Go Back   NASIOC > NASIOC Classifieds > Vendor 'Group Buy' Classifieds
Closed Thread
Old 03-24-2006, 12:06 PM   #1
IMPORTIMAGE
NASIOC Storefront Vendor
Vendor Sales Rating: (617)
Member#: 79304
CALL 941-257-9618
www.ImportImageRacing.com
Default CoolingMist Water Injection Group Buy!!! Insane Specials!!!
Hello everyone!!!! Get in on the water injection craze, don't be left behind!!! get more power from your modded subaru today!
This is special pricing that I will not be able to repeat this crazy deal!!
Stage I retails for $449.95 your price is $WILL NOT BE DUPLICATED shipped
* Coolingmist Controller Based
* 1-30 psi starting boost
* 1-30 PSI Full Pressure
* Up to 60 psi Pressure
* Includes Software
* Brass water filter
* Complete kit
* 0-5 V input for MAF, TPS, etc
Our Stage I controller kit is a fantastic value. You recieve our high pressure pump, vari-cool tuning controller, a 2.0 quart tank and everything else you need. The controller has a starting point for boost, a maximum point for boost and a tuning knob. The tuning knob gives you 10 algorithms to choose from. For example, if you set the minimum knob at 1 and the max at 30 and have the tuning knob at 1 it will give you a linear feed from 1-30 psi. The higher you change the tuning knob the more agressive the curve. Because of this, you do not need to change injectors when you gain more HP. Our software suite allows you to change the variables in the controller so you can fine tune if you wish. Software requires windows 2000, NT, 2003, or XP +. The controller has a 0-5V input also, so if you prefer to inject the water based on the 0-5 instead of the boost, you can do that also. What else can this unit do? Lets say you want to run based on both 0-5V input and Boost...You can set the 0-5V as the primary input and the boost as secondary or you can set the boost as primary input and 0-5V as secondary. You must have the software configured to run that mode.
Stage II retails for $499.95. Your price $WILL NOT BE DUPLICATED shipped
* Clog Nozzle Detector
* Brass Water Filter
* 2 Quart Tank
* Vari-Cool Coolingmist Controller
* Complete Kit!!!
* No Need To Specify Horsepower!
The Stage II controller kit is a fantastic value. Its exactly the same as stage I except it ships with a brass clog nozzle/water flow detector. It will blink when water/methanol flows and it will tell you if you have a clog. You recieve our high pressure pump, vari-cool tuning controller, a 2.0 quart tank and everything else you need. The controller has a starting point for boost, a maximum point for boost and a tuning knob. The tuning knob gives you 10 algorithms to choose from. For example, if you set the minimum knob at 1 and the max at 30 and have the tuning knob at 1 it will give you a linear feed from 1-30 psi. The higher you change the tuning knob the more agressive the curve. Because of this, you do not need to change injectors when you gain more HP. Our software suite allows you to change the variables in the controller so you can fine tune if you wish. Software requires windows 2000, NT, 2003, or XP +. The controller has a 0-5V input also, so if you prefer to inject the water based on the 0-5 instead of the boost, you can do that also. What else can this unit do? Lets say you want to run based on both 0-5V input and Boost...You can set the 0-5V as the primary input and the boost as secondary or you can set the boost as primary input and 0-5V as secondary. You must have the software configured to run that mode.
Stage III retails for $599.95. Your price $490 shipped
(THE STAGE III COMES WITH A 1 GALLON TANK AND FLOAT SWITCH)
* 12 Feet Of Stainless/Teflon Hose (more optional)
* Stainless Steel Re-Useable fittings
* Hose can be shortened with a Dremel Tool
* 1 Gallon Tank
* Low Fluid Light
The Stage III controller kit is an amazing value. Its exactly the same as stage I except it ships with a 1 gallon tank and a low fluid level switch and 12 feet of stainless steel/teflon hose with stainless steel re-usable hose, Vari-Cool tuning controller and everything else you need. Included in the price is 12 feet of this amazing hose. If you require more select the amount from the drop down box. You will need to cut the hose to the length you want using a dremel tool. This hose is indistructable. The controller has a starting point for boost, a maximum point for boost and a tuning knob. The tuning knob connectors. You recieve our high pressure pump, vari-cool gives you 10 algorithms to choose from. For example, if you set the minimum knob at 1 and the max at 30 and have the tuning knob at 1 it will give you a linear feed from 1-30 psi. The higher you change the tuning knob the more agressive the curve. Because of this, you do not need to change injectors when you gain more HP. Our software suite allows you to change the variables in the controller so you can fine tune if you wish. Software requires windows 2000, NT, 2003, or XP +. The controller has a 0-5V input also, so if you prefer to inject the water based on the 0-5 instead of the boost, you can do that also. What else can this unit do? Lets say you want to run based on both 0-5V input and Boost...You can set the 0-5V as the primary input and the boost as secondary or you can set the boost as primary input and 0-5V as secondary. You must have the software configured to run that mode.
