Old 03-24-2006, 04:02 PM   #1
spoolnSTi
Member#: 95049
2005 STi
Default harness bar question
im considering getting this harness bar http://www.islandmotorsports.com/cgi...tegory_Code=IS
anyone use this and have any comments on it? I'd also like to get a set of harness seat belts but i'm not sure what to get. what's the difference between 4,5 and 6 point harnesses? I'm considering getting a set from sparco. any opinions would be greatly appreciated!
spoolnSTi is offline   Reply With Quote
Old 03-24-2006, 04:34 PM   #2
samg00dy06STI
Member#: 101736
06 STi
Obsidian black
its a nice harness bar...but for that $$$ you could get sparco harness bar with sparco harnesses...i got my sparco harness bar and two 5point harnesses for $550 from one of the vendors on Nasioc
samg00dy06STI is offline   Reply With Quote
Old 03-24-2006, 04:36 PM   #3
Surfer Steve
Member#: 70981
2005 WRX WRBlue
01 Outback/5mt
^^^I would like to get some feed back as well, I am in the market for the same setup for auto-x...
Surfer Steve is offline   Reply With Quote
Old 03-24-2006, 05:07 PM   #4
spoolnSTi
Member#: 95049
2005 STi
thinks its a bad idea to get this kinda of set up as a daily driver?
Old 03-24-2006, 05:24 PM   #5
D fresh
Member#: 95459
the activity level
of AutoX is > than F1
Yes, unless you'd like your head to pop off in an accident. In general these harnesses do not stretch like a stock seatbelt and therefore should be used for "offroad purposes only."
Unless you like being called a ricer.
D fresh is offline   Reply With Quote
Old 03-25-2006, 04:05 AM   #6
WRXSTiGirl
Member#: 83277
2005 STi Stage II
WRB/Gold
Which vendor was this ??? I'd like to talk to them.
Thanks
-Lisa
WRXSTiGirl is offline   Reply With Quote
Old 03-25-2006, 01:47 PM   #7
STimpede
Member#: 100603
im thinking bad idea as daily driver
1) you'd look ridiculous with a 5pt harness on cruising down a free way
but more importantly
2) if you have rear passengers and you get into a front end collision, you can kiss your buddies good bye. Their skulls will be crushed to a pulp in an instant.
STimpede is offline   Reply With Quote
Old 03-26-2006, 12:59 AM   #8
STirocket
Member#: 84006
2005 Impreza WRX STi
WRB with Goldies
Are you suggesting that if you have a harness bar installed the rear passenger seat belts stop functioning???
STirocket is offline   Reply With Quote
Old 03-26-2006, 12:23 PM   #9
wrxratedsti
Member#: 108667
They'll function as advertised but the stock restraints weren't designed to compensate for a horizontal metal beam 10" in front of the rear passenger's face. Front passengers have airbags to keep their heads from smashing into the steering wheel and dashboard. The harness bar would definately cause major injury to any rear passengers in a header.
wrxratedsti is offline   Reply With Quote
Old 03-26-2006, 01:46 PM   #10
jmolaver
Member#: 19130
'01 TTE Miata
www.awesom-oracing.com
With any harness bar you shouldn't have rear passengers for the reasons stated above.. Don't be daft, big steel bar in front of someone's face? would YOU sit back there?
Also you should never drive on the street with a 5 or 6 point harness but it has nothing to do with looking ridiculous, seat belts stretching, or fear of your "head popping off" in an accident.
The real reasons are that while properly belted in you won't be able to lift your opposing shoulder to check to see if it's safe to change lanes, nor are harnesses DOT approved, hence technically not street legal.
There is also some concern that in a rollover while wearing a harness without a rollbar or cage (ie true rollover protection) you could be crushed as a you cannot "submarine" under the steering column as you could in a standard 3 point belt. IMO this is pretty unsubstantiated as I know of not one incident where this has occured.
I actually looked at all the available options for harness bars and ended up having one custom fabricated by master cage builder Mitch Piper of Piper Motorsports. Huge difference in my confidence of the integrity of my bar vs. the other available ones in the event of an accident.
It's for sale right now for $250 + s/h (only b/c I'm trading in the STi).
jmolaver is offline   Reply With Quote
Harness bar question! gatorREX Interior & Exterior Modification 10 08-27-2007 12:48 PM
Wagon Harness Bar question mrbigisbudgood Motorsports 0 09-12-2006 01:11 PM
Harness bar question itsawagon Interior & Exterior Modification 23 05-25-2005 02:03 AM
harness / harness bar questions spidey02wrx Motorsports 15 10-28-2002 09:25 PM
('93-'01) Harness Bar Questions mwilliams Impreza Forum 6 07-02-2001 01:20 PM
Message Board Statistics All times are GMT -4. The time now is 05:53 PM.
