Old 03-23-2006, 05:42 PM   #1
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
Default Check my Math!!!
ok engineers and math majors, check my algebra, and equation for that matter, as i made it up to attain the CR. i need this because the piston dish and my value "D" are different now, and i need a head gasket in the right thickness, or at least close.
may be a little hard to understand, but if you know how and want to help, its easier to write it down
for 8:1 CR ratio.
HG= head gasket thickness in cm
HS= head volume/combustion chamber size in cc
PD= piston dish volume in cc
D= distance the piston comes out of the deck in cm (if it is under, its negative)
Eqn: 8/1 = (((HG-D)*(pi*4.6^2))+HS+PD+498.57)/(HS+PD+((HG-D)*pi*4.6^2))
498.57 is the volume of the cylinder made by the stroke: (pi*4.6^2)*7.5
so: 8(HS+PD+((HG-D)*pi*4.6^2)) = ((HG-D)*(pi*4.6^2))+HS+PD+498.57
do algebra...... i got:
HG = (-(HS+PD)+71.2245)/(pi*4.6^2))+D
HG = -(HS+PD)/(pi*4.6^2) + 7.5/7 + D
thanks guys
Hurley 2.5 WRS is offline   Reply With Quote
Old 03-23-2006, 05:52 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Just put the damned v7 block in the car with an EJ205 gasket and get on with it already!
Old 03-23-2006, 06:11 PM   #3
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
so, anyone?
Old 03-23-2006, 06:31 PM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
I'm done doing math for people. After I started publishing numbers for a bunch of different combos, I started getting all these PM asking me to calculate CR's for people. Free bump to get someone to do the math.
BTW, there are some very good online calculators that will do it for you...
Old 03-23-2006, 06:42 PM   #5
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
well, im pretty sure the math is correct, i just want someone to check the algebra.
ps, possible link to an online calculator for cr?
Help me check my math on Compression Ratio SiouxBe1 Normally Aspirated Powertrain 5 12-23-2007 12:26 PM
Check my math? DjRez4 Tire & Wheel 5 01-28-2006 04:54 PM
Letter to the Editor (Part 2) Check my math, and read. eurojax Off-Topic 9 01-24-2005 11:20 AM
Can somebody check my math/help me [Compressor Map Reading] sherifx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 05-03-2002 12:40 PM
('93-'01) Check my math? re CFM, PSI, and so forth... Daveish Impreza Forum 0 10-23-2001 10:18 PM
