Old 05-26-2000, 06:13 AM   #1
tahrndt
Member#: 1315
Post air-box thingy-ma-jig
Being relatively new to sooby land I have a question regarding the air intake system. I Just put in a new Amsoil panel filter and in the process I accidently removed my silencer box under in the front fender... well it wasn't an accident. Anyway what is that big ol black box thingy that is between the MAS and the intake manifold? This is on the '97 DOHC engine. Is this a necessary piece of plastic or one of those silly "optional" parts that can be parted ways with?
tahrndt is offline   Reply With Quote
Old 05-26-2000, 06:24 AM   #2
PaulN
Member#: 566
1994 Legacy GTB
Green
Post
I imagine it has the same effect of removing it on NA as turbos - but on the turbo the box just quietens down the intake roar
Remove it - put in a cold air intake instead - you'll get a bit more noise under WOT and you'll lose a bit of excess weight at the same time - you might gain a tiny bit of power at the top end
Paul
PaulN is offline   Reply With Quote
Old 05-26-2000, 08:11 AM   #3
gumball
Member#: 1209
Exclamation
A lot of people have commented on this before- I think the Sport Compact Car issue on custom intakes talked about it too- most intakes replace all the piping betw. the MAF and the throttle body, including the black box thingy.
However SCC found that removal of the black box created turbulence in the throttle body airflow at higher rpm that screwed up the ECU and actually REDUCED horsepower by causing the engine to run lean. W/o a dyno, you probably wouldn't be able to tell- but if you can find a cold air intake that keeps the box in, that's better. I think the black box actually extends the throttle body's plenum air volume which is a good thing, b/c the 2.5 engine has a small volume plenum. The box is pretty empty w/o any restrictive bends inside, so I would leave it there.
[This message has been edited by gumball (edited May 26, 2000).]
gumball is offline   Reply With Quote
Old 05-26-2000, 08:37 AM   #4
Force[FED]
Member#: 292
2011 BMW 535i
Havana Metallic
Cool
Well, since you have a 97 DOHC setup, you have the more ROBUST MAF (hot wire, where the 99 is hot film). I have a 99 2.5GT sedan, but the motor is the same exact DOHC in my brothers 98 2.5RS.
I have a Weapon-R intake on my car, and the intake is actually LOUDER than my 2.5" exhaust when I got WOT above 4K rpms. It's a very unique sound, very throaty. I think it sounds mean. It won't be mistaken for any 1.6L Honda engine anytime soon
My brother has had the Minnam Stage 2 on for almost a year, and I have used the Weapon-R for a few months. No MAF issues. So don't sweat that.
Does it make extra power? Hard to tell for me...my Legacy feels like such a turd after driving my modded 90 Laser RS turbo regardless of intake or not
Kev
www.lagging.com
Force[FED] is offline   Reply With Quote
FS : 04 WRX DP. UP, Air Box Intake System, Alternator Cover Steeldon Engine/Power/Exhaust 13 01-27-2011 07:21 PM
Whatcha Ma Jig...saw? J-Chow Vancouver Impreza Club Forum -- VIC 9 09-22-2008 03:27 AM
Sti air box / snorkkus vs. WRX air box / snorkus neonglh Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 04-30-2007 11:26 AM
short ram air intake heat shield box thingy jkyes Normally Aspirated Powertrain 2 09-03-2003 09:00 PM
Windshield wiper wing thinga-ma-jig Patrick Olsen New England Impreza Club Forum -- NESIC 7 03-12-2001 01:07 PM
