guess is that I am running into a "minimum injector on-time" problem. Using the TARI OBDII reader, I can see the injectors are firing at 0.9% duty cycle and I can't get it lower than that. I've experimented with setting the injector scaling up to 930cc and I've also tried setting the fuel map to -10 in the 0% column at 500 and 750 rpm. Neither of these changes have had any effect. Oh, also at idle, my ST trim drops to -25.
Has anyone else run into a similar problem? I can see this problem being ignored by tuners since the car idles fine with no smoke or other problems. I only noticed it because of my wideband (and the stock O2 showing similar AFR with TARI). And there's a periodic, pesky P0172 code if the car idles for a long time. Periodically resetting the ECU just doesn't seem like the right answer.
Thank you in advance for your help.
pjm is offline   Reply With Quote
Old 05-04-2007, 08:49 PM   #2
Member#: 54871
1999 Impreza GT
I put 720 cc injectors in my MY99 Turbo 2000 cc engine and I was able to find 14.7 at idle with the apexi SAFC2, with around -10 % setting at 800 rpm
I honestly helped ECU with the mechanical pressure regulator setting to 30 psi (at iddle vaccum -15 inHg) to make this easier.
You may do that with your ECU setting too...
GT99CR is offline   Reply With Quote
Jecs injector clips? exsidrvr04 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 05-25-2008 01:03 PM
Help, please, JECs injector install failure, IWSTI cross post. Tgui Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 04-12-2008 06:26 PM
How my racecar idles with 1680cc Injectors. Video Inside STEALTH-WRX Built Motor Discussion 14 06-15-2007 11:58 PM
JECS injectors, APS turbo inlet cliff257 Private 'Wanted' Classifieds 1 01-08-2007 09:18 PM
DIY 720cc JECS Injector Install keyser_soze Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 21 11-02-2006 10:49 AM
