Old 03-23-2006, 11:28 PM   #1
ejsportcom
Member#: 88905
Default head porting and arp head studs.....
now let me just put this out there, I'm looking to make about 650hp with a set of ej205 heads. I know just by lack of flow they will not be capable. They flow 200cfm while i will need about 265-70cfm to achive my goal. Now my question is who does porting, is it cnc, or can i just do it myself like i did on all my v8 engines and motorcycle engines. Also while on the subject of heads, will the standard size arp head studs support ~650hp or am i going to have to go with the larger studs? Oh and one last question, head gasket... will the stock hold up or have i lost my mind?
ejsportcom is offline   Reply With Quote
Old 03-24-2006, 02:47 AM   #2
keaniegenie
Member#: 94494
2005 Element 92x
If you know how, do it yourself. You'll need new cams too.
650crank hp, or 650 whp? You'll need more than just p&p'd heads and ARP headstuds for either number.
keaniegenie is offline   Reply With Quote
Old 03-24-2006, 04:00 AM   #3
testes1010
Member#: 47145
2012 Gas Saver
I'm sending mine to Crucial Racing... ...oh yeh mine are JDM v8 heads w/ Helix Cams...
testes1010 is offline   Reply With Quote
Old 03-24-2006, 07:13 AM   #4
ejsportcom
Member#: 88905
650crank hp. was looking at 280's from crower for cams and 1mm over valves....... so your saying im going to need the larger studs?
Old 03-24-2006, 10:19 AM   #5
InfamousDX
Member#: 25413
I doubt you'll need something as aggressive as 280's for 650hp . What bottom end and turbo setup are you going with?
Old 03-24-2006, 10:40 AM   #6
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
I've tuned a car to over that power and compared to your heads it has 2mm larger valves, porting, and 272 degree cams. To make that kind of power on a 2.0 expect not to hit 20 psi until about 5300 rpm.
Hope this helps.
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 03-24-2006, 12:05 PM   #7
ejsportcom
Member#: 88905
maybe so, im looking to do a ej205, 100mm sleeved, and close decked. turbo will be something like the GT3582R. so it won't be a 2.0L, more like a 2.4L
FS: Ej2.2t Closed deck short block and ARP head studs Quadsbc NESIC Private Classifieds 8 04-16-2010 07:04 PM
JDM V7 heads and ARP Head Studs r0n Engine/Power/Exhaust 20 01-05-2010 03:35 PM
***Innovative Tuning crate engines, head work, NEW ARP Head Stud Kits, and MORE!!!*** Innovative Tuning Engine/Power/Exhaust 17 07-22-2008 03:33 PM
Socal ported and polished heads, Sard, Cusco, Sti, 350 hp package, gfb, and more! Turbo Juice Private 'For Sale' Classifieds 45 07-28-2005 04:55 PM
i need my heads ported and polished. who to goto and how much STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-26-2002 07:29 PM
