Go Back   NASIOC > NASIOC Subaru Models > Tribeca Forum
Old 03-23-2006, 07:05 PM   #1
THAWA
Member#: 44581
3 Boxers 2 AWD
3 turbo 1 6cyl & a 13BT
Default Tribeca Brake/Suspension technical information
Can anyone fill in these blanks:
Front Disc Size: 316mm x 30mm
Front Caliper Piston Diameter/Radius: 42.8mm x 2/21.4mm x 2
Front Rotor Effective Diamter/Radius: 261mm/130.5
Rear Disc Size: 320mm x 18mm
Rear Caliper Piston Diameter/Radius: 40.46mm/20.23mm
Rear Rotor Effective Diameter/Radius: 284.5mm/142.25mm
Parking Brake Diameter: 210mm
Front Spring Rate:
Rear Spring Rate:
Front Spring Diameter Upper/Lower:
Rear Spring Diameter Upper/Lower:
Front Sway Bar Diameter: 25mm
Rear Sway Bar Diameter: 16mm
Thanks Peaty
Anyone else know the other info?
THAWA is offline   Reply With Quote
Old 03-25-2006, 08:21 PM   #2
THAWA
Member#: 44581
3 Boxers 2 AWD
Does anyone have a FSM?
Old 03-25-2006, 11:10 PM   #3
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
I have one but not with me, I'm on vacation in Fl right now and won't be back home till tuesday. I'll look but I don't think it will have all the info you are looking for. Most of that is too specific even for the SM. I'll try to remember to check.
Peaty is offline   Reply With Quote
Old 03-30-2006, 10:49 PM   #4
THAWA
Member#: 44581
3 Boxers 2 AWD
Anything yet?
Old 03-31-2006, 12:25 AM   #5
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
check your PM
Old 03-31-2006, 10:07 PM   #6
THAWA
Member#: 44581
3 Boxers 2 AWD
Sweet, thanks!
Man, Tribeca parts are beefy.
('93-'01) Subaru Technical Information AHadjiminas Impreza Forum 5 03-26-2007 09:44 AM
Praxis technical information document sdecker Brakes, Steering & Suspension 2 03-16-2004 07:32 AM
Subaru Technical Information Service munkis Service & Maintenance 0 05-22-2003 08:55 PM
Complete and very detailed technical information on wheelbearing fix Outback_Mike Brakes, Steering & Suspension 2 09-22-2001 12:36 PM
