Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Services
Old 03-25-2006, 04:56 PM   #1
Gruppe-S
Vendor Sales Rating: (65)
Member#: 23216
2006 949-457-1234
949-457-1234
Default Fully Built JDM 2.0 STI High Revving Engine - Built to Order
Hey guys,
We are offering for a very limited time:
JDM STI 2.0 V8 Engines - Fully Built / Forged Internals (Built to Order)
Features:
*Wiseco Forged Pistons (8.5CR)
*Forged Connecting Rods w/ ARP L-19 rodbolts
*Gruppe-S Coated race bearings
*Fully Balanced crankshaft within +/- 1 gram
*All tolerances checked, cylinder walls professionally rehoned
*Helix 264 Camshafts
*Helix Titanium Valvetrain
*ARP Head Studs
*Cometic Head Gaskets
*V8 Big Port Heads
Guys, this is a complete long-block that is fully built to withstand well over 600HP while revving to 8300RPM.
$4999 Built to Order, 50% deposit required
1.0mm Oversized Valves - Add $250
Port & Polish Heads - Add $1200
Please contact us with any questions. Thanks!
Gary
Gruppe-S
Gruppe-S is offline   Reply With Quote
Old 04-02-2006, 03:31 PM   #2
Capt Crunch
Member Sales Rating: (15)
Member#: 10852
Then : JDM Ver 7 STi
Now : E46 M3 / MKVI GTI
Are the JDM components (shortblock and heads) used or new?
Capt Crunch is offline   Reply With Quote
Old 04-03-2006, 02:49 PM   #3
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
They are used. Thanks for asking what should have been originally posted.
-Geoff
Old 04-10-2006, 04:18 AM   #4
chibby goku
Member Sales Rating: (5)
Member#: 32121
Are these helix cams avcs capable?
chibby goku is offline   Reply With Quote
Old 04-10-2006, 01:55 PM   #5
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
They are not.
Thanks,
Geoff
Old 05-08-2006, 09:20 AM   #6
Homemade WRX
Member Sales Rating: (10)
Member#: 33782
96 bastard child
search FIRST, then PM!!!
that's a pretty nice price for all that is included
Old 05-17-2006, 07:40 AM   #7
poorboy
Member Sales Rating: (8)
Member#: 82294
1999 2.5rs
Rally Blue Pearl
wiring harness/ecu included to run it all, if not how much? i may be interested in this.
edit if it's still available.
poorboy is offline   Reply With Quote
Old 05-17-2006, 02:43 PM   #8
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Wiring harnesses and ECU are not included, we do not sell those items.
Regards,
Mark
Old 05-18-2006, 01:50 AM   #9
Kaymin
Member#: 96076
RIP 96 SBM GC8
05 Burnt Orange Evo
What if i want a stock V8 with AVCS or the high redline? How much would it cost if you can do it?
Kaymin is offline   Reply With Quote
Old 05-18-2006, 07:17 AM   #10
poorboy
Member#: 82294
1999 2.5rs
Rally Blue Pearl
yeah, i was curious about how much it would cost to get the bottom end work done, but leaving the heads stock.
Old 05-20-2006, 08:52 PM   #11
BonesXMahones
Member#: 56425
How else can you run his engine if not equipped with ECU and harness? I'm guessing there is only a standalone option? Also, this most likely isn't inspection friendly is it?
BonesXMahones is offline   Reply With Quote
Old 05-24-2006, 02:53 PM   #12
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
So essentially, you'd just like a stock Ver. 8 motor (8000 RPM redline)? These are fairly difficult to come by but we do get them in from time to time. They usually go for around $4000-$4500.
Well the heads are actually quite difficult to come by. A clean set in good working order will be $2000-3000. We get heads that are missing some parts in more frequently; those usually go for $1000-$1500. The shortblock by itself will be in the neighborhood of $3600.
You can buy the ECU and harness from somewhere else or you can run a standalone with this set-up. We do actually have ECUs that will work with this motor. You'll need to reflash the ECU so that is works on 93 or 91 though.
Thanks,
Geoff
Old 06-01-2006, 12:56 AM   #13
saab-on-the-cobb
Member Sales Rating: (45)
Member#: 116330
2005 Saabaru 9-2x
desert sand metallic
Default How about a my05 wagon ecu? Can I pro tune for this motor?
GIve me a break down of all parts required to swap into an MY05 US wagon 5sp.
THanks
SOTC.
saab-on-the-cobb is offline   Reply With Quote
Old 06-01-2006, 03:39 AM   #14
Bolster
Member Sales Rating: (26)
Member#: 22290
2002 WRB WRX Wagon
THanks
SOTC.
Because this won't use AVCS, you should be able to directly swap it into your car. You'd just attach your accessories, manifolds, and harness to it and go. You should be able to tune it, but I don't know if you'll find a pre-made Accessport map for it (forgive me here, I don't know how AP works, and you might be able to tune it yourself with street tuner).
Bolster is offline   Reply With Quote
Old 06-01-2006, 03:41 AM   #15
le wagon
Member#: 109109
2005 WRX wagon
Wrong Fitment Crew #015
core returns? and how much $
le wagon is offline   Reply With Quote
Old 06-01-2006, 03:51 PM   #16
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
That's exactly right but I would not recommend tuning your car yourself unless you're experienced at that type of thing.
Sorry, core returns for what? We provide the block and heads for this package. Did you want to provide your own heads?
Thanks,
Geoff
turbo upgrade for a JDM 2.0 STi?? wich one??? litowrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-22-2007 03:09 PM
2004 wrx 2.0 type long block engine built Three105 Private 'Wanted' Classifieds 0 06-30-2006 11:11 AM
First time at track with JDM 2.0 sti motor wreckedWRX Proven Power Bragging 17 11-04-2004 11:46 AM
Best choice for 350+whp JDM 2.0 sti motor Davenow Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 08-18-2004 10:36 PM
Torque curve US STi vs. JDM 2.0 STi superg STi Forum Archive 6 04-29-2003 10:16 PM
