![]() Mid Atlantic Impreza Club Forum sponsored by Annapolis Subaru |
#1 |
In the silly seat
Moderator Member#: 34935
Vehicle:SPB- 2013 Smugmobile |
Symptoms happened this morning in Shannon's wagon. We smelled gas while sitting at a light right by home and then again in the parking lot at work once we stopped and idled for a few moments.
I popped the hood and sniffed around in there, but didn't smell any gas. Shannon says the smell was really strong on her side(driver's side) outside of the car. What do I check first?
#2 |
Member#: 36838
Vehicle:2000 RS Sedan 2004 STi w/RS body swap |
Lift left-outter cheak and inspect for leaks in das pooper?
#3 |
In the silly seat
Gasoline.
#4 |
Member#: 71380
South East
Vehicle:GSX 1300R Hayabusa Pontiac GTO |
Oh noes your NOZ is leaking!!!
#5 |
Member#: 64127
Vehicle:2001 PY ITR, 2012 X5 on order |
Was it cold this am? That is a known issue..do a freakin search n00b!!!
#6 | |
Member#: 44638
Vehicle:04 Sage 2.5 WRX going to the pants party |
#7 |
Member#: 21007
[asshat-ish mid-a representative] do a ****in search noob and you will find your answer...this has been covered a million times!!! [/asshat-ish mid-a representative]
#8 | |
In the silly seat
Sean already told him he was stupid. We're past that. |
#9 | |
Member#: 64127
keep it up. No red hazard button |
#10 | |
Member#: 44638
#11 |
Member#: 64127
Seriously, I have had the same smell. The reason it may not have been noticeable in the engine bay, logic dictates, would be it is in the OPEN FREAKIN AIR!!!! Duhhhh!!! Gaaawsh!!
#12 | |
In the silly seat
a;slkdjf;laskdjf;kahsd;flkjas;dlf |
#13 |
Member#: 21007
i have only had it bad once and then it went away...way back when i first had my car.
only happens on cold morning it seems. some say it is the fule rails, that if you replace those you will be just fine. http://forums.nasioc.com/forums/show...as+smell+cabin can i have the red hazard button? |
#14 | |
Member#: 64127
#15 |
In the silly seat
Now that we're done with that...
I mean I obviously think it could be the TB fuel leak. I'll check all lines when I get a chance and see if there are any loose clamps or crap like that. I was just surprised since it was 39 F this morning and it has been a lot colder out in the last few months and this never happened. |
#16 | |
Member#: 44638
Was the car already warmed up or was the engine still cold? |
#17 |
Member#: 24308
Vehicle:Oh, **** it I'm gonna have a party |
typical issue with the 240 is to not have the inner gastank cover sealed properly...just a thought, if you happen to have installed a pump.
I would then just check all the lines, especially near the firewall where it goes from hard to soft (he heh heh heh). |
#18 | |
In the silly seat
The car was warmed up when we got to the parking lot at work and smelled it again. |
#19 |
Member#: 6590
Didn't you just finish installing a drivers-side flamethrower option on her car?
#20 |
Member#: 993
Did you get the exhaust gaskets fixed?
#21 | |
Member#: 64127
#22 |
Member#: 59872
Vehicle:2004 Impreza WRX White |
My sub stinks like gas a lot. And I drive from inside the car rather than the engine compartment so I tend to smell the gas from inside the car.
#23 | |
In the silly seat
![]() Another note: The car idles and runs fine. |
#24 | |
In the silly seat
#25 | |
Member#: 21007
add your region/chapter info and we will start paying attention to your posts if they are helpful ![]() |
| Thread Tools | |
| Display Modes | |
| Lisa Fleming, so hot or not so much? | rice h8r | Off-Topic | 37 | 05-28-2007 02:19 AM |
| Gas smell coming from alternator and a check engine | ansonb505 | Factory 2.0L Turbo Powertrain | 11 | 05-17-2007 08:38 PM |
| Gas smell that is not related to cold weather | ImpreziveWRX | Factory 2.0L Turbo Powertrain | 3 | 10-08-2006 08:41 PM |
| I like what you've done here, and here, but not so much here...... | Ripper_AWD | Off-Topic | 12 | 12-13-2003 07:21 PM |
| Not knowing much about engine design, I have this question. | redoktober_99 | Factory 2.0L Turbo Powertrain | 3 | 08-14-2002 08:43 AM |
