Old 03-23-2006, 04:57 PM   #1
84SubaruDL
Member#: 42179
SON! F 22's i roll
on 33" 12 fity SON!!!
Default CEL ? with Accessport
my 03 wrx stage 2.5 poped a CEL last week, and when i check it with the accessport scanner, it said no trouble codes found.
has anyone else have this happen to them. and if so, how can i find out if there was really a problem.
84SubaruDL is offline   Reply With Quote
Old 03-23-2006, 05:01 PM   #2
supermarkus
Member#: 6971
2008 WRX STi
SSM
Are you aware that the AP does not read historic CELs? Once you turn your car off, things like p0420 become historic codes. You need to pull the code as soon as it happens without turning the ignition off if you want to use your AP as a scan tool.
supermarkus is offline   Reply With Quote
Old 03-23-2006, 07:57 PM   #3
84SubaruDL
Member#: 42179
SON! F 22's i roll
^^^ so you are saying, that if i drove home turned the car off ran inside my house and grabed the accessport when i go back outside to check it it won't check the code?
cause i turned the car on agian the CEL was still on and when i checked it, it said no trouble codes found
Old 03-24-2006, 04:35 PM   #4
hondaeater69
Member#: 60324
The AP reads current DTC (diagnostic trouble codes), not CEL's perse. confused yet?
Old 03-24-2006, 06:56 PM   #5
84SubaruDL
Member#: 42179
SON! F 22's i roll
what does that mean? cause i thought a few hours would be current enough
Old 03-24-2006, 08:17 PM   #6
supermarkus
Member#: 6971
2008 WRX STi
SSM
Thanks alot, i was trying to keep thing somewhat simple for the Rhodes Scholars out there
to OP
DTC are thrown when there are problems during the self diagnostic routines, the result is a visual cue= Check Engine Light or Malfunction Indicator Light as some call them. Once you turn the car off, they usually get shuffled into memory as a historic DTC. I seriously don't' know how I could have been any clearer in my first post and still keep it brief and simple. Do yourself a favor and get a real scan tool.
Old 03-27-2006, 11:19 PM   #7
Mach V Dan
Member#: 12029
On the later model cars, there ARE DTC codes that the AccessPort CANNOT read. I know this is true for '05 and '06 model year cars. I thought it was NOT true of the 2003 model year, so if you have an active Check Engine light, the AP should be able to tell you the code.
--Dan
Mach V
FastWRX.com
Mach V Dan is offline   Reply With Quote
P0031 CEL with Accessport (stage 2) Jay04WRX AccessPort 15 09-06-2009 01:24 PM
CEL ? with Accessport 84SubaruDL Mid Atlantic Impreza Club -- MAIC 4 03-22-2006 03:28 PM
CEL with accessport...need help NRTmotorsports Engine Management & Tuning 6 11-24-2005 02:32 PM
Help! CEL with CEL fix electricpork Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-31-2004 03:56 PM
throwing cel P0139 with accessport stage II WolfInSheepsCLothing Engine Management & Tuning 2 12-19-2004 07:34 PM
