Old 03-24-2006, 11:24 AM   #1
kheff46
Member#: 66739
2002 WRX wagon
Default DOT 4 to DOT 5
on some bottles of DOT 5 it says for use on replacement systems or systems originally equipped with DOT 5.
-what constitutes a replacement system?
-completely cleaning and refilling?
-new parts only?
whats up guys? does DOt3/4 breakdown seals or react with DOT 5 or is there a difference in the glass beads vs silicon in DOT 5? a little help here!
oh, this is for my swap. does this count as a conversion?
kheff46 is offline   Reply With Quote
Old 03-24-2006, 11:29 AM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
dot 5 ->silicone->bad
dot 5.1->not silicone ->good
silicone is only good for augementation...
Old 03-24-2006, 11:35 AM   #3
kheff46
Member#: 66739
2002 WRX wagon
what is dot 5.1?
Old 03-24-2006, 06:47 PM   #4
sidewayz
Member#: 5810
2001 S366 2.5RS
stick with dot 3/4... dot 5 just has a higher boiling point..which you will never see in any street car.
sidewayz is offline   Reply With Quote
Old 03-24-2006, 07:10 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
DOT 5 is silicone fluid and is NOT compatible with conventional DOT 3 or 4. It also cannot be used in systems that have had DOT 3 or DOT 4 in them, they don't mix and all the seals in the system will be destroyed. It's also not compatible with ABS.
So, don't use it.
Old 03-24-2006, 09:16 PM   #6
JeremyRS
Member#: 65126
00 Leggy Wagon
99 Silverado, 06 HD
l
+1
JeremyRS is offline   Reply With Quote
Old 03-24-2006, 09:23 PM   #7
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
right but 5.1 is not silicone
http://en.wikipedia.org/wiki/DOT_5
Old 03-24-2006, 11:54 PM   #8
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
stick with 3 or 4. No need for 5.anything. Unless you plan on running the 24 hours of Nurburgring. Which i highly doubt.
subbyspeed is offline   Reply With Quote
Old 03-25-2006, 12:45 PM   #9
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Dot 5 brake fuild is for show cars, it doesn't absorb water like Dot 3, 4, and 5.1 so it won't corrode the brake system.
Dot 5.1 is for race cars, much higher dry boiling point and usually (from what I've seen) a lower wet boiling point than Dot 3 or 4 with a higher rate of moisture absorption. Race teams don't care because they will change out the brake fuild every race.
Stick with Dot 4 for anything street driven.
speedyHAM is offline   Reply With Quote
Old 03-25-2006, 01:26 PM   #10
kheff46
Member#: 66739
2002 WRX wagon
thanks!
Anyone have problems with seal/abs when using DOT 4/5.1 brake fluid? Dizmal Brakes, Steering & Suspension 6 03-19-2007 07:56 PM
So I mixed DOT 3 and DOT 5 LatentWagen Brakes, Steering & Suspension 6 03-22-2005 09:39 PM
Changed to Dot 5 without doing the research, now what? MattGC8 Brakes, Steering & Suspension 9 10-02-2004 04:04 PM
Upgrading brake fluid to DOT 4 element533 Service & Maintenance 5 07-21-2003 10:06 AM
More brake fluid changes w/ DOT 4? Kyle Paton Technical Forum Archive 1 07-26-2000 07:02 PM
