Welcome to the North American Subaru Impreza Owners Club Saturday October 22, 2016
Old 03-25-2006, 03:15 PM   #1
Member#: 32486
03 WRX
2004 FXT
Question Valve Cover Oil Leak Question
After doing some searching and reading, I'm about 99% sure that I have the valve cover oil leak on the passenger side that some other folks have. It seems pretty static, I usually have a couple drops on the garage floor after driving it all day. There is also a little dried-up oil on the subframe and DP.
With that said, is this something to be concerned about and will get progressively worse or just a part of having a modified car? My buddy said it's not a big deal at all, but I wanted to hear from some Scooby gurus.
Mods are: PDE UP/DP, Cobb STG 2, RP Synthetic, 20000 miles on the Odometer.
MiamiLife is offline   Reply With Quote
Old 03-25-2006, 03:50 PM   #2
drain bramage
Member#: 88189
02 the 4door model
mines been leaking for at least a year. i got the parts to fix it but havent go to it yet.
i leak about a quart a in about 2 months time. i wouldnt worry to much unless you have a bad leak.( but so shouldnt let go as long as i have)
drain bramage is offline   Reply With Quote
Headgasket/timing belt cover oil leak ?'s badfish1134 Normally Aspirated Powertrain 4 06-18-2009 08:53 AM
Front Cover Oil Leak cintoman Service & Maintenance 1 06-01-2007 01:01 PM
Fujimoto oil drain valve and oil change questions ps99115 Newbies & FAQs 38 10-14-2005 08:14 AM
What's wrong?? Head cover Oil leak !!(pic inside) Power_Getter Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-14-2005 05:57 AM
Valve Cover Oil Leak whitet777 Service & Maintenance 10 07-28-2003 09:44 PM
