Old 06-12-2001, 09:16 AM   #1
Alex RS
Member#: 864
2000 Imrpeza2.5RS
BRP
Question Is changing your trans. fluid like...
changing your oil? Just drain out the old and pour in the new. I think that it time for it to be changed and was wondering if I could do it myself? Any suggestions on what to put in and how to do it?
Alex RS is offline   Reply With Quote
Old 06-12-2001, 11:13 AM   #2
tonytiger
Member#: 3844
1993 Legacy 1.8
Smile
Yes, you should be able to do it by yourself. The drain plug is under the Subie at the bottom of the transaxle case. For the lubricant you might want to check this out http://www.cobbtuning.com/tech/gearoil/index.html.
The procedure is simple: Jack up the vehicle, move some sort of pan or rags under the draining plug to prevent messing up places, wait until it has drained completely, put the plug back and tighten well, lower Subie, put the new lubricant in. After driving a bit check that the system hasn't leaked. It's really simple.
tony
tonytiger is offline   Reply With Quote
Old 06-12-2001, 03:08 PM   #3
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Post
Wait for your exhaust to cool before draining the fluid, and then use a plastic bag to shield your exhaust from the draining fluid. The drain plug is right above the Y in your header, and the few times I've changed my fluid I've gotten some on the pipe (even when I using my jury-rigged plastic bag shield). I noticed the one time I let the dealership do the fluid change that they got fluid on the exhaust, too. Chances are you'll smell some fluid cooking off when you start the car - no biggie, it's just that bit of fluid that got onto the exhaust header/heat shield.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 06-12-2001, 03:28 PM   #4
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Post
Make sure you get a loooong narrow funnel for pouring the fluid back in and you will need to remove the plenum box to get to the dipstick/fill hole.
Revision is offline   Reply With Quote
Old 06-12-2001, 03:36 PM   #5
PunksWRX
Member#: 5504
2004 Impreza WRX STi
Post
Alex,
If you get one of the metal funnels with the long flexible hose you can refill the transmission through the dipstick tube without removing the plenum/air filter box. It was easy when I did it on my RS. I was also able to remove the plug without jacking up the car. If you do jack up the car, lower it while the tranny is draining as you want the car to be as level as possible so that you get a complete drain.
Punk
PunksWRX is offline   Reply With Quote
Old 06-12-2001, 08:52 PM   #6
Alex RS
Member#: 864
2000 Imrpeza2.5RS
BRP
Thumbs up
Thanks alot guys, I really appriciate all the advice!
Changing auto trans fluid vfr Forester Forum 3 06-22-2006 05:44 PM
Is changing the tranny fluid in a awd vehicle any different than chillington Service & Maintenance 2 09-19-2005 07:18 AM
How long before you should change your clutch fluid? 0260B4U Service & Maintenance 16 02-27-2005 11:02 PM
How many miles when you changed your brake fluid? NavyBlueSubaru Brakes, Steering & Suspension 28 02-27-2005 05:44 PM
Interested in changing your clutch fluid? P.K. Motorsports Normally Aspirated Powertrain 0 04-14-2001 11:36 PM