The 150 psi deluxe kit + tank is $299.95, your price is $WILL NOT BE DUPLICATED shipped
* Methanol Safe
* 150 PSI Pump
* 15 Feet of Hose
* Boost Activated 1-25 PSI
* 90 Day Warranty
* Complete Kit
* Professionally Packaged
This is the Cooling Mist DELUXE 150 psi Methanol/Water Injection kit. It comes with everything you need. This comes with our 150 psi pump, brass water filter, 2.0 quart water tank , water tank taping kit and all the wiring, injectors and other things you need. This also ships with our outstanding brass checkvalve. This is a great deal. The boost switch is adjustable from 1-25 psi. Its a great kit at a great price. choose single nozzle or dual nozzle setup from the drop down box. If you have more than 500 HP or if you have twin carbs/throttlebodies we recommend the dual nozzle setup.
Options-
All kits come with a 2 quart tank. There is no pricing difference if someone wants a kit without a tank. If you would like to add a float switch with your order add $20
If you would like to upgrade from a 2 QUART tank to the 1 Gallon your cost is $20 to do so.
Upgrade to the 2.5 gallon tank for $40
Add a controller for $179
I have 5 spots left at the moment, if there is enough interest I might make more room. These parts are all in stock, once we have 5 orders we will ship them out to you!
Participants in the Group Buy-
1. Thran (stage 2 + Float Switch, deposit made, will ship after balance is paid)
2. turbo6speed (stg 2 with Float switch instead of tank, Paid in full!)
3. Mr. Higbee (Deluxe kit + clog detector nozzle, paid in full!)
4. Kenlee (stg 2 setup, paid in full!)
5. KJR (stage 2 + Float Switch, PAID IN FULL!)
6. Hoopty (stage 2 + led light + 2.5 Gallon tank, Paid in full!)
7. Andre W. (stage 2 + float switch, Paid in full!)
8. Mr. Park (Stage 3 kit Paid in full!)
9. JM5999 (Paid in full!)
10. El Supremo (paid in full)
Payments are accepted via visa/mastercard at 239 437 6385
Also, paypal confirmed addresses to [email protected]
Import Image Racing
15460 Bellamar Cir #2722
Ft. Myers, FL 33908
www.importimageracing.com
IMPORTIMAGE is offline
Old 03-24-2006, 03:03 PM   #2
jblaine
Member Sales Rating: (36)
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Bought mine 2 weeks ago.
jblaine is offline
Old 03-24-2006, 03:35 PM   #3
Hoopty
Member Sales Rating: (18)
Member#: 87976
2005 STi
1)Hoopty
Hoopty is offline
Old 03-24-2006, 04:40 PM   #4
AaronB
Worst Mod Ever
Member Sales Rating: (12)
Member#: 369
12 Vagon
How big is the float switch? Will it work in the 2qt tank, or the stock windshield washer bottler?
AaronB is offline
Old 03-24-2006, 07:09 PM   #5
AaronWRX
Member Sales Rating: (2)
Member#: 7194
2011 997.2 Turbo
cool i want in plus the clog fail safe
AaronWRX is offline
Old 03-24-2006, 09:20 PM   #6
kenlee
Member Sales Rating: (7)
Member#: 49341
For that price I'm in for a stage 2. I'ts too late to call so I'll contact you in the morning.
Ken
kenlee is offline
Old 03-25-2006, 01:06 AM   #7
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
Old 03-25-2006, 09:41 AM   #8
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
Another on the list
Old 03-25-2006, 12:49 PM   #9
kenlee
Member#: 49341
Called but there was no answer, so I left a message.
Ken
kenlee is offline
Old 03-25-2006, 06:05 PM   #10
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
All missed calls were called back, had a wedding I had to run to for a few hours.
Old 03-25-2006, 06:46 PM   #11
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
Doesnt look like this will last very long, get in or miss out!!!
Old 03-26-2006, 11:03 AM   #12
kenlee
Member#: 49341
Paypal sent for stage 2.
kenlee is offline
Old 03-26-2006, 12:00 PM   #13
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
Got it, 2 more must be paid, and than we'll ship them out!!! Hurry!!!
Old 03-26-2006, 05:05 PM   #14
El Supremo
Member Sales Rating: (5)
Member#: 38388
I might be in. The optional float switch is a fail safe device? Turns something off when the mixture is too low or just lets you know some how.
El Supremo is offline
Old 03-26-2006, 05:36 PM   #15
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
PM sent
Old 03-26-2006, 06:45 PM   #16
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
Ok we have 4 paid in full right now, just need 1 more and these will be on there way!!!...Hoopty, if you still want in, please send a payment. Its almost over!!!
Josh
Old 03-26-2006, 09:10 PM   #17
Thran
Member Sales Rating: (57)
Member#: 63612
2004 dom 2.5 wrx
Rally Blue
ill be in im waiting on the 29th for my paycheck ; (
only problem
Thran is offline
Old 03-26-2006, 09:16 PM   #18
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
Problem solved...check pm's! we know money doesnt grow on trees, But we have the solution for you!
Old 03-26-2006, 09:28 PM   #19
BlueSTI4Me
Member#: 34361
04.7 STI
Dang, sorry I missed this GB ?
BlueSTI4Me is offline
Old 03-26-2006, 10:48 PM   #20
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
Well Gee that was quick, first 5 are being shipped to us tomorrow From Coolingmist (yes all parts are in stock, we have been working very close with Dave over there on this one!)
We have decided to expand the Group buy to 10 slots, as we have sold 5 kits in 2 days, which is great! So hurry up, you saw how fast the first 5 went, dont miss out!!!!
Old 03-26-2006, 11:40 PM   #21
KJR
Member Sales Rating: (104)
Member#: 16879
Subscribe for tracking....
way to go Thran!
KJR is offline
Old 03-27-2006, 03:46 AM   #22
Thran
Member#: 63612
2004 dom 2.5 wrx
Rally Blue
man KJR i dont know if i can afford it!!!!!!! : D
Thran is offline
Old 03-27-2006, 07:45 AM   #23
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
Well I prepaid for your kit to expedite this group buy, So it'll be here when you have the rest of the $....no big deal
Josh
Old 03-27-2006, 10:27 AM   #24
KJR
Member#: 16879
You can't afford NOT to buy it. You'll be fine dOOd.
KJR is offline
Old 03-27-2006, 01:25 PM   #25
whitson01
Member Sales Rating: (4)
Member#: 100776
2004 sti
white
how does the stage II kit compare to the smc kits and others??
whitson01 is offline
Closed Thread
CoolingMist Varicool stage 2 + Varicool Trunkmount Group buy! Insane prices!! IMPORTIMAGE Vendor 'Group Buy' Classifieds 55 08-01-2007 02:12 PM
CoolingMist Water Injection Group Buy!!! Insane Specials!!! IMPORTIMAGE Vendor 'Group Buy' Classifieds 73 09-25-2006 09:53 AM
73.99 Fuel Pumps shipped, Coolingmist Water Injection specials, Turboxs, SBR, Perrin! IMPORTIMAGE Engine/Power/Exhaust 220 08-05-2006 01:12 PM
Snow Performance Water Injection Group Buy ! F1DYNO Vendor 'Group Buy' Classifieds 8 11-08-2005 05:24 PM
Water injection group buy $300 Shipped! WRXTuner Vendor 'Group Buy' Classifieds 23 01-29-2004 12:07 PM
